Luke 42243 Posted October 22, 2017 Author Posted October 22, 2017 Não consigo adicionar à minha série Servidor Emby, quando adiciono o tipo de conteúdo, como TV, adiciono a serie mas não aparece nada. I can not add to my Emby Server series when I added the content type such as TV by adding a series but nothing appears. Hi @@zod, can you please open a new community topic and discuss this a little more? We'd like to get more information about this. Thanks !
coringa 0 Posted October 24, 2017 Posted October 24, 2017 Não consigo adicionar à minha série Servidor Emby, quando adiciono o tipo de conteúdo, como TV, adiciono a serie mas não aparece nada. I can not add to my Emby Server series when I added the content type such as TV by adding a series but nothing appears. Alguém tem o mesmo problema? pois não to conseguindo adicionar minhas series
Luke 42243 Posted October 24, 2017 Author Posted October 24, 2017 Alguém tem o mesmo problema? pois não to conseguindo adicionar minhas series Continua aqui: https://emby.media/community/index.php?/topic/52132-problema-par-exibir-series/&do=findComment&comment=502529
Cortimi 0 Posted October 27, 2017 Posted October 27, 2017 Installation is not possible on Ubuntu 17.10.Using new default method from original post link:$ curl -f -s https://raw.githubusercontent.com/MediaBrowser/Emby.Releases/master/Server/setup.sh | sh Failed to stop emby-server.service: Unit emby-server.service not loaded.Failed to disable unit: Unit file emby-server.service does not exist.Installing requirementsHit:1 http://us.archive.ubuntu.com/ubuntu artful InRelease Get:2 http://us.archive.ubuntu.com/ubuntu artful-updates InRelease [76.7 kB] Hit:3 http://archive.canonical.com/ubuntu artful InRelease Get:4 http://security.ubuntu.com/ubuntu artful-security InRelease [70.3 kB] Hit:5 http://us.archive.ubuntu.com/ubuntu artful-backports InRelease Fetched 147 kB in 1s (143 kB/s) Reading package lists... DoneReading package lists... DoneBuilding dependency tree Reading state information... Donecurl is already the newest version (7.55.1-1ubuntu2.1).0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.Downloading Microsoft's GPG key to /etc/apt/trusted.gpg.d/microsoft.gpg % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed100 983 100 983 0 0 983 0 0:00:01 --:--:-- 0:00:01 1398Installing the Dotnet Core repository to /etc/apt/sources.list.d/dotnet.listInstalling Emby ServerGet:1 http://security.ubuntu.com/ubuntu artful-security InRelease [70.3 kB] Hit:2 http://us.archive.ubuntu.com/ubuntu artful InRelease Get:3 https://packages.microsoft.com/repos/microsoft-ubuntu-artful-prod artful InRelease [2,846 B] Hit:4 http://archive.canonical.com/ubuntu artful InRelease Get:5 http://us.archive.ubuntu.com/ubuntu artful-updates InRelease [76.7 kB] Get:6 https://packages.microsoft.com/repos/microsoft-ubuntu-artful-prod artful/main amd64 Packages [2,349 B] Hit:7 http://us.archive.ubuntu.com/ubuntu artful-backports InRelease Fetched 152 kB in 0s (223 kB/s) Reading package lists... Done % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed100 623 0 623 0 0 623 0 --:--:-- --:--:-- --:--:-- 1565100 18.9M 100 18.9M 0 0 2765k 0 0:00:07 0:00:07 --:--:-- 2840kSelecting previously unselected package emby-server.(Reading database ... 132741 files and directories currently installed.)Preparing to unpack emby-server-deb_3.2.34.0_amd64.deb ...Unpacking emby-server (3.2.34.0) ...dpkg: dependency problems prevent configuration of emby-server: emby-server depends on dotnet-runtime-2.0.0; however: Package dotnet-runtime-2.0.0 is not installed.dpkg: error processing package emby-server (--install): dependency problems - leaving unconfiguredProcessing triggers for libc-bin (2.26-0ubuntu2) ...Processing triggers for ureadahead (0.100.0-20) ...Errors were encountered while processing: emby-serverReading package lists... DoneBuilding dependency tree Reading state information... DoneCorrecting dependencies... DoneThe following additional packages will be installed: dotnet-host dotnet-hostfxr-2.0.0 dotnet-runtime-2.0.0 liblttng-ust-ctl2 liblttng-ust0 libunwind8 liburcu6The following NEW packages will be installed: dotnet-host dotnet-hostfxr-2.0.0 dotnet-runtime-2.0.0 liblttng-ust-ctl2 liblttng-ust0 libunwind8 liburcu60 upgraded, 7 newly installed, 0 to remove and 2 not upgraded.1 not fully installed or removed.Need to get 