ksar 0 Posted January 31, 2017 Posted January 31, 2017 Please provide the Emby Server log from this. Thanks. Dear Luke, If FFmpeg is not installed before emby, the emby server crash without any logs...
Luke 42243 Posted January 31, 2017 Author Posted January 31, 2017 Dear Luke, If FFmpeg is not installed before emby, the emby server crash without any logs... The startup wizard will give you a chance to configure it.
PlayNice 0 Posted January 31, 2017 Posted January 31, 2017 Hi guys im trying to install ffmpeg on ubuntu serevr 16.04 im getting this erroe each time and i cant find the correct dependencies for this Welcome to Ubuntu 16.04.1 LTS (GNU/Linux 4.4.0-21-generic x86_64) E: Package 'ffmpeg' has no installation candidate root@3:~# sudo gedit /etc/apt/sources.list sudo: gedit: command not found root@3:~# root@3:~#
Jdiesel 1435 Posted January 31, 2017 Posted January 31, 2017 Hi guys im trying to install ffmpeg on ubuntu serevr 16.04 im getting this erroe each time and i cant find the correct dependencies for this Welcome to Ubuntu 16.04.1 LTS (GNU/Linux 4.4.0-21-generic x86_64) E: Package 'ffmpeg' has no installation candidate root@3:~# sudo gedit /etc/apt/sources.list sudo: gedit: command not found root@3:~# root@3:~# Does Ubuntu 16.04 not come with ffmpeg 2.8.10 installed by default? I know that I've never needed to install it manually to use Emby. What is the output when you run "ffmpeg" in the terminal? 1
thatoneguy99 33 Posted January 31, 2017 Posted January 31, 2017 I've never had to do it manually either. You could also type "which ffmpeg" to get an idea of where it resides. Sent from my iPhone using Tapatalk
Guest plexman Posted February 2, 2017 Posted February 2, 2017 Hi guys im trying to install ffmpeg on ubuntu serevr 16.04 im getting this erroe each time and i cant find the correct dependencies for this Welcome to Ubuntu 16.04.1 LTS (GNU/Linux 4.4.0-21-generic x86_64) E: Package 'ffmpeg' has no installation candidate root@3:~# sudo gedit /etc/apt/sources.list sudo: gedit: command not found root@3:~# root@3:~# Just: sudo apt-get update sudo apt-get install ffmpeg If not, then: sudo add-apt-repository ppa:jonathonf/ffmpeg-3 sudo apt-get update sudo apt-get install ffmpeg
Jdiesel 1435 Posted February 2, 2017 Posted February 2, 2017 (edited) Just: sudo apt-get update sudo apt-get install ffmpeg If not, then: sudo add-apt-repository ppa:jonathonf/ffmpeg-3 sudo apt-get update sudo apt-get install ffmpeg Unless things have changed you do not want to install ffmpeg 3.2 from that repository as ffmpeg 3.2 was causing lots of issues with transcoding. Ubuntu 16.04 comes with ffmpeg 2.8 by default which works well with Emby. Edited February 2, 2017 by Jdiesel
ksar 0 Posted February 4, 2017 Posted February 4, 2017 Unless things have changed you do not want to install ffmpeg 3.2 from that repository as ffmpeg 3.2 was causing lots of issues with transcoding. Ubuntu 16.04 comes with ffmpeg 2.8 by default which works well with Emby. For me it is the opposit : ffmpeg 3.2 works well and 2.8 creates a lot of issues on transcoding. Ubunutu 16.04
PlayNice 0 Posted February 6, 2017 Posted February 6, 2017 apt-get install --only-upgrade emby-server this command will not upgrade emby is there an alternative command i can use guys
thatoneguy99 33 Posted February 6, 2017 Posted February 6, 2017 (edited) Try sudo apt update. Then sudo apt upgrade. If that doesn't work try sudo apt-get dist-upgrade. Edit- I messed that all up. Fixed now. Sent from my phone! Edited February 6, 2017 by thatoneguy99
Driesner 0 Posted February 18, 2017 Posted February 18, 2017 (edited) OK, this time I get slowly impatient with emby... So I tried to update again and ran only into issue... finally I got clean from the emby-service and all and want now to install again from scratch. I am running Ubuntu 16.04 and used the instructions: sudo sh -c "echo 'deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04/ /' > /etc/apt/sources.list.d/emby-server.list" sudo apt-get update sudo apt-get install emby-server but already when I do the apt-get update I get the following issue: Get:10 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04 Release [1,009 B] Err:11 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04 Release.gpg Bad header line Bad header data [IP: 195.135.221.134 80] Hit:12 http://ppa.launchpad.net/numix/ppa/ubuntu xenial InRelease Hit:13 https://deb.opera.com/opera-stable stable InRelease Get:14 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04 Packages [35.9 kB] Hit:15 http://ppa.launchpad.net/tista/adapta/ubuntu