LeidenSpain 33 Posted November 15, 2018 Posted November 15, 2018 Thanks ! to me??? Thanks to you for emby, and for the support. I am already at home, so in a while install everything (before I'll see how ubuntu).
LeidenSpain 33 Posted November 15, 2018 Posted November 15, 2018 Hi, I'm installing lubuntu 18.04.1 LTS on my miniPC. for the moment, I've done a test on another computer, using windows. i7-8650 with UHD Graphics 620 IntelQuickSync OFF IntelQuickSync ON This is my reference's point.
LeidenSpain 33 Posted November 15, 2018 Posted November 15, 2018 OK Lubuntu installed, and the system don´t found the graphic card Intel have not support for 18.04, the I used the repositories again
sfatula 208 Posted November 15, 2018 Posted November 15, 2018 (edited) In the step where you showed vainfo, you should be installing not from a ppa, but the generic ubuntu package i965-va-driver, then retry the vainfo You can do this command from the command line to see if the UHD 600 is detected: lspci | grep VGA It would be unusual since Intel graphics drivers are all built into ubuntu to not detect it. If the above shows your card, try this too: lshw -C video *-display description: VGA compatible controller product: Intel Corporation vendor: Intel Corporation physical id: 2 bus info: pci@0000:00:02.0 version: 07 width: 64 bits clock: 33MHz capabilities: pciexpress msi pm vga_controller bus_master cap_list rom configuration: driver=i915 latency=0 resources: irq:128 memory:de000000-deffffff memory:c0000000-cfffffff ioport:f000(size=64) memory:c0000-dffff Edited November 15, 2018 by sfatula 1
LeidenSpain 33 Posted November 15, 2018 Posted November 15, 2018 In the step where you showed vainfo, you should be installing not from a ppa, but the generic ubuntu package i965-va-driver, then retry the vainfo You can do this command from the command line to see if the UHD 600 is detected: lspci | grep VGA It would be unusual since Intel graphics drivers are all built into ubuntu to not detect it. If the above shows your card, try this too: lshw -C video *-display description: VGA compatible controller product: Intel Corporation vendor: Intel Corporation physical id: 2 bus info: pci@0000:00:02.0 version: 07 width: 64 bits clock: 33MHz capabilities: pciexpress msi pm vga_controller bus_master cap_list rom configuration: driver=i915 latency=0 resources: irq:128 memory:de000000-deffffff memory:c0000000-cfffffff ioport:f000(size=64) memory:c0000-dffff indeed, in the capture of vainfo I had only installed vainfo. When I tried 18.10 yes that I detected the UHD600 directly. home-server@home-server:~$ lspci | grep VGA 00:02.0 VGA compatible controller: Intel Corporation Device 3185 (rev 03) home-server@home-server:~$ sudo lshw -C video *-display descripción: VGA compatible controller producto: Intel Corporation fabricante: Intel Corporation id físico: 2 información del bus: pci@0000:00:02.0 versión: 03 anchura: 64 bits reloj: 33MHz capacidades: pciexpress msi pm vga_controller bus_master cap_list rom configuración: driver=i915 latency=0 recursos: irq:127 memoria:a0000000-a0ffffff memoria:90000000-9fffffff ioport:f000(size=64) memoria:c0000-dffff Now, i install the package i965-va-driver-shaders from synaptic (This package contains also contains the non-free encode shaders for VP8, VP9, HEVC and AVC for generation 7.5 hardware a newer.) home-server@home-server:~$ vainfo libva info: VA-API version 1.1.