barbandrob 0 Posted June 6, 2025 Posted June 6, 2025 I get the following message what I try to run the server app. "Apple could not verify “EmbyServer” is free of malware that may harm your Mac or compromise your privacy."
barbandrob 0 Posted June 10, 2025 Author Posted June 10, 2025 I had to unblock it under security and privacy. I have another issue though. I am unable to connect to the server from the app. It’s on the same network, VPN and firewall are not the issue. I’ve tried it on Apple TV and on my Google tv. Will not connect.
Luke 42237 Posted June 10, 2025 Posted June 10, 2025 2 hours ago, barbandrob said: I had to unblock it under security and privacy. I have another issue though. I am unable to connect to the server from the app. It’s on the same network, VPN and firewall are not the issue. I’ve tried it on Apple TV and on my Google tv. Will not connect. hi there, what exactly happens when you try to connect?
barbandrob 0 Posted June 11, 2025 Author Posted June 11, 2025 Unable to reach server We’re unable to connect to the selected server right now. Please ensure that it’s running and try again.
Luke 42237 Posted June 11, 2025 Posted June 11, 2025 Hi, how do you know that vpn and firewall are not the issue? Have you taken a look at this? Connecting from Client Apps
