hooray4me 52 Posted February 12, 2019 Posted February 12, 2019 Somehow my logs didn't attach... just edited my post.
avalon65 2 Posted February 17, 2019 Posted February 17, 2019 (edited) I have emby , on my linux pc, and have emby installed on my FreeNAS server. The ip address of emby on my desktop is that which FreeNAS assigned. I have my media files mounted on my linux pc under /mnt/path to media/files When I try to add a folder for media files, I click on the / and that gives a list of folders. When I select mnt, there is nothing there. Is the /mnt in emby the same as /mnt on my linux pc or is it the network/FreeNAS /mnt. Which ever it is, the media files are showing under /mnt on both FreeNAS and linux pc. Where is emby looking for the medial files. Thanks Update: I didn't realise and not remembered that I had add the media files into emby storage on my FreeNAS machine. Embey now sees the said files and they are now added into emby. Edited February 19, 2019 by avalon65
jds_emby 0 Posted March 2, 2019 Posted March 2, 2019 As far as I can tell, this is the best place to post my question, but if I am wrong, would be happy to move it. I recently installed Emby on my Ubuntu 18.04 server. It looks beautiful, and fixes my problems transcoding in Plex. However, it is extremely unstable, and crashes constantly. Sometimes the crash is provoked reproducibly, like when it was scanning either my Books folder or my Personal Photos and Videos folder. However, I removed those libraries, and it still crashes reproducibly. For example, I would start playing a video, and the emby server would crash. However, if the server were restarted, it would then play that video fine. One thing that might be reproducible is accessing the server with the emby app on the Amazon Fire stick. If I opened the library and browsed through the videoes alphabetically, clicking on a letter would crash the server. This even creates problems with the whole fire stick, because the emby error message would stay on the screen. I could also make it crash reproducibly by going to my Movies library, and clicking on a letter on the right side of the browser app. That would give: $ sudo systemctl status emby-server● emby-server.service - Emby Server is a personal media server with apps on just about every device. Loaded: loaded (/usr/lib/systemd/system/emby-server.service; enabled; vendor preset: enabled) Active: failed (Result: signal) since Sat 2019-03-02 15:34:04 CST; 1min 20s ago Process: 31054 ExecStart=/opt/emby-server/bin/emby-server (code=killed, signal=SEGV) Main PID: 31054 (code=killed, signal=SEGV)Mar 02 15:34:00 jdsden emby-server[31054]: Info App: SyncRepository Initialize taking write lockMar 02 15:34:00 jdsden emby-server[31054]: Info App: SyncRepository Initialize write lock takenMar 02 15:34:00 jdsden emby-server[31054]: Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0.0076808 secondsMar 02 15:34:00 jdsden emby-server[31054]: Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPointMar 02 15:34:00 jdsden emby-server[31054]: Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0.0024432 secondsMar 02 15:34:00 jdsden emby-server[31054]: Info App: Starting entry point EmbyServer.Windows.LoopUtilEntryPointMar 02 15:34:00 jdsden emby-server[31054]: Info App: Entry point completed: EmbyServer.Windows.LoopUtilEntryPoint. Duration: 0.0004542 secondsMar 02 15:34:00 jdsden emby-server[31054]: Info App: All entry points have startedMar 02 15:34:04 jdsden systemd[1]: emby-server.service: Main process exited, code=killed, status=11/SEGVMar 02 15:34:04 jdsden systemd[1]: emby-server.service: Failed with result 'signal'. Since it solves the transcoding problem, I really want to get it to work. Also, because it is open source, I am much more inclined to use it instead of plex. However, if it won't run reliably, it is not really tenable. I have the logs from one the crashes, and can post. However, I could not be sure if they would reveal any information that should not be public. In the meantime, here is some information that is certainly safe to post publicly: NAME="Ubuntu"VERSION="18.04.2 LTS (Bionic Beaver)"ID=ubuntuID_LIKE=debianPRETTY_NAME="Ubuntu 18.04.2 LTS"VERSION_ID="18.04"HOME_URL="https://www.ubuntu.com/"SUPPORT_URL="https://help.ubuntu.com/"BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"VERSION_CODENAME=bionicUBUNTU_CODENAME=bionic 2019-03-02 14:49:27.747 Info Main: Application path: /opt/emby-server/system/EmbyServer.dll2019-03-02 14:49:27.856 Info Main: Emby Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.15.0.45 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 12 Program data path: /var/lib/emby Application directory: /opt/emby-server/system2019-03-02 14:49:27.887 Info App: Application version: 4.0.2.0 Here are the very few relevant lines from syslog: Mar 2 13:56:42 jdsden systemd[1]: emby-server.service: Main process exited, code=killed, status=11/SEGVMar 2 13:56:42 jdsden systemd[1]: emby-server.service: Failed with result 'signal'. The media files are not accessed through a network, but rather are on the server. I have found one post that is similar, but has been inactive for many months: https://emby.media/community/index.php?/topic/60122-emby-server-segfaulting-on-1604-lts/page-3 Some of those folks had a problem with permissions, but I checked that, and it had no effect.
