Blue278 22 Posted May 22, 2025 Posted May 22, 2025 (edited) 5 hours ago, Luke said: HI, we are looking into this. Thanks. Thanks for the update I’m temporarily cancelling my subscription until it’s fixed because I can’t use Emby in its current state. I use subtitles 90% of the time. Hopefully it will be fixed soon. Edited May 22, 2025 by Blue278
Luke 42283 Posted May 22, 2025 Posted May 22, 2025 9 minutes ago, Blue278 said: Thanks for the update I’m temporarily cancelling my subscription until it’s fixed because I can’t use Emby in its current state. I use subtitles 90% of the time. Hopefully it will be fixed soon. How do subtitles relate to this?
Blue278 22 Posted May 22, 2025 Posted May 22, 2025 (edited) 12 minutes ago, Luke said: How do subtitles relate to this? Because of the constant frame drops/stuttering when subtitles are enabled. It’s unwatchable.therefore I don’t use emby. Edited May 22, 2025 by Blue278
Luke 42283 Posted May 31, 2025 Posted May 31, 2025 On 5/22/2025 at 1:27 AM, Blue278 said: Because of the constant frame drops/stuttering when subtitles are enabled. It’s unwatchable.therefore I don’t use emby. Hi, can you give it another try?
Blue278 22 Posted May 31, 2025 Posted May 31, 2025 (edited) 11 hours ago, Luke said: Hi, can you give it another try? The issue still exists. Here’s a little insight: the stutter/frame drops start the moment someone speaks and the subtitles begin. jellyfin doesn't have this issue. Edited May 31, 2025 by Blue278
Luke 42283 Posted June 8, 2025 Posted June 8, 2025 On 6/7/2025 at 1:26 PM, Blue278 said: Any closer to fixing the bug? Thanks Are you asking about subtitles or "not auto-playing next episode" ?
Blue278 22 Posted June 8, 2025 Posted June 8, 2025 (edited) 2 hours ago, Luke said: Are you asking about subtitles or "not auto-playing next episode" ? "not auto-playing next episode" The subtitle issue is on another thread. Edited June 8, 2025 by Blue278 1
Blue278 22 Posted June 28, 2025 Posted June 28, 2025 On 09/06/2025 at 06:10, Blue278 said: I hope the two bugs get fixed soon Not sure if it's been addressed. "auto-playing next episode" seams to be working so far. 1
Blue278 22 Posted July 3, 2025 Posted July 3, 2025 On 28/06/2025 at 17:59, Blue278 said: Not sure if it's been addressed. "auto-playing next episode" seams to be working so far. Short lived. Still having issues 1
Blue278 22 Posted July 10, 2025 Posted July 10, 2025 Can you please prioritise auto-playing next episode bug. Thanks
Blue278 22 Posted July 20, 2025 Posted July 20, 2025 On 22/05/2025 at 06:27, Blue278 said: Because of the constant frame drops/stuttering when subtitles are enabled. It’s unwatchable.therefore I don’t use emby. Any news regarding subtitle issues?
Luke 42283 Posted July 24, 2025 Posted July 24, 2025 On 7/20/2025 at 11:52 AM, Blue278 said: Any news regarding subtitle issues? Hi, we are looking into it. Thanks.
Blue278 22 Posted July 25, 2025 Posted July 25, 2025 (edited) 11 hours ago, Luke said: Hi, we are looking into it. Thanks. Thanks, but in its current state, Emby isn’t really cutting it for. daily use. I really do hope it gets sorted sooner rather than later. Edited July 25, 2025 by Blue278 1
Blue278 22 Posted July 27, 2025 Posted July 27, 2025 (edited) For now, I’ll cancel my subscription until the two bugs are fixed, as it’s been over two months since I reported them. What’s surprising is that Jellyfin, which is completely free, doesn’t have these issues. Emby has a lot of potential but falls short of basic functions. I want to emphasise that this is constructive criticism, not meant to offend.I'm really rooting for Emby to be a bigger success than it already is. Looking forward to what I would like to see in future updates and features. Bugs: * Auto play next episode(Only Affects Apple TV & Android) * Framerate stuttering/frame drop when subtitles are enabled(Only Affects Apple TV & Android) Features lacking on Apple TV compared to Android and web version: * A-Z search * HDR * Thumb view option Thanks Edited July 27, 2025 by Blue278
vdatanet 1619 Posted July 27, 2025 Posted July 27, 2025 1 hour ago, Blue278 said: Features lacking on Apple TV compared to Android and web version: Yes, the Emby app for Apple TV lacks some features, but Jellyfin lacks an app for Apple TV.
Blue278 22 Posted July 27, 2025 Posted July 27, 2025 1 hour ago, vdatanet said: Yes, the Emby app for Apple TV lacks some features, but Jellyfin lacks an app for Apple TV. You’re right. Perhaps I should compare Emby to Plex, as they both offer a paid subscription. In this case, Plex wins hands down for functionality with Apple TV.
Blue278 22 Posted July 27, 2025 Posted July 27, 2025 (edited) 3 hours ago, Blue278 said: For now, I’ll cancel my subscription until the two bugs are fixed, as it’s been over two months since I reported them. What’s surprising is that Jellyfin, which is completely free, doesn’t have these issues. Emby has a lot of potential but falls short of basic functions. I want to emphasise that this is constructive criticism, not meant to offend.I'm really rooting for Emby to be a bigger success than it already is. Looking forward to what I would like to see in future updates and features. Bugs: * Auto play next episode(Only Affects Apple TV & Android) * Framerate stuttering/frame drop when subtitles are enabled(Only Affects Apple TV & Android) Features lacking on Apple TV compared to Android and web version: * A-Z search * HDR * Thumb view option Thanks Update: Framerate stutters/drop when subtitles are enabled. A temporary fix is to enable “Playback Correction” (only affects Apple TV and Android). Edited July 27, 2025 by Blue278 1
pwhodges 2037 Posted August 10, 2025 Posted August 10, 2025 In those three months of this thread I don't see a single description of a specific occurrence with supporting logs and details of your relevant settings (there are several for subtitles, for instance) so that the devs can find the cause. You don't even say what type of subtitles are involved (srt, ass, vobsub, pgs) or whether they are embedded or in separate files. This kind of information is necessary because you can't assume that everybody else has the same issues - I don't for one (and I use subtitles 100%, of nearly all kinds). Paul 1
Blueskies278 43 Posted August 10, 2025 Posted August 10, 2025 (edited) I posted the Log file here Log file for "Not auto-playing next episode" on page one. Luke replied to both of them, saying they were being looked into, back in May. Edited August 10, 2025 by Blueskies278
pwhodges 2037 Posted August 10, 2025 Posted August 10, 2025 Sorry - I missed that. The way you embedded the download in the text made it less prominent than I expected. It's usually best to supply the main server log at the same time (though of course you won't have the corresponding one now!). Paul 1
rhodges 49 Posted September 11, 2025 Posted September 11, 2025 (edited) I also have the issue with TV episodes not playing the next episode. Edge browser. The option is enabled, I just get a couple buttons on the bottom of the screen with an option to play the next episode if I click on it, but it never automatically plays it. These are episodes I have already watched, so maybe it just doesn't want to autoplay a watched episode. I haven't verified that yet. Edited September 11, 2025 by rhodges
rhodges 49 Posted September 11, 2025 Posted September 11, 2025 (edited) It might be related to transcoding. So far, after turning that off (actually changing it so it just does 1080p 60Mbs, effectively disabling it) it seems to be working. Edited September 11, 2025 by rhodges