xenial InRelease Fetched 241 kB in 7s (30.6 kB/s) Reading package lists... Done W: The repository 'http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04 Release' is not signed. N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use. N: See apt-secure(8) manpage for repository creation and user configuration details. E: Failed to fetch http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04/Release.gpg Bad header line Bad header data [IP: 195.135.221.134 80] Of course when I then try to run apt-get install emby-server I get: E: Unable to locate package emby-server Getting a bit frustrated here as there seems to be always issues when trying to update, last time I somehow had a dev version that didnt want to update and now this... I start to wonder if it was really worth to pay for this Edited February 18, 2017 by Driesner
Phezz 0 Posted February 18, 2017 Posted February 18, 2017 Ubuntu 16.04 emby-server is not installable. - 16.04 emby-server specifically requires the emby repository's version of mono-devel (4.6, while 4.2 is installed from Ubuntu repo) - the emby repository's version of mono requires libc 2.24 - libc 2.24 is not available, 2.23 is installed. user@Host:~$ sudo apt install emby-server Reading package lists... DoneBuilding dependency tree Reading state information... DoneSome packages could not be installed. This may mean that you haverequested an impossible situation or if you are using the unstabledistribution that some required packages have not yet been createdor been moved out of Incoming.The following information may help to resolve the situation:The following packages have unmet dependencies:emby-server : Depends: libc6 (>= 2.24) but 2.23-0ubuntu5 is to be installed or libc6.1 (>= 2.24) but it is not installable or libc0.1 (>= 2.24) but it is not installable Depends: libmono-microsoft-csharp4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-posix4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-core4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-data4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-drawing4.0-cil (>= 3.0.6) but it is not going to be installed Depends: libmono-system-io-compression4.0-cil (>= 3.2.1) but it is not going to be installed Depends: libmono-system-net-http4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-system-runtime-serialization4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-servicemodel4.0a-cil (>= 3.2.3) but it is not going to be installed Depends: libmono-system-xml-linq4.0-cil (>= 3.0.6) but it is not going to be installed Depends: mono-devel (>= 4.6) but it is not going to be installedE: Unable to correct problems, you have held broken packages. user@Host:~$ dpkg --list |grep mono ii ca-certificates-mono 4.2.1.102+dfsg2-7ubuntu4 all Common CA certificates (Mono keystore)ii fonts-noto-mono 20160116-1 all "No Tofu" monospaced font family with large Unicode coverage ii fonts-tlwg-mono 1:0.6.2-2.1 all Thai TlwgMono font (dependency package)ii fonts-tlwg-mono-ttf 1:0.6.2-2.1 all Thai TlwgMono TrueType fontii libmono-corlib4.5-cil 4.2.1.102+dfsg2-7ubuntu4 all Mono core library (for CLI 4.5)ii libmono-i18n-west4.0-cil 4.2.1.102+dfsg2-7ubuntu4 all Mono I18N.West library (for CLI 4.0)ii libmono-i18n4.0-cil 4.2.1.102+dfsg2-7ubuntu4 all Mono I18N base library (for CLI 4.0)ii libmono-security4.0-cil 4.2.1.102+dfsg2-7ubuntu4 all Mono Security library (for CLI 4.0)ii libmono-system-configuration4.0-cil 4.2.1.102+dfsg2-7ubuntu4 all Mono System.Configuration library (for CLI 4.0)ii libmono-system-security4.0-cil 4.2.1.102+dfsg2-7ubuntu4 all Mono System.Security library (for CLI 4.0)ii libmono-system-xml4.0-cil 4.2.1.102+dfsg2-7ubuntu4 all Mono System.Xml library (for CLI 4.0)ii libmono-system4.0-cil 4.2.1.102+dfsg2-7ubuntu4 all Mono System libraries (for CLI 4.0)ii mono-4.0-gac 4.2.1.102+dfsg2-7ubuntu4 all Mono GAC tool (for CLI 4.0)ii mono-gac 4.2.1.102+dfsg2-7ubuntu4 all Mono GAC toolii mono-runtime 4.2.1.102+dfsg2-7ubuntu4 amd64 Mono runtime - default versionii mono-runtime-common 4.2.1.102+dfsg2-7ubuntu4 amd64 Mono runtime - common filesii mono-runtime-sgen 4.2.1.102+dfsg2-7ubuntu4 amd64 Mono runtime - SGenii ubuntu-mono 14.04+16.04.20161024-0ubuntu1 all Ubuntu Mono Icon themeuser@Host:~$ cat /etc/apt/sources.list.d/emby.list deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10/ /
thatoneguy99 33 Posted February 18, 2017 Posted February 18, 2017 A un recommended possible solution would be to install mono-complete. sudo apt install mono-complete Sent from my phone!
