gruppa 3 Posted August 22, 2024 Posted August 22, 2024 I have it setup to play next episode automatically in the playback settings but more often that not it doesn't work. I am currently watching a several season long series and sometimes it does auto-play the next one but most of the time it will just go to a black screen at the end of an episode and I have to manually click the next item button at the bottom. Emby 4.8.8.0 in Firefox. Any help would be much appreciated.
Luke 42283 Posted August 22, 2024 Posted August 22, 2024 Hi there, can you please provide a specific example? Thanks.
gruppa 3 Posted August 22, 2024 Author Posted August 22, 2024 14 minutes ago, Luke said: Hi there, can you please provide a specific example? Thanks. Right now I'm watching Batman the Animated Series. Season 1 has 60 episodes, all about ~23 minutes long. Most of them do not play the next episode automatically. Only about 1 in 10 will go to the next one. Usually when an episode ends the playback time will sit at -0:00 and will stay there until I manually click the next episode (next item) button.
gruppa 3 Posted August 22, 2024 Author Posted August 22, 2024 I will check in Edge and Chrome tomorrow and let you know. I have it playing in the background at work. One thing I did notice on this particular computer is the arrows on the edges Continue Watching and Latest Movies and TV that let you scroll left and right through the list aren't there, both in Chrome and FF. However they are there on other computers. 1
Luke 42283 Posted August 23, 2024 Posted August 23, 2024 1 hour ago, gruppa said: I will check in Edge and Chrome tomorrow and let you know. I have it playing in the background at work. One thing I did notice on this particular computer is the arrows on the edges Continue Watching and Latest Movies and TV that let you scroll left and right through the list aren't there, both in Chrome and FF. However they are there on other computers. Do you have a touch input device connected? That could be why.
gruppa 3 Posted August 23, 2024 Author Posted August 23, 2024 33 minutes ago, Luke said: Do you have a touch input device connected? That could be why. No, it's a PC using a wall mounted TV for a monitor. No touch input devices at all.
Happy2Play 9814 Posted August 23, 2024 Posted August 23, 2024 1 hour ago, gruppa said: One thing I did notice on this particular computer is the arrows on the edges Continue Watching and Latest Movies and TV that let you scroll left and right through the list aren't there, both in Chrome and FF. However they are there on other computers. 1 minute ago, gruppa said: mounted TV for a monitor So I will guess Emby is using TV mode. User icon-App Setting-Display-Display Mode. May need to change from Auto to Desktop.
gruppa 3 Posted August 23, 2024 Author Posted August 23, 2024 (edited) Just changed display mode to Desktop but the scroll arrows still do not appear. Just for giggles I changed it to TV and that at least lets me click and drag to scroll left and right. Also, I am not using any custom CSS or code. It's vanilla Emby. It's also running Win11. Not sure if it matters. I will test it on another Win11 machine later. Edited August 23, 2024 by gruppa add info
Luke 42283 Posted August 23, 2024 Posted August 23, 2024 40 minutes ago, gruppa said: Just changed display mode to Desktop but the scroll arrows still do not appear. Just for giggles I changed it to TV and that at least lets me click and drag to scroll left and right. Also, I am not using any custom CSS or code. It's vanilla Emby. It's also running Win11. Not sure if it matters. I will test it on another Win11 machine later. Try opening this page in the browser: https://hover-pointer-media-query.glitch.me/ In the top section, boxes 5-8 should all be green.
gruppa 3 Posted August 23, 2024 Author Posted August 23, 2024 3 minutes ago, Luke said: In the top section, boxes 5-8 should all be green. Only the first 4 that say :none are green. Hover, fine and course are red. Do you have any idea how to fix that? It's doing the same thing in FF, Chrome and Edge.
gruppa 3 Posted August 23, 2024 Author Posted August 23, 2024 So I tested the autoplay next episode on another computer in Chrome, FF and Edge and it does the same thing, but I have a feeling it just the media itself. If I back it up 10 seconds and let it play through to the end it will sometimes autoplay when before it didn't. I also tested with the A-Team and all episodes autoplayed. There is still the issue with the scroll hover arrows not showing up. I went to the https://hover-pointer-media-query.glitch.me/ site on another computer and hover tests fine and works in Emby so it's not Win11. I have no idea why CSS hover on Edge, Chrome and FF are broken on this computer.
tiff1002 7 Posted September 1, 2024 Posted September 1, 2024 I think I have the exact same problem and while I agree it seems to be certain media files that have the problem and others that dont... At least that is what I thought... Now it has started happening on videos it never happened before on so maybe that assumption is wrong. It is super annoying since I like to shuffle a playlist at night and having to click next makes me wake up again and not get my sleep :(
visproduction 338 Posted September 1, 2024 Posted September 1, 2024 Similar issue? https://emby.media/community/index.php?/topic/131166-shuffling-a-large-playlist-wont-select-songs-later-in-the-playlist/&do=findComment&comment=1377420
tiff1002 7 Posted September 1, 2024 Posted September 1, 2024 Similar, but it is not limited to large playlists (happens the most there) and I'm not doing music this is all TV shows.
Luke 42283 Posted September 5, 2024 Posted September 5, 2024 On 9/1/2024 at 12:27 PM, tiff1002 said: Similar, but it is not limited to large playlists (happens the most there) and I'm not doing music this is all TV shows. HI, yes please follow that other topic. We are looking into it. Thanks. 1
Blue278 22 Posted May 4, 2025 Posted May 4, 2025 I have the same issue with Android and Apple TV. I can see the grey bar moving, but when it gets to the end, nothing happens until I press enter on the remote.
Lessaj 485 Posted May 4, 2025 Posted May 4, 2025 1 hour ago, Blue278 said: I have the same issue with Android and Apple TV. I can see the grey bar moving, but when it gets to the end, nothing happens until I press enter on the remote. Is it sitting on a screen of rotating backdrops (if you have multiple backdrops) and a "Next episode" button and that's it?
Blue278 22 Posted May 11, 2025 Posted May 11, 2025 On 04/05/2025 at 16:53, Lessaj said: Is it sitting on a screen of rotating backdrops (if you have multiple backdrops) and a "Next episode" button and that's it? No
Lessaj 485 Posted May 11, 2025 Posted May 11, 2025 Just now, Blue278 said: No What is shown on screen while it "does nothing"?
Blue278 22 Posted May 12, 2025 Posted May 12, 2025 23 hours ago, Lessaj said: What is shown on screen while it "does nothing"? Blank screen 1
Luke 42283 Posted May 13, 2025 Posted May 13, 2025 On 5/12/2025 at 1:34 PM, Blue278 said: Blank screen Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Blue278 22 Posted May 17, 2025 Posted May 17, 2025 Auto-play next episode not working 17/05/2025, 15:16 Blueskies278 emby_android_1747491099205.txt
Blue278 22 Posted May 21, 2025 Posted May 21, 2025 On 17/05/2025 at 15:27, Blue278 said: Auto-play next episode not working 17/05/2025, 15:16 Blueskies278 emby_android_1747491099205.txt How do I know if this issue is being addressed? Thanks
Luke 42283 Posted May 21, 2025 Posted May 21, 2025 7 hours ago, Blue278 said: How do I know if this issue is being addressed? Thanks HI, we are looking into this. Thanks. 1