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so libva info: Found init function __vaDriverInit_1_1 libva info: va_openDriver() returns 0 vainfo: VA-API version: 1.1 (libva 2.1.0) vainfo: Driver version: Intel i965 driver for Intel® Gemini Lake - 2.1.0 vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264ConstrainedBaseline: VAEntrypointEncSliceLP VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264Main : VAEntrypointEncSliceLP VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileH264High : VAEntrypointEncSliceLP VAProfileH264MultiviewHigh : VAEntrypointVLD VAProfileH264MultiviewHigh : VAEntrypointEncSlice VAProfileH264StereoHigh : VAEntrypointVLD VAProfileH264StereoHigh : VAEntrypointEncSlice VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc VAProfileJPEGBaseline : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointEncPicture VAProfileVP8Version0_3 : VAEntrypointVLD VAProfileVP8Version0_3 : VAEntrypointEncSlice VAProfileHEVCMain : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointEncSlice VAProfileHEVCMain10 : VAEntrypointVLD VAProfileHEVCMain10 : VAEntrypointEncSlice VAProfileVP9Profile0 : VAEntrypointVLD VAProfileVP9Profile0 : VAEntrypointEncSlice VAProfileVP9Profile2 : VAEntrypointVLD home-server@home-server:~$ lspci | grep VGA 00:02.0 VGA compatible controller: Intel Corporation Device 3185 (rev 03) home-server@home-server:~$ sudo lshw -C video *-display descripción: VGA compatible controller producto: Intel Corporation fabricante: Intel Corporation id físico: 2 información del bus: pci@0000:00:02.0 versión: 03 anchura: 64 bits reloj: 33MHz capacidades: pciexpress msi pm vga_controller bus_master cap_list rom configuración: driver=i915 latency=0 recursos: irq:127 memoria:a0000000-a0ffffff memoria:90000000-9fffffff ioport:f000(size=64) memoria:c0000-dffff FINE But..... some strange happends with the system detect and the intel-gpu-tools And now, I see the generic ubuntu package i965-va-driver it's not compatible with N4100 (Gemini Lake) This package contains the video decode and encode driver backend for the Intel G45 chipsets and Intel HD Graphics for the Intel Core processor family. The supported platforms include: * Cantiga, Intel GMA 4500MHD (GM45) * Ironlake, Intel HD Graphics for 2010 Intel Core processor family * Sandy Bridge, Intel HD Graphics for 2011 Intel Core processor family * Ivy Bridge * Haswell * Broadwell * Skylake * Kaby Lake * Coffee Lake * Cannon Lake
sfatula 208 Posted November 15, 2018 Posted November 15, 2018 (edited) Aha, so that is going to turn out to be your problem, it isn't supported by the i965. I suspected it wasn't emby. The names always confuse me, I don't always recall which name associates to which processor, yes, can look it up I know. This might be of some help: https://www.omgubuntu.co.uk/2018/06/mesa-18-1-1-ubuntu-18-04-ppa It says it's not in generic ubuntu yet (will be), but, the new version of Mesa improves support for Gemini Lake. Worth a shot. If you go down the road of other drivers, you might succeed, but, it's often a hard road. With the newer updated i965 driver, it says: Add support for Gemini Lake (aka. GLK) - Decoding: H.264/MPEG-2/VC-1/JPEG/VP8/HEVC/HEVC 10-bit/VP9/VP9 10-bit - Encoding: H.264/MPEG-2/JPEG/VP8/VP9/HEVC/HEVC 10-bit/AVC low power CQP mode - VPP: CSC/scaling/NoiseReduction/Deinterlacing{Bob, MotionAdaptive, MotionCompensated}/ColorBalance/STD Note the article is old, newer Mesa is available. Use this ppa to try: https://launchpad.net/~ubuntu-x-swat/+archive/ubuntu/updates You would want mesa 18.2.2 While not officially ubuntu supported per se, it's close. Hopefully, this might get you somewhere but the issue is your GPU is not supported at present in stock ubuntu. So, that's why emby was failing to accelerate. Edited November 15, 2018 by sfatula 1