18.5 MB of archives.After this operation, 63.3 MB of additional disk space will be used.Do you want to continue? [Y/n] Abort.ERROR: Installation of Emby Server failedERROR: Please contact apps@ with the full output aboveAttempt with alternative sources:$ sudo sh -c "echo 'deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_17.04/ /' > /etc/apt/sources.list.d/emby-server.list" $ sudo apt-get updateHit:1 http://archive.canonical.com/ubuntu artful InRelease Hit:2 http://us.archive.ubuntu.com/ubuntu artful InRelease Get:3 http://us.archive.ubuntu.com/ubuntu artful-updates InRelease [76.7 kB] Get:4 http://security.ubuntu.com/ubuntu artful-security InRelease [70.3 kB] Hit:5 https://packages.microsoft.com/repos/microsoft-ubuntu-artful-prod artful InRelease Ign:6 http://download.opensuse.org/repositories/home:/emby/xUbuntu_17.04 InRelease Hit:7 http://us.archive.ubuntu.com/ubuntu artful-backports InRelease Get:8 http://download.opensuse.org/repositories/home:/emby/xUbuntu_17.04 Release [1,009 B] Get:9 http://download.opensuse.org/repositories/home:/emby/xUbuntu_17.04 Release.gpg [481 B] Ign:9 http://download.opensuse.org/repositories/home:/emby/xUbuntu_17.04 Release.gpg Reading package lists... Done W: GPG error: http://download.opensuse.org/repositories/home:/emby/xUbuntu_17.04 Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0A506F712A7D8A28 E: The repository 'http://download.opensuse.org/repositories/home:/emby/xUbuntu_17.04 Release' is not signed. N: Updating from such a repository can't be done securely, and is therefore disabled by default.N: See apt-secure(8) manpage for repository creation and user configuration details.$ sudo apt-get install emby-serverReading package lists... DoneBuilding dependency tree Reading state information... DoneE: Unable to locate package emby-server
Luke 42243 Posted October 27, 2017 Author Posted October 27, 2017 Installation is not possible on Ubuntu 17.10. Using new default method from original post link: $ curl -f -s https://raw.githubusercontent.com/MediaBrowser/Emby.Releases/master/Server/setup.sh | sh Failed to stop emby-server.service: Unit emby-server.service not loaded. Failed to disable unit: Unit file emby-server.service does not exist. Installing requirements Hit:1 http://us.archive.ubuntu.com/ubuntu artful InRelease Get:2 http://us.archive.ubuntu.com/ubuntu artful-updates InRelease [76.7 kB] Hit:3 http://archive.canonical.com/ubuntu artful InRelease Get:4 http://security.ubuntu.com/ubuntu artful-security InRelease [70.3 kB] Hit:5 http://us.archive.ubuntu.com/ubuntu artful-backports InRelease Fetched 147 kB in 1s (143 kB/s) Reading package lists... Done Reading package lists... Done Building dependency tree Reading state information... Done curl is already the newest version (7.55.1-1ubuntu2.1). 0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded. Downloading Microsoft's GPG key to /etc/apt/trusted.gpg.d/microsoft.gpg % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 983 100 983 0 0 983 0 0:00:01 --:--:-- 0:00:01 1398 Installing the Dotnet Core repository to /etc/apt/sources.list.d/dotnet.list Installing Emby Server Get:1 http://security.ubuntu.com/ubuntu artful-security InRelease [70.3 kB] Hit:2 http://us.archive.ubuntu.com/ubuntu artful InRelease Get:3 https://packages.microsoft.com/repos/microsoft-ubuntu-artful-prod artful InRelease [2,846 B] Hit:4 http://archive.canonical.com/ubuntu artful InRelease Get:5 http://us.archive.ubuntu.com/ubuntu artful-updates InRelease [76.7 kB] Get:6 https://packages.microsoft.com/repos/microsoft-ubuntu-artful-prod artful/main amd64 Packages [2,349 B] Hit:7 http://us.archive.ubuntu.com/ubuntu artful-backports InRelease Fetched 152 kB in 0s (223 kB/s) Reading package lists... Done % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 623 0 623 0 0 623 0 --:--:-- --:--:-- --:--:-- 1565 100 18.9M 100 18.9M 0 0 2765k 0 0:00:07 0:00:07 --:--:-- 2840k Selecting previously unselected package emby-server. (Reading database ... 