silvanet 0 Posted July 20, 2015 Posted July 20, 2015 Just so that others can see in case they ever need help, we have attempted to help you but haven't heard back after we offered suggestions or asked questions. You only posted for help twice. I responded within 30 minutes here: http://emby.media/community/index.php?/topic/22510-m4a-aac-direct-play-without-transcoding-through-webinterface/?p=229215 And I responded within 90 minutes here: http://emby.media/community/index.php?/topic/18043-web-client-will-not-play-anything/?p=229235 In both cases I never heard back. If you would like help we are here to help. If you would like to uninstall then you should be able to uninstall just as with any other ubuntu package. Sorry, but you grabbed only a minor part of my posts all across this forum as I was looking for help. I never got any email notifications of anybody responding and I went about my business. I did plenty of digging into the logs and the transcoding info and I posted about that too. I also apologized for having not collected all my posts in one place. That is ALL my own fault. I admit it. I'm not in any way trying to blame you. Perhaps if I had seen your reply, I could have fixed this, but now I'm afraid things are really messed up. I DID get errors on the initial install. I mentioned that in another post. it had to do with libsdl2-2.0-0 and I don't thing ffmpeg properly installed. But I did mention that for a moment at least everything played OK, so I don't know if that was really the problem. Do you still want me to send you a log and try to help me fix this?
silvanet 0 Posted July 20, 2015 Posted July 20, 2015 On uninstalling just as with any other package, I'm a little wary because now I'm getting errors on missing dependencies with my kodi unable to do updates.
hurricanehrndz 149 Posted July 20, 2015 Posted July 20, 2015 (edited) On uninstalling just as with any other package, I'm a little wary because now I'm getting errors on missing dependencies with my kodi unable to do updates. If you are willing I'm able to offer remote assistance. PS did you install Kodi yourself? Edited July 20, 2015 by hurricanehernandez
Luke 42242 Posted July 20, 2015 Author Posted July 20, 2015 Sorry, but you grabbed only a minor part of my posts all across this forum as I was looking for help. I never got any email notifications of anybody responding and I went about my business. I did plenty of digging into the logs and the transcoding info and I posted about that too. I also apologized for having not collected all my posts in one place. That is ALL my own fault. I admit it. I'm not in any way trying to blame you. Perhaps if I had seen your reply, I could have fixed this, but now I'm afraid things are really messed up. I DID get errors on the initial install. I mentioned that in another post. it had to do with libsdl2-2.0-0 and I don't thing ffmpeg properly installed. But I did mention that for a moment at least everything played OK, so I don't know if that was really the problem. Do you still want me to send you a log and try to help me fix this? Yea I'm here and will help with whatever problem you're having. As far as logs go, see this first: http://emby.media/community/index.php?/topic/23404-cant-play-from-browser-and-intros-no-longer-working/?p=229357 The browser can't play strm files that contain kodi plugin paths. This might not be your fault - maybe they were put there by a kodi add-on? In any case, we can improve this in a future release to not allow you to try and play in the first place. If your issue is different or if you're not sure, then yes please post logs.
silvanet 0 Posted July 20, 2015 Posted July 20, 2015 First, in reply to Luke, yes, I did have a kodi media browser add-on, so thanks for clearing that up. Then I was wrong to expect that I could click on a the server's home page video icons and have them play; or, at least, if they were or weren't playing then it would have been the Kodi addon that I had to address, and not emby. My ultimate idea was to set emby up as my stand along media server (on a NAS), and allow any computer or TV connected box to stream content from my library on to any device in my home network. Kodi can kind of do that, but in a very limited way (at least to my still learning understanding of Kodi). Maybe a little explanation of what I should expect from emby? I created its library (well, kind of, because what I really did was copy over my Kodi library - and then remove the original Kodi library when I found that Kodi could recognize the one I created for emby and that all the content played as if the original one were there). I then wanted to do two things: check that Kodi running on the same machine where I set up emby could play the videos; and then check if another client on my home network could do the same. For a brief moment I was able to get the server machine to play the videos from within Kodi, but I was never able to get the client to do so. OK, after that little intro, I'll go back and see if emby still reports that it is running OK. I'll try to play some videos and I'll send you my log. Thanks so much.
silvanet 0 Posted July 20, 2015 Posted July 20, 2015 Second, in reply to hurricanehernandez, yes I did install Kodi myself. I have done so in over 100 machines, all working perfectly well - some Raspberrys with OpenElec, a few pure Linux boxes (the ones with the least problems), and the vast majority of them Android boxes, with a smattering of Windows 7 and Windows 8 installations.