LeidenSpain 33 Posted November 15, 2018 Posted November 15, 2018 (edited) Aha, so that is going to turn out to be your problem, it isn't supported by the i965. I suspected it wasn't emby. The names always confuse me, I don't always recall which name associates to which processor, yes, can look it up I know. This might be of some help: https://www.omgubuntu.co.uk/2018/06/mesa-18-1-1-ubuntu-18-04-ppa It says it's not in generic ubuntu yet (will be), but, the new version of Mesa improves support for Gemini Lake. Worth a shot. If you go down the road of other drivers, you might succeed, but, it's often a hard road. With the newer updated i965 driver, it says: Add support for Gemini Lake (aka. GLK) - Decoding: H.264/MPEG-2/VC-1/JPEG/VP8/HEVC/HEVC 10-bit/VP9/VP9 10-bit - Encoding: H.264/MPEG-2/JPEG/VP8/VP9/HEVC/HEVC 10-bit/AVC low power CQP mode - VPP: CSC/scaling/NoiseReduction/Deinterlacing{Bob, MotionAdaptive, MotionCompensated}/ColorBalance/STD Note the article is old, newer Mesa is available. Use this ppa to try: https://launchpad.net/~ubuntu-x-swat/+archive/ubuntu/updates You would want mesa 18.2.2 While not officially ubuntu supported per se, it's close. Hopefully, this might get you somewhere but the issue is your GPU is not supported at present in stock ubuntu. So, that's why emby was failing to accelerate. Hi, I think the problem is not the driver: remember that in my first installation, the lubuntu used the GPU to Hi I'm using emby 3.5.3.0 and Lubuntu 18.04.1 LTS over an Intel N4100 (GPU UHD600). This chip has hardware transcodification- First I used emby with windows and IntelQuickSync and I saw how the use of the GPU increased. But now I to use ubuntu, and I can not use transcoding with emby (but if it is used in the video player). This is my info And now playing a film I do not think that's the problem: in my first installation, ubuntu used the GPU to play video, using these drivers: https://launchpad.net/~oibaf/+archive/ubuntu/graphics-drivers I try with the mesa driver Edited November 15, 2018 by juancarlos.castro
LeidenSpain 33 Posted November 15, 2018 Posted November 15, 2018 (edited) The same: if I play the video directly on lubuntu, I see that the gnome-mpv player use the GPU. But the transcoding option on emby is disabled when emby try to do it UPS, mesa drivers have a very big problem: home-server@home-server:~$ vainfo libva info: VA-API version 1.1.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so libva info: va_openDriver() returns -1 vaInitialize failed with error code -1 (unknown libva error),exit And the same with the Oibaf Really, it's not a easy configuration Edited November 15, 2018 by juancarlos.castro
sfatula 208 Posted November 15, 2018 Posted November 15, 2018 Sounds like it. But the hardware is not fully supported either (I took the notes from the changelog of i965 mentioning Gemini Lake), I may be getting totally confused on all the variants you have tried, but, I thought your first config was with custom drivers? With my Intel 620, it was as simple as install xubuntu, install i965, add video group to emby user, works. You are comparing an mpv based player though, not the same thing that emby is using, your screen captures showed mpv as working, but the ffmpeg emby transcode as not working if I recall correctly. I wonder if you could run ffmpeg manually with the correct options and see if it will use gpu? That might be a good hint? I don't know if mpv uses the i965 driver or not. Don't know enough about it. 1