hurricanehrndz 149 Posted February 19, 2017 Posted February 19, 2017 Ubuntu 16.04 emby-server is not installable. - 16.04 emby-server specifically requires the emby repository's version of mono-devel (4.6, while 4.2 is installed from Ubuntu repo) - the emby repository's version of mono requires libc 2.24 - libc 2.24 is not available, 2.23 is installed. user@Host:~$ sudo apt install emby-server Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: emby-server : Depends: libc6 (>= 2.24) but 2.23-0ubuntu5 is to be installed or libc6.1 (>= 2.24) but it is not installable or libc0.1 (>= 2.24) but it is not installable Depends: libmono-microsoft-csharp4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-posix4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-core4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-data4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-drawing4.0-cil (>= 3.0.6) but it is not going to be installed Depends: libmono-system-io-compression4.0-cil (>= 3.2.1) but it is not going to be installed Depends: libmono-system-net-http4.0-cil (>= 1.0) but it is not going to be installed Depends: libmono-system-runtime-serialization4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed Depends: libmono-system-servicemodel4.0a-cil (>= 3.2.3) but it is not going to be installed Depends: libmono-system-xml-linq4.0-cil (>= 3.0.6) but it is not going to be installed Depends: mono-devel (>= 4.6) but it is not going to be installed E: Unable to correct problems, you have held broken packages. user@Host:~$ dpkg --list |grep mono ii ca-certificates-mono 4.2.1.102+dfsg2-7ubuntu4 all Common CA certificates (Mono keystore) ii fonts-noto-mono 20160116-1 all "No Tofu" monospaced font family with large Unicode coverage ii fonts-tlwg-mono 1:0.6.2-2.1 all Thai TlwgMono font (dependency package) ii fonts-tlwg-mono-ttf 1:0.6.2-2.1 all Thai TlwgMono TrueType font ii libmono-corlib4.5-cil 4.2.1.102+dfsg2-7ubuntu4 all Mono core library (for CLI 4.5) ii libmono-i18n-west4.0-cil 4.2.1.102+dfsg2-7ubuntu4 all Mono I18N.West library (for CLI 4.0) ii libmono-i18n4.0-cil 4.2.1.102+dfsg2-7ubuntu4 all Mono I18N base library (for CLI 4.0) ii libmono-security4.0-cil 4.2.1.102+dfsg2-7ubuntu4 all Mono Security library (for CLI 4.0) ii libmono-system-configuration4.0-cil 4.2.1.102+dfsg2-7ubuntu4 all Mono System.Configuration library (for CLI 4.0) ii libmono-system-security4.0-cil 4.2.1.102+dfsg2-7ubuntu4 all Mono System.Security library (for CLI 4.0) ii libmono-system-xml4.0-cil 4.2.1.102+dfsg2-7ubuntu4 all Mono System.Xml library (for CLI 4.0) ii libmono-system4.0-cil 4.2.1.102+dfsg2-7ubuntu4 all Mono System libraries (for CLI 4.0) ii mono-4.0-gac 4.2.1.102+dfsg2-7ubuntu4 all Mono GAC tool (for CLI 4.0) ii mono-gac 4.2.1.102+dfsg2-7ubuntu4 all Mono GAC tool ii mono-runtime 4.2.1.102+dfsg2-7ubuntu4 amd64 Mono runtime - default version ii mono-runtime-common 4.2.1.102+dfsg2-7ubuntu4 amd64 Mono runtime - common files ii mono-runtime-sgen 4.2.1.102+dfsg2-7ubuntu4 amd64 Mono runtime - SGen ii ubuntu-mono 14.04+16.04.20161024-0ubuntu1 all Ubuntu Mono Icon theme user@Host:~$ cat /etc/apt/sources.list.d/emby.list deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10/ / @@Phezz Perhaps using the right repo for your distribution would solve your issue. Try the 16.04 repo instead of the 16.10 repo. Please let us know if this helps. Thanks ! Sent from my ONEPLUS A3000 using Tapatalk
Driesner 0 Posted February 20, 2017 Posted February 20, 2017 @@Phezz Perhaps using the right repo for your distribution would solve your issue. Try the 16.04 repo instead of the 16.10 repo. Please let us know if this helps. Thanks ! Sent from my ONEPLUS A3000 using Tapatalk And that is what totally fails for me due to W: The repository 'http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04 Release' is not signed. N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
hurricanehrndz 149 Posted February 20, 2017 Posted February 20, 2017 Perhaps following the instructions about adding the key would solve that issue. Sent from my ONEPLUS A3000 using Tapatalk