132741 files and directories currently installed.) Preparing to unpack emby-server-deb_3.2.34.0_amd64.deb ... Unpacking emby-server (3.2.34.0) ... dpkg: dependency problems prevent configuration of emby-server: emby-server depends on dotnet-runtime-2.0.0; however: Package dotnet-runtime-2.0.0 is not installed. dpkg: error processing package emby-server (--install): dependency problems - leaving unconfigured Processing triggers for libc-bin (2.26-0ubuntu2) ... Processing triggers for ureadahead (0.100.0-20) ... Errors were encountered while processing: emby-server Reading package lists... Done Building dependency tree Reading state information... Done Correcting dependencies... Done The following additional packages will be installed: dotnet-host dotnet-hostfxr-2.0.0 dotnet-runtime-2.0.0 liblttng-ust-ctl2 liblttng-ust0 libunwind8 liburcu6 The following NEW packages will be installed: dotnet-host dotnet-hostfxr-2.0.0 dotnet-runtime-2.0.0 liblttng-ust-ctl2 liblttng-ust0 libunwind8 liburcu6 0 upgraded, 7 newly installed, 0 to remove and 2 not upgraded. 1 not fully installed or removed. Need to get 18.5 MB of archives. After this operation, 63.3 MB of additional disk space will be used. Do you want to continue? [Y/n] Abort. ERROR: Installation of Emby Server failed ERROR: Please contact apps@ with the full output above Attempt with alternative sources: $ sudo sh -c "echo 'deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_17.04/ /' > /etc/apt/sources.list.d/emby-server.list" $ sudo apt-get update Hit:1 http://archive.canonical.com/ubuntu artful InRelease Hit:2 http://us.archive.ubuntu.com/ubuntu artful InRelease Get:3 http://us.archive.ubuntu.com/ubuntu artful-updates InRelease [76.7 kB] Get:4 http://security.ubuntu.com/ubuntu artful-security InRelease [70.3 kB] Hit:5 https://packages.microsoft.com/repos/microsoft-ubuntu-artful-prod artful InRelease Ign:6 http://download.opensuse.org/repositories/home:/emby/xUbuntu_17.04 InRelease Hit:7 http://us.archive.ubuntu.com/ubuntu artful-backports InRelease Get:8 http://download.opensuse.org/repositories/home:/emby/xUbuntu_17.04 Release [1,009 B] Get:9 http://download.opensuse.org/repositories/home:/emby/xUbuntu_17.04 Release.gpg [481 B] Ign:9 http://download.opensuse.org/repositories/home:/emby/xUbuntu_17.04 Release.gpg Reading package lists... Done W: GPG error: http://download.opensuse.org/repositories/home:/emby/xUbuntu_17.04 Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0A506F712A7D8A28 E: The repository 'http://download.opensuse.org/repositories/home:/emby/xUbuntu_17.04 Release' is not signed. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. $ sudo apt-get install emby-server Reading package lists... Done Building dependency tree Reading state information... Done E: Unable to locate package emby-server Duplicate of: https://emby.media/community/index.php?/topic/52273-cannot-install-on-ubuntu-1710/
coringa 0 Posted October 30, 2017 Posted October 30, 2017 Senhores, boa noite. Atualizei minha versão do emby para Versão 3.2.35.0, desde de então o sistema se tornou inutilizavel para mim, não sei o que aconteceu, mas ele parou de funcionar, meus arquivos aparecem na biblioteca porem na home inicial nada mais aparece, não consigo mais assistir nem adicionar nada, alguém esta com esse mesmo problema ? Tudo depois da ultima atualização, ajuda Foto da minha biblioteca Fotos da minha home
Luke 42243 Posted October 30, 2017 Author Posted October 30, 2017 Oi, você tentou executar uma varredura da biblioteca? obrigado.
coringa 0 Posted October 30, 2017 Posted October 30, 2017 Oi, você tentou executar uma varredura da biblioteca? obrigado. Sim, tentei fazer isso , porém o mesmo não efetua, ele mostra como se fosse iniciar a fazer a varredura porem ele não demora nenhum segundo no rastreio e para.
coringa 0 Posted October 30, 2017 Posted October 30, 2017 Sim, tentei fazer isso, no entanto, não efetua, ele mostra como se fosse iniciar uma verificação porem ele não demora nenhum segundo e e para o rastreio.
tlgcntn 0 Posted October 31, 2017 Posted October 31, 2017 Hello everyone,Thanks for this awesome work. I'm using emby media server for last one week at my home. I noticed there is a new version of Emby. I'm using 3.2.34.0 version on Ubuntu. Here is my Linux specs: tlgcntn@bluebird:~$ hostnamectl Static hostname: bluebird Icon name: computer-laptop Chassis: laptop Machine ID: *** Boot ID: *** Operating System: Ubuntu 16.04.3 LTS Kernel: Linux 4.4.0-97-generic Architecture: x86 I'm using x86 (32bit) architecture as you can see. When I check download page, I didn't see any v3.2.35 32bit package for Ubuntu on new download page -> https://emby.media/linux-server.html Is this mean, we can't get a new 32bit versions anymore?