LeidenSpain 33 Posted November 15, 2018 Posted November 15, 2018 Sounds like it. But the hardware is not fully supported either (I took the notes from the changelog of i965 mentioning Gemini Lake), I may be getting totally confused on all the variants you have tried, but, I thought your first config was with custom drivers? With my Intel 620, it was as simple as install xubuntu, install i965, add video group to emby user, works. You are comparing an mpv based player though, not the same thing that emby is using, your screen captures showed mpv as working, but the ffmpeg emby transcode as not working if I recall correctly. I wonder if you could run ffmpeg manually with the correct options and see if it will use gpu? That might be a good hint? I don't know if mpv uses the i965 driver or not. Don't know enough about it. tell me how I can do the ffmpeg test. But now, it's too late. But before going to sleep, I found the official drivers from the web of intel https://01.org/linuxmedia https://github.com/intel/media-driver/ I try tomorrow Good night
sfatula 208 Posted November 16, 2018 Posted November 16, 2018 (edited) Yes, those are where Intel does it's thing in the Linux world. Those are the official intel drivers, which are unofficial from an ubuntu point of view. However, I would use them if needed and it sounds like you do! They have some interesting projects they have been working on over there for virtual machines and GPUs that I have been following for some time (GVT). The relevant doc for ffmpeg is here: https://trac.ffmpeg.org/wiki/HWAccelIntro I am not an ffmpeg command line person, someone else might be able to chime in, but from that page, appears that the option you need is -hwaccel. Usually, it's not much of a command, if I get a chance, I'll try and make one for a video later. Edited November 16, 2018 by sfatula 1
LeidenSpain 33 Posted November 16, 2018 Posted November 16, 2018 Yes, those are where Intel does it's thing in the Linux world. Those are the official intel drivers, which are unofficial from an ubuntu point of view. However, I would use them if needed and it sounds like you do! They have some interesting projects they have been working on over there for virtual machines and GPUs that I have been following for some time (GVT). The relevant doc for ffmpeg is here: https://trac.ffmpeg.org/wiki/HWAccelIntro I am not an ffmpeg command line person, someone else might be able to chime in, but from that page, appears that the option you need is -hwaccel. Usually, it's not much of a command, if I get a chance, I'll try and make one for a video later. HI someone said that emby does a VA-API test and if it gives an error it is disabled Is it possible to do that test in some way to see where the fault is? Regards
sfatula 208 Posted November 16, 2018 Posted November 16, 2018 (edited) I'd be curious of that also, but still, you need to do a simple ffmpeg test and see if it uses VAAPI, especially if MPV is working. I believe you don't need much, just input, output, and, the hwaccel flag If ffmpeg does not use vaapi, then, emby sure won't. If ffmpeg does use it on your system, then, it's not more intriguing as to why does emby not Edited November 16, 2018 by sfatula 1
LeidenSpain 33 Posted November 16, 2018 Posted November 16, 2018 I'd be curious of that also, but still, you need to do a simple ffmpeg test and see if it uses VAAPI, especially if MPV is working. I believe you don't need much, just input, output, and, the hwaccel flag If ffmpeg does not use vaapi, then, emby sure won't. If ffmpeg does use it on your system, then, it's not more intriguing as to why does emby not Would you know how I can do this test?
sfatula 208 Posted November 16, 2018 Posted November 16, 2018 ffmpeg -i 'Manifest S01E05 Connecting Flights.ts' -s 1280x720 -f null - The above will test without vaapi, monitor by your tool of choice to see how it behaves, replace video name with a correct path to some large video file ffmpeg -hwaccel vaapi -i 'Manifest S01E05 Connecting Flights.ts' -s 1280x720 -f null - That should give a different use of cpu/gpu I believe these will work good enough for a test of ffmpeg and vaapi, hopefully! Someone can correct if necessary. 1
