Luke 42242 Posted June 12, 2018 Author Posted June 12, 2018 hi @@jwilson9, i see you're on our legacy installation package. for now, what you can do to update manually is follow these instructions here in posts #3 and #4: https://emby.media/community/index.php?/topic/58613-question-about-my-32-bit-upgrade/?p=574032 Thanks.
altramarine 21 Posted July 18, 2018 Posted July 18, 2018 (edited) Good day gents. I've been updating emby on centos via yum for years. It is my understanding the opensuse repo is legacy now. What is the proper way to update emby going forward? I am on 3.4.1.0 trying to update to 3.5. Just install the .rpm over top?: https://emby.media/linux-server.html Cheers, Edited July 18, 2018 by altramarine
sector327 4 Posted July 21, 2018 Posted July 21, 2018 (edited) Loving Emby in the past. I just installed a new OS (Fedora28 on a new/old desktop) and am having trouble installing Emby. (gotta admit the instructions are only 3 lines and even then, they're for Ubuntu https://emby.media/linux-server.html).anyways, I go to install with "$ sudo dpkg -i emby-server-deb_3.5.0.0_amd64.deb" and I get missing dependency I can't resolve. Any ideas? (or is there a more thorough how-to around? I really like Emby and hate the idea of resorting to plex) $ sudo dpkg -i emby-server-deb_3.5.0.0_amd64.deb (Reading database ... 5043 files and directories currently installed.) Preparing to unpack emby-server-deb_3.5.0.0_amd64.deb ... Unpacking emby-server (3.5.0.0) over (3.4.1.0) ... dpkg: dependency problems prevent configuration of emby-server: emby-server depends on libc6 (>= 2.17); however: Package libc6 is not installed. dpkg: error processing package emby-server (--install): dependency problems - leaving unconfigured Errors were encountered while processing: emby-server [user1@[member="mother"] Downloads]$ sudo dnf install libc6 Last metadata expiration check: 0:43:19 ago on Sat 21 Jul 2018 12:32:23 PM CDT. No match for argument: libc6 Error: Unable to find a match Thanks for any pointers! Edited July 21, 2018 by sector327
sector327 4 Posted July 21, 2018 Posted July 21, 2018 Loving Emby in the past. I just installed a new OS (Fedora28 on a new/old desktop) and am having trouble installing Emby. (gotta admit the instructions are only 3 lines and even then, they're for Ubuntu https://emby.media/linux-server.html).anyways, I go to install with "$ sudo dpkg -i emby-server-deb_3.5.0.0_amd64.deb" and I get missing dependency I can't resolve. Any ideas? (or is there a more thorough how-to around? I really like Emby and hate the idea of resorting to plex) $ sudo dpkg -i emby-server-deb_3.5.0.0_amd64.deb (Reading database ... 5043 files and directories currently installed.) Preparing to unpack emby-server-deb_3.5.0.0_amd64.deb ... Unpacking emby-server (3.5.0.0) over (3.4.1.0) ... dpkg: dependency problems prevent configuration of emby-server: emby-server depends on libc6 (>= 2.17); however: Package libc6 is not installed. dpkg: error processing package emby-server (--install): dependency problems - leaving unconfigured Errors were encountered while processing: emby-server [user1@[member="mother"] Downloads]$ sudo dnf install libc6 Last metadata expiration check: 0:43:19 ago on Sat 21 Jul 2018 12:32:23 PM CDT. No match for argument: libc6 Error: Unable to find a match Thanks for any pointers! argh!!!! Nevermind. I see now you need to select your distrib to download the appropriate packages. (I had the page not full screen and all I saw was the Ubuntu directions. It's ok now but it might help others to show no instructions on the initial page other than direction to "select your distrib".)
alucryd 318 Posted July 21, 2018 Posted July 21, 2018 Why are you trying to install a deb on an rpm distro? Where did you even get dpkg...? Anyway, there's a big-ass dropdown to select the distribution on the download page, fedora instructions are right there with the others. 1
Luke 42242 Posted July 21, 2018 Author Posted July 21, 2018 Thanks alucryd. We need to redesign the download page. 1
Riggs 312 Posted February 14, 2019 Posted February 14, 2019 @@Luke the download page for Fedora us updated? i saw the new dnf which is great if the info is updated Thanks.
