Luke 42242 Posted November 25, 2019 Author Posted November 25, 2019 OK thanks, we'll take a look. This is something in the Roku app that will need to be corrected and is not related to the server update.
ebr 16335 Posted November 25, 2019 Posted November 25, 2019 Hi. Can you give me exact steps to reproduce? I cannot make this happen. Thanks.
sekondchakra 6 Posted November 26, 2019 Posted November 26, 2019 - Play a local file (eg, .mp4) - Use back arrow on Roku remote to return to the episode screen that shows you "Play" "played" "favorite" "delete", etc. -Select "Delete" & Confirm Delete - Screen returns to "Next Up" screen -Hit back arrow on remote in attempt to return to Emby Home screen - Emby app quits and returns you to Roku Home screen. Have to restart Emby app to watch next file. Video of steps described Note: Happens on both Emby Beta and Emby Stable. Roku Ultra is running latest version of it's software (v9.2.0 build 4750-46) Emby Beta software updated recently. Was having this issue for awhile (early Oct?) but resolved itself a week or so ago. Returned after updating to emby-server 4.3.0.26 a couple of days ago? Generally run latest beta available--update often.
Luke 42242 Posted November 27, 2019 Author Posted November 27, 2019 Thanks for those steps as well as the video. We'll look into this.
Guest plexman Posted November 27, 2019 Posted November 27, 2019 We want the last stable on Arch repositories !! @@alucryd Just joking, release it when ready, i'll wait patiently.
Luke 42242 Posted November 27, 2019 Author Posted November 27, 2019 We want the last stable on Arch repositories !! @@alucryd Just joking, release it when ready, i'll wait patiently. We're working on it. Thanks for the feedback.
sekondchakra 6 Posted December 17, 2019 Posted December 17, 2019 - Play a local file (eg, .mp4) - Use back arrow on Roku remote to return to the episode screen that shows you "Play" "played" "favorite" "delete", etc. -Select "Delete" & Confirm Delete - Screen returns to "Next Up" screen -Hit back arrow on remote in attempt to return to Emby Home screen - Emby app quits and returns you to Roku Home screen. Have to restart Emby app to watch next file. Video of steps described Note: Happens on both Emby Beta and Emby Stable. Roku Ultra is running latest version of it's software (v9.2.0 build 4750-46) Emby Beta software updated recently. Was having this issue for awhile (early Oct?) but resolved itself a week or so ago. Returned after updating to emby-server 4.3.0.26 a couple of days ago? Generally run latest beta available--update often. Last weeks update to Emby Server Beta 4.4.2 and Emby Roku beta app v3.0-build 203 seems to have remedied this dropping-back-to-Home-Menu issue I'd been having for quite awhile. Thanks!
sekondchakra 6 Posted December 21, 2019 Posted December 21, 2019 Last weeks update to Emby Server Beta 4.4.2 and Emby Roku beta app v3.0-build 203 seems to have remedied this dropping-back-to-Home-Menu issue I'd been having for quite awhile. Thanks! This problem has resurfaced after upgrading to emby server beta v4.4.0.2-4 this evening.
henryford 11 Posted December 28, 2019 Posted December 28, 2019 (edited) Moved to a new topic: https://emby.media/community/index.php?/topic/80844-arch-outgoing-network-connections-timing-out-on-new-install/ Edited December 28, 2019 by henryford
Luke 42242 Posted December 28, 2019 Author Posted December 28, 2019 This problem has resurfaced after upgrading to emby server beta v4.4.0.2-4 this evening. @@sekondchakra can you please create a topic in the Roku section of the community? Thanks !
Luke 42242 Posted March 3, 2020 Author Posted March 3, 2020 For those looking for additional options to run Emby Server, we now have Snap packages available for testing: https://emby.media/community/index.php?/topic/83274-emby-server-snap-packages/ Thanks !
sekondchakra 6 Posted June 10, 2020 Posted June 10, 2020 That CAN'T be right, but sure enough. The beta is still there...