sfatula 208 Posted March 2, 2019 Posted March 2, 2019 (edited) Generally, you should post the complete log file, not just excerpts. There will be additional details and may be additional clues. Note, on Ubuntu 18.04.2 for us, never ever crashes (even with SMB) so it is going to be something specific to your machine or setup. We use it daily. Remember to check *all* file perms, not just your media library, but, metadata folders, .config folder for Emby, the user it rans as, etc. Edited March 2, 2019 by sfatula
jds_emby 0 Posted March 3, 2019 Posted March 3, 2019 (edited) Generally, you should post the complete log file, not just excerpts. There will be additional details and may be additional clues. Note, on Ubuntu 18.04.2 for us, never ever crashes (even with SMB) so it is going to be something specific to your machine or setup. We use it daily. Remember to check *all* file perms, not just your media library, but, metadata folders, .config folder for Emby, the user it rans as, etc. Thanks for the tip. I checked these directories from Path in the dashboard, and looked at those permissions. I see that they are all owned by emby. I had assumed that they would be given ownership by my username, because that is how I installed it. I was wrong, obviously/ I don't want to change the ownership of the media files, because they are accessed by other software that also needs permission. I added emby as an agent to my username, then made sure that they had access by the following: sudo usermod -a -G jay emby chmod -R a+rx /media/virtual/Movies EDIT: For the moment, at least, this is working. Is this a reasonable way? Just in case, I have uploaded the log. It still crashes with the above. Log_emby.txt Edited March 3, 2019 by jds_emby
hooray4me 52 Posted March 3, 2019 Posted March 3, 2019 Thanks for the tip. I checked these directories from Path in the dashboard, and looked at those permissions. I see that they are all owned by emby. I had assumed that they would be given ownership by my username, because that is how I installed it. I was wrong, obviously/ I don't want to change the ownership of the media files, because they are accessed by other software that also needs permission. I added emby as an agent to my username, then made sure that they had access by the following: sudo usermod -a -G jay emby chmod -R a+rx /media/virtual/Movies For the moment, at least, this is working. Is this a reasonable way? Just in case, I have uploaded the log. I run the same distro... since you don't want the USER "emby" to own the files, then as long as you grant read (write if you want to be able to delete) for the emby user to what ever group has those permissions then you should be good. So if the owner of your media files is jay and the primary group for the media file is jay... and those permissions are recursive, then doing usermod -a -G jay emby was all you needed to do.
francoib 0 Posted March 3, 2019 Posted March 3, 2019 Hello,for several versions already Emby is crashing almost every time I search for an item. This started when I upgraded the application, but I can't remember when, I thought the next version would solve the problem but I've updated the system several times since and the issue is still there. An extract of the log before the crash is attached. Thanks for your help, I can't figure this out...
Tur0k 148 Posted March 3, 2019 Posted March 3, 2019 Hello, for several versions already Emby is crashing almost every time I search for an item. This started when I upgraded the application, but I can't remember when, I thought the next version would solve the problem but I've updated the system several times since and the issue is still there. An extract of the log before the crash is attached. Thanks for your help, I can't figure this out... Specs on server? Have you checked your log? Might be better to start a new thread that has this information. Sent from my iPhone using Tapatalk
Luke 42244 Posted March 5, 2019 Author Posted March 5, 2019 Hello, for several versions already Emby is crashing almost every time I search for an item. This started when I upgraded the application, but I can't remember when, I thought the next version would solve the problem but I've updated the system several times since and the issue is still there. An extract of the log before the crash is attached. Thanks for your help, I can't figure this out... @@francoib, can you please attach the emby server log? Thanks !
francoib 0 Posted March 5, 2019 Posted March 5, 2019 Sorry, looks like I missed something attaching the file last time... I hope this time I'll got it right. Ubuntu 16.04.3 LTS emby version: Version 4.0.2.0 Thanks a lot for your support Françoisembyserverextract.log
Luke 42244 Posted March 6, 2019 Author Posted March 6, 2019 Sorry, looks like I missed something attaching the file last time... I hope this time I'll got it right. Ubuntu 16.04.3 LTS emby version: Version 4.0.2.0 Thanks a lot for your support Françoisembyserverextract.log Please see here for a solution: https://emby.media/community/index.php?/topic/69167-emby-server-4010-crashing-on-music-playback Thanks.
Tavarusj 0 Posted March 26, 2019 Posted March 26, 2019 Anybody install on a cloud based server? Considering purchasing cloud server access on www.ionos.com. What yall think?
weble 19 Posted March 26, 2019 Posted March 26, 2019 Anybody install on a cloud based server? Considering purchasing cloud server access on www.ionos.com. What yall think? Would work fine as long as you didn't have to transcode much, as you have no hardware transcoding options. So as long as most of your clients can direct play your good to go. Where would you be storing your media?