LeidenSpain 33 Posted November 16, 2018 Posted November 16, 2018 ffmpeg -i 'Manifest S01E05 Connecting Flights.ts' -s 1280x720 -f null - The above will test without vaapi, monitor by your tool of choice to see how it behaves, replace video name with a correct path to some large video file ffmpeg -hwaccel vaapi -i 'Manifest S01E05 Connecting Flights.ts' -s 1280x720 -f null - That should give a different use of cpu/gpu I believe these will work good enough for a test of ffmpeg and vaapi, hopefully! Someone can correct if necessary. OK, I try home-server@home-server:~/Vídeos$ ffmpeg -i '001.mkv' -s 1280x720 -f null - ffmpeg version 4.0.3-1~18.04.york0 Copyright © 2000-2018 the FFmpeg developers built with gcc 7 (Ubuntu 7.3.0-27ubuntu1~18.04) configuration: --prefix=/usr --extra-version='1~18.04.york0' --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared libavutil 56. 14.100 / 56. 14.100 libavcodec 58. 18.100 / 58. 18.100 libavformat 58. 12.100 / 58. 12.100 libavdevice 58. 3.100 / 58. 3.100 libavfilter 7. 16.100 / 7. 16.100 libavresample 4. 0. 0 / 4. 0. 0 libswscale 5. 1.100 / 5. 1.100 libswresample 3. 1.100 / 3. 1.100 libpostproc 55. 1.100 / 55. 1.100 Input #0, matroska,webm, from '001.mkv': Metadata: encoder : libebml v1.3.6 + libmatroska v1.4.9 creation_time : 2018-09-17T19:00:02.000000Z Duration: 00:41:10.76, start: 0.000000, bitrate: 2078 kb/s Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 704x396 [sAR 1:1 DAR 16:9], 25 fps, 25 tbr, 1k tbn, 23.98 tbc (default) Metadata: BPS-eng : 1692668 DURATION-eng : 00:41:10.760000000 NUMBER_OF_FRAMES-eng: 61769 NUMBER_OF_BYTES-eng: 522772108 _STATISTICS_WRITING_APP-eng: mkvmerge v26.0.0 ('In The Game') 64-bit _STATISTICS_WRITING_DATE_UTC-eng: 2018-09-17 19:00:02 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:1(spa): Audio: mp3, 48000 Hz, stereo, fltp, 192 kb/s (default) Metadata: BPS-eng : 192000 DURATION-eng : 00:41:10.752000000 NUMBER_OF_FRAMES-eng: 102948 NUMBER_OF_BYTES-eng: 59298048 _STATISTICS_WRITING_APP-eng: mkvmerge v26.0.0 ('In The Game') 64-bit _STATISTICS_WRITING_DATE_UTC-eng: 2018-09-17 19:00:02 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:2(eng): Audio: mp3, 48000 Hz, stereo, fltp, 192 kb/s Metadata: BPS-eng : 192000 DURATION-eng : 00:41:10.752000000 NUMBER_OF_FRAMES-eng: 102948 NUMBER_OF_BYTES-eng: 59298048 _STATISTICS_WRITING_APP-eng: mkvmerge v26.0.0 ('In The Game') 64-bit _STATISTICS_WRITING_DATE_UTC-eng: 2018-09-17 19:00:02 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream mapping: Stream #0:0 -> #0:0 (mpeg4 (native) -> wrapped_avframe (native)) Stream #0:1 -> #0:1 (mp3 (mp3float) -> pcm_s16le (native)) Press [q] to stop, [?] for help Output #0, null, to 'pipe:': Metadata: encoder : Lavf58.12.100 Stream #0:0: Video: wrapped_avframe, yuv420p, 1280x720 [sAR 1:1 DAR 16:9], q=2-31, 200 kb/s, 25 fps, 25 tbn, 25 tbc (default) Metadata: BPS-eng : 1692668 DURATION-eng : 00:41:10.760000000 NUMBER_OF_FRAMES-eng: 61769 NUMBER_OF_BYTES-eng: 522772108 _STATISTICS_WRITING_APP-eng: mkvmerge v26.0.0 ('In The Game') 64-bit _STATISTICS_WRITING_DATE_UTC-eng: 2018-09-17 19:00:02 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES encoder : Lavc58.18.100 wrapped_avframe Stream #0:1(spa): Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s (default) Metadata: BPS-eng : 192000 DURATION-eng : 00:41:10.752000000 NUMBER_OF_FRAMES-eng: 102948 NUMBER_OF_BYTES-eng: 59298048 _STATISTICS_WRITING_APP-eng: mkvmerge v26.0.0 ('In The Game') 64-bit _STATISTICS_WRITING_DATE_UTC-eng: 2018-09-17 19:00:02 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES encoder : Lavc58.18.100 pcm_s16le frame=35112 fps=337 q=-0.0 size=N/A time=00:23:24.79 bitrate=N/A speed=13.5x And now, using "-hwaccel vaapi" home-server@home-server:~/Vídeos$ ffmpeg -hwaccel vaapi -i '001.mkv' -s 1280x720 -f null - ffmpeg version 4.0.3-1~18.04.york0 Copyright © 2000-2018 the FFmpeg developers built with gcc 7 (Ubuntu 7.3.0-27ubuntu1~18.04) configuration: --prefix=/usr --extra-version='1~18.04.york0' --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared libavutil 56. 