hurricanehrndz 149 Posted February 20, 2017 Posted February 20, 2017 Ps the instructions to install the key so that the repository is trusted is right below the instructions on how to add the repo. Please report back once your issue has been resolved Sent from my ONEPLUS A3000 using Tapatalk
Luke 42243 Posted February 20, 2017 Author Posted February 20, 2017 Just to clarify, the download page on our website will always have the most up to date installation instructions: https://emby.media/linux-server.html Currently, when you click Ubuntu, it will link you to our open build service and will provide the exact instructions. Let us know if this helps. Thanks !
Driesner 0 Posted February 20, 2017 Posted February 20, 2017 Adding the key , which I did before of course already does not help at all: user@ubuntu1:~$ wget http://download.opensuse.org/repositories/home:emby/xUbuntu_16.04/Release.key --2017-02-20 13:55:30-- http://download.opensuse.org/repositories/home:emby/xUbuntu_16.04/Release.key Resolving download.opensuse.org (download.opensuse.org)... 195.135.221.134, 2001:67c:2178:8::13 Connecting to download.opensuse.org (download.opensuse.org)|195.135.221.134|:80... connected. HTTP request sent, awaiting response... 301 Moved Permanently Location: http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04/Release.key [following] --2017-02-20 13:55:31-- http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04/Release.key Reusing existing connection to download.opensuse.org:80. HTTP request sent, awaiting response... Read error (Connection reset by peer) in headers. Retrying. --2017-02-20 13:55:32-- (try: 2) http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04/Release.key Connecting to download.opensuse.org (download.opensuse.org)|195.135.221.134|:80... connected. HTTP request sent, awaiting response... 200 OK Length: 1089 (1.1K) [application/pgp-keys] Saving to: ‘Release.key’ Release.key 100%[================================================>] 1.06K --.-KB/s in 0s 2017-02-20 13:55:32 (130 MB/s) - ‘Release.key’ saved [1089/1089] user@ubuntu1:~$ sudo apt-key add - < Release.key OK user@ubuntu1:~$ sudo apt-get update Hit:1 http://security.ubuntu.com/ubuntu xenial-security InRelease Hit:2 http://archive.canonical.com/ubuntu xenial InRelease Hit:3 http://id.archive.ubuntu.com/ubuntu xenial InRelease Hit:4 http://ppa.launchpad.net/font-manager/staging/ubuntu xenial InRelease Hit:5 http://id.archive.ubuntu.com/ubuntu xenial-updates InRelease Ign:6 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04 InRelease Hit:7 http://ppa.launchpad.net/moka/daily/ubuntu xenial InRelease Hit:8 http://ppa.launchpad.net/noobslab/themes/ubuntu xenial InRelease Get:9 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04 Release [1,009 B] Err:10 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04 Release.gpg Bad header line Bad header data [IP: 195.135.221.134 80] Hit:11 https://deb.opera.com/opera-stable stable InRelease Hit:12 http://ppa.launchpad.net/numix/ppa/ubuntu xenial InRelease Get:13 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04 Packages [35.9 kB] Hit:14 https://packagecloud.io/gyazo/gyazo-for-linux/ubuntu xenial InRelease Hit:15 http://ppa.launchpad.net/tista/adapta/ubuntu xenial InRelease Fetched 36.9 kB in 4s (7,905 B/s) Reading package lists... Done W: The repository 'http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04 Release' is not signed. N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use. N: See apt-secure(8) manpage for repository creation and user configuration details. E: Failed to fetch http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04/Release.gpg Bad header line Bad header data [IP: 195.135.221.134 80] E: Some index files failed to download. They have been ignored, or old ones used instead. You werent helpful at all so far but assumed I am not able to read instructions before posting here
Luke 42243 Posted February 20, 2017 Author Posted February 20, 2017 hi @@Driesner, thank you for the report we will investigate that.