Luke 42242 Posted February 14, 2019 Author Posted February 14, 2019 Yes it is fully up to date. Thanks. 1
Riggs 312 Posted April 19, 2019 Posted April 19, 2019 (edited) FYI two weeks ago i started running Emby Server on Fedora 30 beta, no problems to report, just alerts updates fails (asked in other topic, no big deal). @@Luke : Quick question: why the beta releases are 4.1.0.25_x86_64.rpm and the stable are 4.1.0.26_x86_64.rpm? I missed something? beta versions lower number release? Thanks. Edited April 19, 2019 by HRSCR
Luke 42242 Posted April 19, 2019 Author Posted April 19, 2019 FYI two weeks ago i started running Emby Server on Fedora 30 beta, no problems to report, just alerts updates fails (asked in other topic, no big deal). @@Luke : Quick question: why the beta releases are 4.1.0.25_x86_64.rpm and the stable are 4.1.0.26_x86_64.rpm? I missed something? beta versions lower number release? Thanks. See here on that: https://emby.media/community/index.php?/topic/72674-stablebeta/ 1
MASUDA 0 Posted August 1, 2019 Posted August 1, 2019 hello. first time emby user, long time PLEX user exploring alternatives. i just setup emby on my CentOS 7.6.1810 server and that was a breeze. However, i'm trying to add my media files to libraries and this has not been smooth sailing. When I add a library for "Tv shows" it works perfectly. when i add a library for "movies", i get nothing but an empty library. tried it on 2 different folders with movies in them, and same result. i can't find anything useful in the logs, the only mention of the folders with movies are these entries in the logs:2019-08-01 12:02:17.819 Info LibraryMonitor: Watching directory /data/media/animation/Movies2019-08-01 12:02:17.833 Info LibraryMonitor: Watching directory /data/media/tv_shows2019-08-01 12:02:17.863 Info LibraryMonitor: Watching directory /data/media/movies So it looks like it acknowledge my library folder configuration, but after that nothing. The "tv_shows" folder works fine though. All directories have world read+execute, and all files have world read permissions as far as Unix file permissions go. Looking through the logs, there are Error entries related to TheTVDB, but not much else in terms of errors. Does that have anything to do with my problem? (I didn't think so.. but in case I'm wrong about that, please let me know) Any suggestions? TIA.
gatsu 0 Posted August 16, 2019 Posted August 16, 2019 Hi I am running a clean install of Fedora 30 and I followed the instruction on emby's website on how to install emby but server won't start. I get this error when I check the status of emby-server.service: ● emby-server.service - Emby Server is a personal media server with apps on just about every device. Loaded: loaded (/usr/lib/systemd/system/emby-server.service; enabled; vendor preset: disabled) Active: failed (Result: core-dump) since Fri 2019-08-16 11:14:26 EDT; 9min ago Process: 4313 ExecStart=/opt/emby-server/bin/emby-server (code=dumped, signal=ABRT) Main PID: 4313 (code=dumped, signal=ABRT)Aug 16 11:14:26 fedorabox30 emby-server[4313]: --- End of inner exception stack trace ---Aug 16 11:14:26 fedorabox30 emby-server[4313]: at System.IO.FileSystem.CreateDirectory(String fullPath)Aug 16 11:14:26 fedorabox30 emby-server[4313]: at System.IO.Directory.CreateDirectory(String path)Aug 16 11:14:26 fedorabox30 emby-server[4313]: at Emby.Server.Implementations.Logging.FileLogger..ctor(String path)Aug 16 11:14:26 fedorabox30 emby-server[4313]: at Emby.Server.Implementations.Logging.SimpleLogManager.ReloadLogger(LogSeverity severity, CancellationToken cancellationToken)Aug 16 11:14:26 fedorabox30 emby-server[4313]: --- End of inner exception stack trace ---Aug 16 11:14:26 fedorabox30 emby-server[4313]: at System.Threading.Tasks.Task.WaitAllCore(Task[] tasks, Int32 millisecondsTimeout, CancellationToken cancellationToken)Aug 16 11:14:26 fedorabox30 emby-server[4313]: at EmbyServer.Program.Main(String[] args)Aug 16 11:14:26 fedorabox30 systemd[1]: emby-server.service: Main process exited, code=dumped, status=6/ABRTAug 16 11:14:26 fedorabox30 systemd[1]: emby-server.service: Failed with result 'core-dump'. Any help will be appreciated. Thanks.