14.100 / 56. 14.100 libavcodec 58. 18.100 / 58. 18.100 libavformat 58. 12.100 / 58. 12.100 libavdevice 58. 3.100 / 58. 3.100 libavfilter 7. 16.100 / 7. 16.100 libavresample 4. 0. 0 / 4. 0. 0 libswscale 5. 1.100 / 5. 1.100 libswresample 3. 1.100 / 3. 1.100 libpostproc 55. 1.100 / 55. 1.100 Input #0, matroska,webm, from '001.mkv': Metadata: encoder : libebml v1.3.6 + libmatroska v1.4.9 creation_time : 2018-09-17T19:00:02.000000Z Duration: 00:41:10.76, start: 0.000000, bitrate: 2078 kb/s Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 704x396 [sAR 1:1 DAR 16:9], 25 fps, 25 tbr, 1k tbn, 23.98 tbc (default) Metadata: BPS-eng : 1692668 DURATION-eng : 00:41:10.760000000 NUMBER_OF_FRAMES-eng: 61769 NUMBER_OF_BYTES-eng: 522772108 _STATISTICS_WRITING_APP-eng: mkvmerge v26.0.0 ('In The Game') 64-bit _STATISTICS_WRITING_DATE_UTC-eng: 2018-09-17 19:00:02 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:1(spa): Audio: mp3, 48000 Hz, stereo, fltp, 192 kb/s (default) Metadata: BPS-eng : 192000 DURATION-eng : 00:41:10.752000000 NUMBER_OF_FRAMES-eng: 102948 NUMBER_OF_BYTES-eng: 59298048 _STATISTICS_WRITING_APP-eng: mkvmerge v26.0.0 ('In The Game') 64-bit _STATISTICS_WRITING_DATE_UTC-eng: 2018-09-17 19:00:02 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:2(eng): Audio: mp3, 48000 Hz, stereo, fltp, 192 kb/s Metadata: BPS-eng : 192000 DURATION-eng : 00:41:10.752000000 NUMBER_OF_FRAMES-eng: 102948 NUMBER_OF_BYTES-eng: 59298048 _STATISTICS_WRITING_APP-eng: mkvmerge v26.0.0 ('In The Game') 64-bit _STATISTICS_WRITING_DATE_UTC-eng: 2018-09-17 19:00:02 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream mapping: Stream #0:0 -> #0:0 (mpeg4 (native) -> wrapped_avframe (native)) Stream #0:1 -> #0:1 (mp3 (mp3float) -> pcm_s16le (native)) Press [q] to stop, [?] for help [mpeg4 @ 0x55f6e933f600] No support for codec mpeg4 profile 15. [mpeg4 @ 0x55f6e933f600] Failed setup for format vaapi_vld: hwaccel initialisation returned error. Output #0, null, to 'pipe:': Metadata: encoder : Lavf58.12.100 Stream #0:0: Video: wrapped_avframe, yuv420p, 1280x720 [sAR 1:1 DAR 16:9], q=2-31, 200 kb/s, 25 fps, 25 tbn, 25 tbc (default) Metadata: BPS-eng : 1692668 DURATION-eng : 00:41:10.760000000 NUMBER_OF_FRAMES-eng: 61769 NUMBER_OF_BYTES-eng: 522772108 _STATISTICS_WRITING_APP-eng: mkvmerge v26.0.0 ('In The Game') 64-bit _STATISTICS_WRITING_DATE_UTC-eng: 2018-09-17 19:00:02 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES encoder : Lavc58.18.100 wrapped_avframe Stream #0:1(spa): Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s (default) Metadata: BPS-eng : 192000 DURATION-eng : 00:41:10.752000000 NUMBER_OF_FRAMES-eng: 102948 NUMBER_OF_BYTES-eng: 59298048 _STATISTICS_WRITING_APP-eng: mkvmerge v26.0.0 ('In The Game') 64-bit _STATISTICS_WRITING_DATE_UTC-eng: 2018-09-17 19:00:02 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES encoder : Lavc58.18.100 pcm_s16le frame=11584 fps=325 q=-0.0 size=N/A time=00:07:43.58 bitrate=N/A speed= 13x PERFECT, now I see the problem is on my system. Then, I must find the correct driver and configuration until you get to use the GPU in this way THANKS
sfatula 208 Posted November 16, 2018 Posted November 16, 2018 I see no difference in the 2 really, so, yep. 142% vs 137% at the moment each was captured, should be way different. About the same fps. It will always vary some. I guess that's "good" news, at least you should know when you get it working so you can retest emby. I was interested as I did not understand why your machine could be so difficult when mine was so easy. It has to be the CPU/GPU not being fully supported yet, at least by some of the tools, maybe not all. I think there should be a way to get that from the Intel site you located. 1