Luke 42242 Posted July 20, 2015 Author Posted July 20, 2015 What you can do is add your own media to the Emby library - your own videos, music, pictures, etc. You should have no problems playing those from Emby apps and if you do, then we can help. Emby also has some understanding of strm files: https://github.com/MediaBrowser/Wiki/wiki/Strm%20files But only if those files contain media paths. If those files contain kodi plugin paths, then you can browse that content from any Emby app, but you can only play it from the Kodi add-on.
silvanet 0 Posted July 20, 2015 Posted July 20, 2015 OK, now I know I did mess something up. I restarted emby and got this: at ServiceStack.ServiceStackHost.TryResolve[iRequestLogger] () [0x00000] in <filename unknown>:0 at ServiceStack.Host.ServiceRunner`1[MediaBrowser.WebDashboard.Api.GetDashboardResource].AfterEachRequest (IRequest requestContext, MediaBrowser.WebDashboard.Api.GetDashboardResource request, System.Object response) [0x00000] in <filename unknown>:0 at ServiceStack.Host.ServiceRunner`1[MediaBrowser.WebDashboard.Api.GetDashboardResource].HandleException (IRequest request, MediaBrowser.WebDashboard.Api.GetDashboardResource requestDto, System.Exception ex) [0x00000] in <filename unknown>:0 at ServiceStack.Host.ServiceRunner`1[MediaBrowser.WebDashboard.Api.GetDashboardResource].Execute (IRequest request, System.Object instance, MediaBrowser.WebDashboard.Api.GetDashboardResource requestDto) [0x00000] in <filename unknown>:0 at ServiceStack.Host.ServiceRunner`1[MediaBrowser.WebDashboard.Api.GetDashboardResource].Process (IRequest requestContext, System.Object instance, System.Object request) [0x00000] in <filename unknown>:0 at ServiceStack.Host.ServiceExec`1[MediaBrowser.WebDashboard.Api.DashboardService].Execute (IRequest request, System.Object instance, System.Object requestDto, System.String requestName) [0x00000] in <filename unknown>:0 at ServiceStack.Host.ServiceRequestExec`2[MediaBrowser.WebDashboard.Api.DashboardService,MediaBrowser.WebDashboard.Api.GetDashboardResource].Execute (IRequest requestContext, System.Object instance, System.Object request) [0x00000] in <filename unknown>:0 at ServiceStack.Host.ServiceController+<>c__DisplayClassf+<>c__DisplayClass11.<RegisterServiceExecutor>b__e (IRequest reqCtx, System.Object req) [0x00000] in <filename unknown>:0 at ServiceStack.Host.ServiceController.ManagedServiceExec (ServiceStack.Host.ServiceExecFn serviceExec, IService service, IRequest request, System.Object requestDto) [0x00000] in <filename unknown>:0 at ServiceStack.Host.ServiceController+<>c__DisplayClassf.<RegisterServiceExecutor>b__d (IRequest requestContext, System.Object dto) [0x00000] in <filename unknown>:0 at ServiceStack.Host.ServiceController.Execute (System.Object requestDto, IRequest req) [0x00000] in <filename unknown>:0 at ServiceStack.HostContext.ExecuteService (System.Object request, IRequest httpReq) [0x00000] in <filename unknown>:0 at ServiceStack.Host.Handlers.ServiceStackHandlerBase.ExecuteService (System.Object request, IRequest httpReq) [0x00000] in <filename unknown>:0 at ServiceStack.Host.RestHandler.GetResponse (IRequest request, System.Object requestDto) [0x00000] in <filename unknown>:0 at ServiceStack.Host.RestHandler.ProcessRequestAsync (IRequest httpReq, IResponse httpRes, System.String operationName) [0x00000] in <filename unknown>:0
silvanet 0 Posted July 20, 2015 Posted July 20, 2015 Just done some checking and it does seem that emby is making me mix repository archives - open suse with ubuntu. Not sure I really should be doing that. Checking with Ubuntu 14.04, emby is not supported since 12.10. Have you guys made necessary adjustments to work with 14.04, or maybe it's best really to uninstall emby for my version?
silvanet 0 Posted July 20, 2015 Posted July 20, 2015 I'm now working on fixing my broken installer package in Ubuntu.