LeidenSpain 33 Posted April 6, 2019 Posted April 6, 2019 (edited) Good morning, I wanted to take up the problem of transcoding in ubuntu with intel hardware, but I just saw this. Does that mean that in version 3.x hasdware transcoding was for all users, but in 4.x is only for premiums? Edited April 6, 2019 by juancarlos.castro
Luke 42244 Posted April 6, 2019 Author Posted April 6, 2019 Good morning, I wanted to take up the problem of transcoding in ubuntu with intel hardware, but I just saw this. Does that mean that in version 3.x hasdware transcoding was for all users, but in 4.x is only for premiums? Hi, yes, please see here: https://emby.media/community/index.php?/blog/1/entry-443-exciting-additions-coming-soon-in-emby-server-36/ Thanks.
nick114 1 Posted April 23, 2019 Posted April 23, 2019 (edited) hi guy i been trying to move some tv shows what emby have record to a never folder but it just keep saying that i am not the owner and it is saying that emby is the owner im running Ubuntu 18.04.2 LTS i do not now a lot a bout Ubuntu as i all ways worked with windows not Ubuntu all so any ways to make the live tv faster as it take 20s to play i now it not a lot of time but i all my over live tv apps dues it in 2s even your android mobile app play the live tv in like 3s i have been running this on the amazon fire tv stick gen2 and android box any help will be good thanks from nick Edited April 23, 2019 by nick114
hooray4me 52 Posted April 23, 2019 Posted April 23, 2019 I'm not sure how to do it from the GUI, but if you open up terminal and elevate your permissions... Terminal -> sudo -i then enter the root password. From here you can change directory to the one you are trying to move folders to/from the command to move a folder is mv /sourcefolder /destination IE) mv /home/rob/movies/Gumbi /mnt/movies/Gumbi What are you using for your source for live tv?
nick114 1 Posted April 23, 2019 Posted April 23, 2019 (edited) robrhedrick thanks for the help but i will just like to unlock any thing to do with emby as i can not add photo to any of the folders to do with emby all so my live tv is a custom kit i have 7 tv turner what running on tv mosaic it is then sent to my emby sever as a m3u as i tried the plugin but lost all my recording as i want emby sever to do the recording not tv mosaic all so i am all way recording so i now all of my 7 turner are set up right as tested with over apps it is all ways the emby tv apps what is not fast on live tv the phone app work fast never had a fault with that Edited April 23, 2019 by nick114
hooray4me 52 Posted April 23, 2019 Posted April 23, 2019 What is the brand of your tv tuners? the real "owner" of the emby related directories needs to be the emby user and the emby group. Then this emby "service account" will be able to read and write to the data directory on behalf of all your emby users. in a terminal window do the following command: sudo chown -R emby:emby /var/lib/emby-server then restart your emby-server service. sudo service emby-server restart enter your password when prompted. This should fix your image issue.
EODCrafter 181 Posted April 23, 2019 Posted April 23, 2019 (edited) Anybody install on a cloud based server? Considering purchasing cloud server access on www.ionos.com. What yall think? A Lot of IPTV Services are Blocking Cloud installs cause of all the Re-Streaming Businesses ($ hungry People without hacking skills) used to re-stream their Streams...Check with Provider if you Plan on having IPTV. Edited April 23, 2019 by EODCrafter
nick114 1 Posted April 23, 2019 Posted April 23, 2019 (edited) hi mate i have moved where my sever record it is not (/var/lib/emby) i moved it to /home/jump/Documents/west/tv shows i changed the setting on the sever bout 2 weeks a go so im moving videos in to the over files first i put sudo -i sudo chown -R emby:emby /var/lib/emby-server sudo service emby-server restart 2 time i put sudo -i studo clown -R emby:emby /home/jump/Documents/west/tv shows sudo service emby-server restart but no luck still all locked and will not let me cut the folders to move them or will not let me paste in them i am all so getting this see photo and can not get rid of it at all lol think i will go back to windows lol Edited April 23, 2019 by nick114
hooray4me 52 Posted April 23, 2019 Posted April 23, 2019 What your are paths and library paths in your emby admin panel? What is the path to the movie/recording folder you want to move from and where you want to move to?
nick114 1 Posted April 23, 2019 Posted April 23, 2019 (edited) hi mate my recording movies is /home/jump/Documents/west/movies and my recording tv shows are /home/jump/Documents/west/tv shows i will like to move any movies in to any over movie folders and what let me delete them as well as it is all locked so i can delete off the emby dash sever but it will not delete from my pc as they are locked to emby Edited April 23, 2019 by nick114
hooray4me 52 Posted April 23, 2019 Posted April 23, 2019 When you use terminal to get root access, then the root user has the permission necessary to move files and folders. so in terminal, elevate your access to root level by doing sudo -i then move the folders you want by doing: mv /source/path /destination/path so in your case if your old movies recording path was /home/jump/Documents/oldlocation/movies and your new movies path is /home/jump/Documents/west/movies... then your command to move all the movies would be: mv -v /home/jump/Documents/oldlocation/movies/* /home/jump/Documents/west/movies 1
nick114 1 Posted April 23, 2019 Posted April 23, 2019 (edited) hi mate it worked it let me move them but they are still locked but i think i can get around that now but just asking is there any way to take the lock off or is it to do with Ubuntu thanks mate a++++++++++++++++++++ Edited April 23, 2019 by nick114