LeidenSpain 33 Posted November 16, 2018 Posted November 16, 2018 I see no difference in the 2 really, so, yep. 142% vs 137% at the moment each was captured, should be way different. About the same fps. It will always vary some. I guess that's "good" news, at least you should know when you get it working so you can retest emby. I was interested as I did not understand why your machine could be so difficult when mine was so easy. It has to be the CPU/GPU not being fully supported yet, at least by some of the tools, maybe not all. I think there should be a way to get that from the Intel site you located. I'm going to try installing Lubuntu 18.10 to see what happens.
sfatula 208 Posted November 16, 2018 Posted November 16, 2018 Be sure and post back! I don't see why Lubuntu should be any different than the other flavors as far as vaapi. 18.10 should have later versions at least of various libraries and drivers. I do want to hear your results. 1
Luke 42244 Posted November 16, 2018 Author Posted November 16, 2018 Since you're mentioning mpv, I'm having a hard time following what you guys are discussing. Emby Server does not use mpv, however, some of our apps do. If you are discussing Emby Server transcoding, then perhaps you might like to get involved with the changes in the beta channel. If so then you can participate here: https://emby.media/community/index.php?/topic/64534-36058-hardware-acceleration-settings/ Thanks guys. 1
LeidenSpain 33 Posted November 16, 2018 Posted November 16, 2018 Since you're mentioning mpv, I'm having a hard time following what you guys are discussing. Emby Server does not use mpv, however, some of our apps do. If you are discussing Emby Server transcoding, then perhaps you might like to get involved with the changes in the beta channel. If so then you can participate here: https://emby.media/community/index.php?/topic/64534-36058-hardware-acceleration-settings/ Thanks guys. I will be happy to help in any way I can. That if I notice that my knowledge is something basic, so I need to be guided.
sfatula 208 Posted November 16, 2018 Posted November 16, 2018 Since you're mentioning mpv, I'm having a hard time following what you guys are discussing. Emby Server does not use mpv, however, some of our apps do. If you are discussing Emby Server transcoding, then perhaps you might like to get involved with the changes in the beta channel. If so then you can participate here: https://emby.media/community/index.php?/topic/64534-36058-hardware-acceleration-settings/ Thanks guys. Summary: mpv came up as he was comparing emby not transcoding with another player transcoding, but that player used mpv so it was not the same thing. That lead him to believe that emby was messing up. But we just showed that ffmpeg will not use vaapi on his machine, so, now he's going to try and solve that.
LeidenSpain 33 Posted November 16, 2018 Posted November 16, 2018 Summary: mpv came up as he was comparing emby not transcoding with another player transcoding, but that player used mpv so it was not the same thing. That lead him to believe that emby was messing up. But we just showed that ffmpeg will not use vaapi on his machine, so, now he's going to try and solve that. correct The problem is the way used in my system with ffmpeg and VA-API. Emby works fine (in anothers computers )
LeidenSpain 33 Posted November 17, 2018 Posted November 17, 2018 OK, this is the actual situation: installed Lubuntu 18.10 update upgrade dist-upgrade The system don't recognice the GPU.....