Luke 42242 Posted July 21, 2015 Author Posted July 21, 2015 it's still an ubuntu-compatible package we're just using an opensuse build system that allows us to build for multiple distros.
drhill 2 Posted July 21, 2015 Posted July 21, 2015 I just attempted upgraded emby on my linux server (14.04 trusty, 3.13.0-43-generic GNU/Linux) via apt-get and it fails out and no longer starts. apt-get error Setting up emby-server (3.0.5675.1) ... * EmbyServer: started but exited rightaway, please check logs in /var/lib/emby-server/logs invoke-rc.d: initscript emby-server, action "start" failed. dpkg: error processing package emby-server (--configure): subprocess installed post-installation script returned error exit status 1 Errors were encountered while processing: emby-server Also, every single time I've updated emby it rewrites my /etc/default/emby-server file so I have to edit it to get back my data as the home folder is in a different location. server-63573071307.txt unhandled_0c55a628-b56d-413e-bc49-cd8fe516809b.txt
Luke 42242 Posted July 21, 2015 Author Posted July 21, 2015 it looks like it's not able to secure the socket. try again in a few minutes or reboot the system.
hurricanehrndz 149 Posted July 21, 2015 Posted July 21, 2015 I just attempted upgraded emby on my linux server (14.04 trusty, 3.13.0-43-generic GNU/Linux) via apt-get and it fails out and no longer starts. apt-get error Setting up emby-server (3.0.5675.1) ... * EmbyServer: started but exited rightaway, please check logs in /var/lib/emby-server/logs invoke-rc.d: initscript emby-server, action "start" failed. dpkg: error processing package emby-server (--configure): subprocess installed post-installation script returned error exit status 1 Errors were encountered while processing: emby-server Also, every single time I've updated emby it rewrites my /etc/default/emby-server file so I have to edit it to get back my data as the home folder is in a different location. I will look into not overwriting the default file.
drhill 2 Posted July 21, 2015 Posted July 21, 2015 it looks like it's not able to secure the socket. try again in a few minutes or reboot the system. That happened after I did reboot the system, which was rebooted because I started getting this error :\
Luke 42242 Posted July 21, 2015 Author Posted July 21, 2015 make sure nothing else is taking control over that port, and also make sure the server isn't already running.
drhill 2 Posted July 21, 2015 Posted July 21, 2015 make sure nothing else is taking control over that port, and also make sure the server isn't already running. ps aux shows no instances of emby and a netstat shows nothing for 8920 and 8096. Is there setting in the default (or a config) I can set the ports or disable https? This server is just used for organizing, tracking playback progress, and server files to local Kodi devices. Nothing fancy for me.