Luke 42242 Posted August 16, 2019 Author Posted August 16, 2019 Hi I am running a clean install of Fedora 30 and I followed the instruction on emby's website on how to install emby but server won't start. I get this error when I check the status of emby-server.service: ● emby-server.service - Emby Server is a personal media server with apps on just about every device. Loaded: loaded (/usr/lib/systemd/system/emby-server.service; enabled; vendor preset: disabled) Active: failed (Result: core-dump) since Fri 2019-08-16 11:14:26 EDT; 9min ago Process: 4313 ExecStart=/opt/emby-server/bin/emby-server (code=dumped, signal=ABRT) Main PID: 4313 (code=dumped, signal=ABRT) Aug 16 11:14:26 fedorabox30 emby-server[4313]: --- End of inner exception stack trace --- Aug 16 11:14:26 fedorabox30 emby-server[4313]: at System.IO.FileSystem.CreateDirectory(String fullPath) Aug 16 11:14:26 fedorabox30 emby-server[4313]: at System.IO.Directory.CreateDirectory(String path) Aug 16 11:14:26 fedorabox30 emby-server[4313]: at Emby.Server.Implementations.Logging.FileLogger..ctor(String path) Aug 16 11:14:26 fedorabox30 emby-server[4313]: at Emby.Server.Implementations.Logging.SimpleLogManager.ReloadLogger(LogSeverity severity, CancellationToken cancellationToken) Aug 16 11:14:26 fedorabox30 emby-server[4313]: --- End of inner exception stack trace --- Aug 16 11:14:26 fedorabox30 emby-server[4313]: at System.Threading.Tasks.Task.WaitAllCore(Task[] tasks, Int32 millisecondsTimeout, CancellationToken cancellationToken) Aug 16 11:14:26 fedorabox30 emby-server[4313]: at EmbyServer.Program.Main(String[] args) Aug 16 11:14:26 fedorabox30 systemd[1]: emby-server.service: Main process exited, code=dumped, status=6/ABRT Aug 16 11:14:26 fedorabox30 systemd[1]: emby-server.service: Failed with result 'core-dump'. Any help will be appreciated. Thanks. Is that the full contents of the terminal? 1
gatsu 0 Posted August 16, 2019 Posted August 16, 2019 Is that the full contents of the terminal? Hi Luke, Seems like it keeps repeating if I do a journalctl -u emby-server.service -b I get: -- Logs begin at Fri 2019-08-16 04:21:53 EDT, end at Fri 2019-08-16 15:01:09 EDT. -- Aug 16 14:49:35 fedorabox30 systemd[1]: Started Emby Server is a personal media server with apps on just about every device.. Aug 16 14:49:35 fedorabox30 emby-server[1170]: Unhandled Exception: System.AggregateException: One or more errors occurred. (Access to the path '/var/lib/emby/logs' is denied.) ---> System.UnauthorizedAccessException: Access to the path> Aug 16 14:49:35 fedorabox30 emby-server[1170]: --- End of inner exception stack trace --- Aug 16 14:49:35 fedorabox30 emby-server[1170]: at System.IO.FileSystem.CreateDirectory(String fullPath) Aug 16 14:49:35 fedorabox30 emby-server[1170]: at System.IO.Directory.CreateDirectory(String path) Aug 16 14:49:35 fedorabox30 emby-server[1170]: at Emby.Server.Implementations.Logging.FileLogger..ctor(String path) Aug 16 14:49:35 fedorabox30 emby-server[1170]: at Emby.Server.Implementations.Logging.SimpleLogManager.ReloadLogger(LogSeverity severity, CancellationToken cancellationToken) Aug 16 14:49:35 fedorabox30 emby-server[1170]: --- End of inner exception stack trace --- Aug 16 14:49:35 fedorabox30 emby-server[1170]: at System.Threading.Tasks.Task.WaitAllCore(Task[] tasks, Int32 millisecondsTimeout, CancellationToken cancellationToken) Aug 16 14:49:35 fedorabox30 emby-server[1170]: at EmbyServer.Program.Main(String[] args) Aug 16 14:49:36 fedorabox30 systemd[1]: emby-server.service: Main process exited, code=dumped, status=6/ABRT Aug 16 14:49:36 fedorabox30 systemd[1]: emby-server.service: Failed with result 'core-dump'. ...skipping... ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ Then I get the same thing over and over.