Luke 42243 Posted October 31, 2017 Author Posted October 31, 2017 Hello everyone, Thanks for this awesome work. I'm using emby media server for last one week at my home. I noticed there is a new version of Emby. I'm using 3.2.34.0 version on Ubuntu. Here is my Linux specs: tlgcntn@bluebird:~$ hostnamectl Static hostname: bluebird Icon name: computer-laptop Chassis: laptop Machine ID: *** Boot ID: *** Operating System: Ubuntu 16.04.3 LTS Kernel: Linux 4.4.0-97-generic Architecture: x86 I'm using x86 (32bit) architecture as you can see. When I check download page, I didn't see any v3.2.35 32bit package for Ubuntu on new download page -> https://emby.media/linux-server.html Is this mean, we can't get a new 32bit versions anymore? You can get it by following the same instructions as the ARM architecture.
tlgcntn 0 Posted November 1, 2017 Posted November 1, 2017 Thank you so much. I just updated via this command: sudo apt-get dist-upgrade
Mytico 0 Posted November 1, 2017 Posted November 1, 2017 Thank you so much. I just updated via this command: sudo apt-get dist-upgrade Thanks
schmitty 66 Posted November 4, 2017 Posted November 4, 2017 (edited) I just installed the latest update on Ubuntu 16.04, and the service won't start. It's throwing the below error. daniel@ubuntu-server:~$ systemctl status emby-server.service ● emby-server.service - Emby Server is a personal media server with apps on just about every device. Loaded: loaded (/usr/lib/systemd/system/emby-server.service; enabled; vendor preset: enabled) Active: inactive (dead) (Result: core-dump) since Sat 2017-11-04 23:46:15 AEDT; 8s ago Process: 7415 ExecStart=/opt/emby-server/bin/emby-server (code=dumped, signal=ABRT) Main PID: 7415 (code=dumped, signal=ABRT) Nov 04 23:46:15 ubuntu-server systemd[1]: emby-server.service: Unit entered failed state. Nov 04 23:46:15 ubuntu-server systemd[1]: emby-server.service: Failed with result 'core-dump'. Nov 04 23:46:15 ubuntu-server systemd[1]: emby-server.service: Service hold-off time over, scheduling restart. Nov 04 23:46:15 ubuntu-server systemd[1]: Stopped Emby Server is a personal media server with apps on just about every device.. Nov 04 23:46:15 ubuntu-server systemd[1]: emby-server.service: Start request repeated too quickly. Nov 04 23:46:15 ubuntu-server systemd[1]: Failed to start Emby Server is a personal media server with apps on just about every device.. daniel@ubuntu-server:~$ Edited November 4, 2017 by schmitty
schmitty 66 Posted November 4, 2017 Posted November 4, 2017 (edited) I just installed the latest update on Ubuntu 16.04, and the service won't start. It's throwing the below error. daniel@ubuntu-server:~$ systemctl status emby-server.service ● emby-server.service - Emby Server is a personal media server with apps on just about every device. Loaded: loaded (/usr/lib/systemd/system/emby-server.service; enabled; vendor preset: enabled) Active: inactive (dead) (Result: core-dump) since Sat 2017-11-04 23:46:15 AEDT; 8s ago Process: 7415 ExecStart=/opt/emby-server/bin/emby-server (code=dumped, signal=ABRT) Main PID: 7415 (code=dumped, signal=ABRT) Nov 04 23:46:15 ubuntu-server systemd[1]: emby-server.service: Unit entered failed state. Nov 04 23:46:15 ubuntu-server systemd[1]: emby-server.service: Failed with result 'core-dump'. Nov 04 23:46:15 ubuntu-server systemd[1]: emby-server.service: Service hold-off time over, scheduling restart. Nov 04 23:46:15 ubuntu-server systemd[1]: Stopped Emby Server is a personal media server with apps on just about every device.. Nov 04 23:46:15 ubuntu-server systemd[1]: emby-server.service: Start request repeated too quickly. Nov 04 23:46:15 ubuntu-server systemd[1]: Failed to start Emby Server is a personal media server with apps on just about every device.. daniel@ubuntu-server:~$ Never mind. I restarted the system and installed system updates, and it is now working. I have lost my library though. Edited November 4, 2017 by schmitty
Luke 42243 Posted November 4, 2017 Author Posted November 4, 2017 Try running a library scan. Thanks.