hurricanehrndz 149 Posted February 20, 2017 Posted February 20, 2017 (edited) Adding the key , which I did before of course already does not help at all: user@ubuntu1:~$ wget http://download.opensuse.org/repositories/home:emby/xUbuntu_16.04/Release.key --2017-02-20 13:55:30-- http://download.opensuse.org/repositories/home:emby/xUbuntu_16.04/Release.key Resolving download.opensuse.org (download.opensuse.org)... 195.135.221.134, 2001:67c:2178:8::13 Connecting to download.opensuse.org (download.opensuse.org)|195.135.221.134|:80... connected. HTTP request sent, awaiting response... 301 Moved Permanently Location: http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04/Release.key [following] --2017-02-20 13:55:31-- http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04/Release.key Reusing existing connection to download.opensuse.org:80. HTTP request sent, awaiting response... Read error (Connection reset by peer) in headers. Retrying. --2017-02-20 13:55:32-- (try: 2) http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04/Release.key Connecting to download.opensuse.org (download.opensuse.org)|195.135.221.134|:80... connected. HTTP request sent, awaiting response... 200 OK Length: 1089 (1.1K) [application/pgp-keys] Saving to: ‘Release.key’ Release.key 100%[================================================>] 1.06K --.-KB/s in 0s 2017-02-20 13:55:32 (130 MB/s) - ‘Release.key’ saved [1089/1089] user@ubuntu1:~$ sudo apt-key add - < Release.key OK user@ubuntu1:~$ sudo apt-get update Hit:1 http://security.ubuntu.com/ubuntu xenial-security InRelease Hit:2 http://archive.canonical.com/ubuntu xenial InRelease Hit:3 http://id.archive.ubuntu.com/ubuntu xenial InRelease Hit:4 http://ppa.launchpad.net/font-manager/staging/ubuntu xenial InRelease Hit:5 http://id.archive.ubuntu.com/ubuntu xenial-updates InRelease Ign:6 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04 InRelease Hit:7 http://ppa.launchpad.net/moka/daily/ubuntu xenial InRelease Hit:8 http://ppa.launchpad.net/noobslab/themes/ubuntu xenial InRelease Get:9 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04 Release [1,009 B] Err:10 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04 Release.gpg Bad header line Bad header data [IP: 195.135.221.134 80] Hit:11 https://deb.opera.com/opera-stable stable InRelease Hit:12 http://ppa.launchpad.net/numix/ppa/ubuntu xenial InRelease Get:13 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04 Packages [35.9 kB] Hit:14 https://packagecloud.io/gyazo/gyazo-for-linux/ubuntu xenial InRelease Hit:15 http://ppa.launchpad.net/tista/adapta/ubuntu xenial InRelease Fetched 36.9 kB in 4s (7,905 B/s) Reading package lists... Done W: The repository 'http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04 Release' is not signed. N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use. N: See apt-secure(8) manpage for repository creation and user configuration details. E: Failed to fetch http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04/Release.gpg Bad header line Bad header data [IP: 195.135.221.134 80] E: Some index files failed to download. They have been ignored, or old ones used instead. You werent helpful at all so far but assumed I am not able to read instructions before posting here I'm sorry you feel that way, the errors you have presented though would usually suggest that and so we try and help