mastrmind11 722 Posted August 16, 2019 Posted August 16, 2019 '/var/lib/emby/logs' is denied give emby access 1
gatsu 0 Posted August 17, 2019 Posted August 17, 2019 '/var/lib/emby/logs' is denied give emby access Thanks mastrmind11 and Luke! I got it working I forgot to change the permissions on that directory.
aptalca 71 Posted October 2, 2019 Posted October 2, 2019 (edited) Hi @@Luke I noticed that there are no rpm artifacts on github for the latest beta. Were they missed? Thanks Edited October 2, 2019 by aptalca
Luke 42242 Posted October 3, 2019 Author Posted October 3, 2019 Hi @@Luke I noticed that there are no rpm artifacts on github for the latest beta. Were they missed? Thanks We're looking into it. Please use the testing area for beta related discussion. Thanks.
aptalca 71 Posted October 4, 2019 Posted October 4, 2019 We're looking into it. Please use the testing area for beta related discussion. Thanks. Oops, sorry about that. Will do next time.
Luke 42242 Posted October 4, 2019 Author Posted October 4, 2019 We're looking into it. Please use the testing area for beta related discussion. Thanks. They're uploading now.
aptalca 71 Posted October 5, 2019 Posted October 5, 2019 They're uploading now. Thanks. I see the arm and aarch64 artifacts but not the x86_64
Xnet Project 0 Posted March 2, 2020 Posted March 2, 2020 I just recently installed Emby Server 4.3.1.0_x86_64 on CentOS 8 and ran into the following errors after install: Installed: emby-server-4.3.1.0-1.x86_64 libnsl-2.28-72.el8_1.1.x86_64 Complete! [root@xnetcloud ~]# systemctl status emby-server ● emby-server.service - Emby Server is a personal media server with apps on just about every device. Loaded: loaded (/usr/lib/systemd/system/emby-server.service; enabled; vendor preset: disabled) Active: failed (Result: core-dump) since Mon 2020-03-02 10:47:06 CST; 8s ago Process: 14870 ExecStart=/opt/emby-server/bin/emby-server (code=dumped, signal=ABRT) Main PID: 14870 (code=dumped, signal=ABRT) Mar 02 10:47:06 xnetcloud emby-server[14870]: --- End of inner exception stack trace --- Mar 02 10:47:06 xnetcloud emby-server[14870]: at System.IO.FileSystem.CreateDirectory(String fullPath) Mar 02 10:47:06 xnetcloud emby-server[14870]: at System.IO.Directory.CreateDirectory(String path) Mar 02 10:47:06 xnetcloud emby-server[14870]: at Emby.Server.Implementations.Logging.FileLogger..ctor(String path) Mar 02 10:47:06 xnetcloud emby-server[14870]: at Emby.Server.Implementations.Logging.SimpleLogManager.ReloadLogger(LogSeverity severity, CancellationToken cancellationToken) Mar 02 10:47:06 xnetcloud emby-server[14870]: --- End of inner exception stack trace --- Mar 02 10:47:06 xnetcloud emby-server[14870]: at System.Threading.Tasks.Task.WaitAllCore(Task[] tasks, Int32 millisecondsTimeout, CancellationToken cancellationToken) Mar 02 10:47:06 xnetcloud emby-server[14870]: at EmbyServer.Program.Main(String[] args) Mar 02 10:47:06 xnetcloud systemd[1]: emby-server.service: Main process exited, code=dumped, status=6/ABRT Mar 02 10:47:06 xnetcloud systemd[1]: emby-server.service: Failed with result 'core-dump'. [root@xnetcloud ~]# systemctl start emby-server [root@xnetcloud ~]# systemctl status emby-server ● emby-server.service - Emby Server is a personal media server with apps on just about every device. Loaded: loaded (/usr/lib/systemd/system/emby-server.service; enabled; vendor preset: disabled) Active: failed (Result: core-dump) since Mon 2020-03-02 10:47:21 CST; 1s ago Process: 14924 ExecStart=/opt/emby-server/bin/emby-server (code=dumped, signal=ABRT) Main PID: 14924 (code=dumped, signal=ABRT) I even tried removing both group and user for emby and reinstalled to no avail. Not sure if this is an issue with the latest systemd version and Python3. Any update would help.