francisuk1989 4 Posted November 7, 2017 Posted November 7, 2017 (edited) I have installed a fresh of emby server beta on 16.04.3 x64 but when changing the HTTP/HTTPS ports i get this error, It also happens on the stable 3.2.34 release. 2017-11-07 21:22:46.801 Info ServerManager: Loading Http Server2017-11-07 21:22:46.801 Info HttpServer: Adding HttpListener prefix http://+:8096/ < should be 36352017-11-07 21:22:46.801 Info HttpServer: Adding HttpListener prefix https://+:1011/when visiting http://192.168.1.252:8096 and port https://:1011 on both ports i get Unable to connect same with port 3635 EDIT Using this methord works but is running emby as root i guess? is there anyway to change this for user emby? https://emby.media/community/index.php?/topic/26818-error-changing-ports/&do=findComment&comment=261257 server-63645686565.txt unhandled_83bdde99-de8f-43e1-9ebc-9d29cf8d4332.txt Edited November 7, 2017 by francisuk1989
Luke 42243 Posted November 7, 2017 Author Posted November 7, 2017 It appears your system is not allowing access to those ports. That's all i can really tell you. The reason it reverts back to 8096 is because we do that automatically if we get an error when trying to bind to the custom port of your choice.
francisuk1989 4 Posted November 7, 2017 Posted November 7, 2017 It appears your system is not allowing access to those ports. That's all i can really tell you. The reason it reverts back to 8096 is because we do that automatically if we get an error when trying to bind to the custom port of your choice. but even reverting back to 8096 dosnt work but using this methord works https://emby.media/community/index.php?/topic/26818-error-changing-ports/&do=findComment&comment=261257 but using root account but is there a way of emby user to use say HTTP 3535 HTTPS 3536
Luke 42243 Posted December 1, 2017 Author Posted December 1, 2017 Great news everyone. We now have .NET Core-based armhf .deb downloads ready for testing. If you'd like to try them out please see here: https://emby.media/community/index.php?/topic/50012-emby-server-for-net-core/ Thanks !
nicox 2 Posted December 8, 2017 Posted December 8, 2017 (edited) Hello, When i try to install Emby on Ubuntu 16.04 I got an error. I've downloaded the .deb and try to install it : emby@Emby-Server:~$ sudo dpkg -i emby-server-deb_3.2.50.0_amd64.deb (Lecture de la base de données... 61807 fichiers et répertoires déjà installés.) Préparation du dépaquetage de emby-server-deb_3.2.50.0_amd64.deb ... Dépaquetage de emby-server (3.2.50.0) sur (3.2.50.0) ... Paramétrage de emby-server (3.2.50.0) ... usermod: user emby is currently used by process 1163 dpkg: erreur de traitement du paquet emby-server (--install) : le sous-processus script post-installation installé a retourné une erreur de sortie d'état 8 Traitement des actions différées (« triggers ») pour libc-bin (2.23-0ubuntu9) ... Traitement des actions différées (« triggers ») pour ureadahead (0.100.0-19) ... Des erreurs ont été rencontrées pendant l'exécution : emby-server It says "Error output 8", what does it means ? It's a fresh ubuntu with a user named emby, is it the problem (I have to use a different name) ? Thank you. Edit : I tried with a different username, did the trick. May be usefull to indicate it somewhere (As my vm was for emby, I use emby for username, not clever I know). Edited December 8, 2017 by nicox
Luke 42243 Posted December 9, 2017 Author Posted December 9, 2017 Glad to see you figured it out. Thanks !
Turboschnecke 2 Posted January 18, 2018 Posted January 18, 2018 (edited) Hi, i try to install emby within an Ubuntu 16.04 in a LX Zone on a OmniOS machine. But it doesn't work: Unpacking emby-server (3.2.60.0) ... Setting up emby-server (3.2.60.0) ... Failed to connect to bus: No such file or directory dpkg: error processing package emby-server (--install): subprocess installed post-installation script returned error exit status 1 Processing triggers for libc-bin (2.23-0ubuntu10) ... Processing triggers for unreadahed (0.100.0-19) ... Error were encountered while processing: emby-server I search for this error and found a post about a not working systemd. Could this be the problem? Is there a possibility to install emby server an other way? i already did apt-get update and upgrade. I am a linux noob Edited January 18, 2018 by Turboschnecke
Luke 42243 Posted January 18, 2018 Author Posted January 18, 2018 Hi, what about the Docker installation? Does OmniOS support Docker?