everyone no matter what their issue is. Anyhow, seems to me you are having trouble connecting to the repo, I believe the key you downloaded might be corrupt. Also, if you visit the index of the repository you will see Release.gpg is there and is the signed file for the repository. I would check your internet connection before proceeding, it seems to me like it is having a hard time connecting to our repository. Does the country you live in do any censorship of the internet? Please confirm the release key is the same as the one below: -----BEGIN PGP PUBLIC KEY BLOCK----- Version: GnuPG v2.0.15 (GNU/Linux) mQENBFVVBkABCACWEEmKmOYBKgKsEtOuh27n4iG11vGAuOcAtlWxj6K/zeDXQKKi sbEAX7itvmcGBTmfs1zCimPFdYsA5/yKgLmUOnsvnrycKsC7jpoKnrvCeEueLZqp cTyXhlfM1LqWw8+sFJLPXyNp44ow55IydJISyhsAR4wEVPubuO+VlLHTlGk3iIG4 V/D9mFEpqL+iKjI57N5nu4IrH7PR3Lp7unh3a18AG+UTaBVsLA5Osxcc8yEoOecs xLCK1hVxImmrfy04WhDlHff6A49yarVdYjVxhwlu5X9WEOw5MZBu2Flj9srrbbB2 8ZDAr1IN4lm7fvoe4Y9nl5Ws2OStxt28JQtfABEBAAG0NGhvbWU6ZW1ieSBPQlMg UHJvamVjdCA8aG9tZTplbWJ5QGJ1aWxkLm9wZW5zdXNlLm9yZz6JAT4EEwECACgF AlVVBkACGwMFCQQesAAGCwkIBwMCBhUIAgkKCwQWAgMBAh4BAheAAAoJEApQb3Eq fYooSv8H/2mWdeOCj4jucUlWKoAHI4203fk90s5BnTY7gMj8J8h72kTzDcXyazLW fKjlfCO2IVORqgQRu25em4EcO7AinKZnSTaqpyypkuGwd0Rkm4kZiWhNrPR7SiWk Mu/tqZpz7MVMrRW2DnMzCskdBrgUHwwg0ILjZOm4R0+agJRVeDgC2ypmmcKNW4I3 6Z1HUYV72hsLpPOrJx4++Wc13gr0IiWUCBcmGEEZr0WHSG4DCOxyicZOZPu94Ipk ooPXhTzeXppq6ZRY+BTSRKL/65B/WSkjla3KiHqiVKu5PzCSMJ1Sc09lce/GPGg1 FBrKElKMJ/j/R6oiwHA2paXAV0Mo8c6IRgQTEQIABgUCVVUGQAAKCRA7MBG3a51l Ixy3AKC0iLk3uIgwx6oz7lZ5zxpdtJuaFgCghmuiviB5ootAWh8uFEQbnxTllpM= =+h6Z -----END PGP PUBLIC KEY BLOCK----- This is a test of me hitting the repo, on a fresh vm. root@232cee3fa661:/# cat /etc/issue Ubuntu 16.04.1 LTS \n \l root@232cee3fa661:/# apt-key list | grep emby -B1 pub 2048R/2A7D8A28 2015-05-14 [expires: 2017-07-22] uid home:emby OBS Project <home:emby@build.opensuse.org> root@232cee3fa661:/# apt update Hit:1 http://archive.ubuntu.com/ubuntu xenial InRelease Get:2 http://archive.ubuntu.com/ubuntu xenial-updates InRelease [102 kB] Ign:3 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04 InRelease Hit:4 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04 Release Get:6 http://archive.ubuntu.com/ubuntu xenial-security InRelease [102 kB] Fetched 204 kB in 1s (141 kB/s) Reading package lists... Done Building dependency tree Reading state information... Done 22 packages can be upgraded. Run 'apt list --upgradable' to see them. Edited February 20, 2017 by hurricanehrndz
Driesner 0 Posted February 20, 2017 Posted February 20, 2017 (edited) OK, here is what the Release.gpg I download looks like: -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.0.7 (GNU/Linux) iQEVAwUAWKqcoApQb3EqfYooAQhNEAf/bAbOCuWp2rHrvmsb53qVkNH7w4AZg9tJ TCtUZJ7knt22FHanz+KztO7XmmTnrf6H7RDJWlCHhjmdOSpECLiarWlldaQthYWN 5WiTPDxHxY9JZc+je+5oV9nfI6Kfy4VSOhLmvSVBrt9rtELzPCwDFk43gZvzHk9x CCLuNTTtd9n95YqBpCzxmjkJKtlH1ZX6LbXFyx/gCQE1XfMsp9yVGTXdQ7dIvnTn CUjKEG41spvsfQtULHXY1POVxJT+Giz9MSSGRDK7v9ms8IGB0mPV2MPayGiIEgTI ABT7ShYRPfaPxSCLoU8xH3SgALPXkgeJyEzqnZVuhDysodAyqh9a/w== =y4BH -----END PGP SIGNATURE----- Yes, there is censorship where I am, but I think it is mainly done by DNS filtering as far as I know. So I used a browser which uses VPN to download the file but it looks exactly the same. Release.key : -----BEGIN PGP PUBLIC KEY BLOCK----- Version: GnuPG v2.0.15 (GNU/Linux) mQENBFVVBkABCACWEEmKmOYBKgKsEtOuh27n4iG11vGAuOcAtlWxj6K/zeDXQKKi sbEAX7itvmcGBTmfs1zCimPFdYsA5/yKgLmUOnsvnrycKsC7jpoKnrvCeEueLZqp cTyXhlfM1LqWw8+sFJLPXyNp44ow55IydJISyhsAR4wEVPubuO+VlLHTlGk3iIG4 V/D9mFEpqL+iKjI57N5nu4IrH7PR3Lp7unh3a18AG+UTaBVsLA5Osxcc8yEoOecs xLCK1hVxImmrfy04WhDlHff6A49yarVdYjVxhwlu5X9WEOw5MZBu2Flj9srrbbB2 8ZDAr1IN4lm7fvoe4Y9nl5Ws2OStxt28JQtfABEBAAG0NGhvbWU6ZW1ieSBPQlMg UHJvamVjdCA8aG9tZTplbWJ5QGJ1aWxkLm9wZW5zdXNlLm9yZz6JAT4EEwECACgF AlVVBkACGwMFCQQesAAGCwkIBwMCBhUIAgkKCwQWAgMBAh4BAheAAAoJEApQb3Eq fYooSv8H/2mWdeOCj4jucUlWKoAHI4203fk90s5BnTY7gMj8J8h72kTzDcXyazLW fKjlfCO2IVORqgQRu25em4EcO7AinKZnSTaqpyypkuGwd0Rkm4kZiWhNrPR7SiWk Mu/tqZpz7MVMrRW2DnMzCskdBrgUHwwg0ILjZOm4R0+agJRVeDgC2ypmmcKNW4I3 6Z1HUYV72hsLpPOrJx4++Wc13gr0IiWUCBcmGEEZr0WHSG4DCOxyicZOZPu94Ipk ooPXhTzeXppq6ZRY+BTSRKL/65B/WSkjla3KiHqiVKu5PzCSMJ1Sc09lce/GPGg1 FBrKElKMJ/j/R6oiwHA2paXAV0Mo8c6IRgQTEQIABgUCVVUGQAAKCRA7MBG3a51l Ixy3AKC0iLk3uIgwx6oz7lZ5zxpdtJuaFgCghmuiviB5ootAWh8uFEQbnxTllpM= =+h6Z -----END PGP PUBLIC KEY BLOCK----- So I tried again... but sadly still the same issue: user@ubuntu1:~$ apt-key list | grep emby -B1 pub 2048R/2A7D8A28 2015-05-14 [expires: 2017-07-22] uid home:emby OBS Project <home:emby@build.opensuse.org> user@ubuntu1:~$ sudo apt update . . . Get:14 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04 Release [1,009 B] Err:15 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04 Release.gpg Bad header line Bad header data [IP: 195.135.221.134 80] . . . Reading package lists... Done E: The repository 'http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04 Release' is not signed. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. All other repos I use have no issue Edited February 20, 2017 by Driesner
hurricanehrndz 149 Posted February 21, 2017 Posted February 21, 2017 I'm not sure what to say, could be flagged because it's a gpg file. Which means encrypted. The 16.10 repo does not present that issue though? Sent from my ONEPLUS A3000 using Tapatalk
hurricanehrndz 149 Posted February 21, 2017 Posted February 21, 2017 Which other third-party repos are you using Sent from my ONEPLUS A3000 using Tapatalk
Driesner 0 Posted February 21, 2017 Posted February 21, 2017 I use: https://packagecloud.io/gyazo/gyazo-for-linux/ubuntu https://deb.opera.com/opera-stable and some from ppa.launchpad.net, for example http://ppa.launchpad.net/noobslab/themes/ubuntu So I tried with the 16.10 repo and get the same issue: Ign:12 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 InRelease Get:13 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Release [1,009 B] Err:14 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Release.gpg Bad header line Bad header data [IP: 195.135.221.134 80] Get:15 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages [35.9 kB] Fetched 36.9 kB in 6s (5,483 B/s) Reading package lists... Done W: The repository 'http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Release' is not signed. N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use. N: See apt-secure(8) manpage for repository creation and user configuration details. E: Failed to fetch http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10/Release.gpg Bad header line Bad header data [IP: 195.135.221.134 80] E: Some index files failed to download. They have been ignored, or old ones used instead.