Guest Posted June 10, 2020 Posted June 10, 2020 (edited) That CAN'T be right, but sure enough. The beta is still there... I just now moved to docker, easy enough transfer, just use Kitematic, install it with that, and in Volumes, set /config to /var/lib/emby, done. (p.s. make sure you power off pacman emby-server prior to any docker business or your gonna have a bad time with database locks) Edited June 10, 2020 by PRAGMA
Luke 42242 Posted June 11, 2020 Author Posted June 11, 2020 On 6/9/2020 at 10:22 PM, PRAGMA said: The Arch Linux package has completely disappeared? It should be restored now. Thanks.
Seb8888 0 Posted August 29, 2020 Posted August 29, 2020 Hello im new here do you have tutorial how give access on my folder on Manjaro ?
fattony 4 Posted August 29, 2020 Posted August 29, 2020 Have a look at emby's systemd service file, is there a line ReadWritePaths= if so you may need to add a path to your folder systemctl edit emby-server [Service] ReadWritePaths=/path/to/my/share regards 1
Seb8888 0 Posted August 30, 2020 Posted August 30, 2020 Where you can explain more please im new on linux and new on emby lol
Guest Posted August 30, 2020 Posted August 30, 2020 2 hours ago, fattony said: Have a look at emby's systemd service file, is there a line ReadWritePaths= if so you may need to add a path to your folder systemctl edit emby-server [Service] ReadWritePaths=/path/to/my/share regards 8 minutes ago, ZombTux said: Where you can explain more please im new on linux and new on emby lol None of that is necessary, simply add the user `emby` to a group in which the files are allowed read-access to. I believe there's also a group called `emby` which you could use. You could go ahead and make a NEW group called `homeserver` or such and add root, all your users, and `emby` to that group. Once done, make sure that you set all files to use the `homeserver` group (keep the user perms set to you though). `sudo chown username:homeserver -R /path/to/root/of/your/files/you/wanna/share`
Seb8888 0 Posted August 30, 2020 Posted August 30, 2020 2 minutes ago, PRAGMA said: None of that is necessary, simply add the user `emby` to a group in which the files are allowed read-access to. I believe there's also a group called `emby` which you could use. You could go ahead and make a NEW group called `homeserver` or such and add root, all your users, and `emby` to that group. Once done, make sure that you set all files to use the `homeserver` group (keep the user perms set to you though). `sudo chown username:homeserver -R /path/to/root/of/your/files/you/wanna/share` When i try change permission on my folder im not root where i can change this on terminal ?
Luke 42242 Posted August 30, 2020 Author Posted August 30, 2020 11 minutes ago, ZombTux said: anyone ? Hi there, have you checked out our file permissions guide?
AGhost 0 Posted September 2, 2020 Posted September 2, 2020 (edited) Thought this was about the best place to post my issue. I just moved Sputnik (2020) to my movies from it's temporary location and I cannot get it to pull information when I select identify. I get no results at all. I decided to try on other movies in the library and it's the same even though everything else in the library and my other libraries are correct. Any idea why Emby might not be pulling data from any of the sites setup just for this? Steps attempted below. Thanks launched emby opened movies library found what sputnix was being called clicked the 3 dots selected identify searched for sputnik nothing searched for sputnik 2020 nothing searched by it's movie database number nothing embyserver.txt Edited September 2, 2020 by AGhost
AGhost 0 Posted September 2, 2020 Posted September 2, 2020 (edited) On 8/29/2020 at 2:25 PM, ZombTux said: Hello im new here do you have tutorial how give access on my folder on Manjaro ? If you're using Manjaro KDE which I'd personally suggest you do you can simply add the Services Menu and then the Root Action to that. Then you would be able to rightclick in the folder you want to share with Emby and under Root Actions select ownership to active user, click yes when asked, then enter your password. They can walk you through adding the above on the Manjaro forums, or you can go to the KDE forums and request help there. Edited September 2, 2020 by AGhost