osborni 1 Posted July 21, 2015 Posted July 21, 2015 Install issues as well. To the bottom, there are a few "failed to fetch" Mono and Mediabrowser packages. Not sure if that is relevant. also - the prior release was inconsistent with downloading movie images. Poster, banner, fan art, logo. ian@ubuntu-basement:~$ wget -qO - http://download.opensuse.org/repositories/home:emby/xUbuntu_14.04/Release.key | sudo apt-key add - OK ian@ubuntu-basement:~$ sudo sh -c "echo 'deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_14.04/ /' >> /etc/apt/sources.list.d/emby-server.list" ian@ubuntu-basement:~$ sudo apt-get update Ign http://plex.r.worldssl.net lucid InRelease Ign http://plex.r.worldssl.net lucid Release.gpg Ign http://dl.google.com stable InRelease Ign http://plex.r.worldssl.net lucid Release Ign http://security.ubuntu.com trusty-security InRelease Ign http://us.archive.ubuntu.com trusty InRelease Get:1 http://dl.google.com stable Release.gpg [198 B] Hit http://download.mono-project.com wheezy/snapshots/3.10.0 InRelease Hit http://download.mono-project.com wheezy-apache24-compat InRelease Ign http://plex.r.worldssl.net lucid/main amd64 Packages/DiffIndex Ign http://plex.r.worldssl.net lucid/main i386 Packages/DiffIndex Get:2 http://dl.google.com stable Release [1,347 B] Ign http://extras.ubuntu.com trusty InRelease Ign http://ppa.launchpad.net trusty InRelease Ign http://us.archive.ubuntu.com trusty-updates InRelease Get:3 http://security.ubuntu.com trusty-security Release.gpg [933 B] Ign http://download.opensuse.org InRelease Ign http://us.archive.ubuntu.com trusty-backports InRelease Get:4 http://dl.google.com stable/main amd64 Packages [1,173 B] Hit http://us.archive.ubuntu.com trusty Release.gpg Get:5 http://security.ubuntu.com trusty-security Release [63.5 kB] Hit http://extras.ubuntu.com trusty Release.gpg Ign http://ppa.launchpad.net trusty InRelease Hit http://download.mono-project.com wheezy/snapshots/3.10.0/main amd64 Packages Get:6 http://us.archive.ubuntu.com trusty-updates Release.gpg [933 B] Get:7 http://dl.google.com stable/main i386 Packages [1,190 B] Ign http://download.opensuse.org InRelease Hit http://us.archive.ubuntu.com trusty-backports Release.gpg Hit http://us.archive.ubuntu.com trusty Release Hit http://extras.ubuntu.com trusty Release Ign http://ppa.launchpad.net trusty Release.gpg Hit http://download.mono-project.com wheezy/snapshots/3.10.0/main i386 Packages Get:8 http://us.archive.ubuntu.com trusty-updates Release [63.5 kB] Get:9 http://security.ubuntu.com trusty-security/main Sources [87.9 kB] Hit http://ppa.launchpad.net trusty Release.gpg Hit http://extras.ubuntu.com trusty/main Sources Hit http://us.archive.ubuntu.com trusty-backports Release Get:10 http://security.ubuntu.com trusty-security/restricted Sources [2,061 B] Ign http://ppa.launchpad.net trusty Release Hit http://us.archive.ubuntu.com trusty/main Sources Ign http://dl.google.com stable/main Translation-en_US Hit http://extras.ubuntu.com trusty/main amd64 Packages Get:11 http://security.ubuntu.com trusty-security/universe Sources [28.1 kB] Hit http://us.archive.ubuntu.com trusty/restricted Sources Hit http://download.mono-project.com wheezy-apache24-compat/main amd64 Packages Ign http://dl.google.com stable/main Translation-en Get:12 http://security.ubuntu.com trusty-security/multiverse Sources [2,334 B] Hit http://download.mono-project.com wheezy-apache24-compat/main i386 Packages Hit http://us.archive.ubuntu.com trusty/universe Sources Hit http://ppa.launchpad.net trusty Release Get:13 http://security.ubuntu.com trusty-security/main amd64 Packages [310 kB] Hit http://extras.ubuntu.com trusty/main i386 Packages Hit http://us.archive.ubuntu.com trusty/multiverse Sources Hit http://us.archive.ubuntu.com trusty/main amd64 Packages Hit http://us.archive.ubuntu.com trusty/restricted amd64 Packages Ign http://ppa.launchpad.net trusty/main amd64 Packages/DiffIndex Hit http://us.archive.ubuntu.com trusty/universe amd64 Packages Hit http://us.archive.ubuntu.com trusty/multiverse amd64 Packages Ign http://ppa.launchpad.net trusty/main i386 Packages/DiffIndex Hit http://us.archive.ubuntu.com trusty/main i386 Packages Hit http://us.archive.ubuntu.com trusty/restricted i386 Packages Ign http://download.opensuse.org Release.gpg Get:14 http://security.ubuntu.com trusty-security/restricted amd64 Packages [8,875 B] Get:15 http://security.ubuntu.com trusty-security/universe amd64 Packages [111 kB] Hit http://us.archive.ubuntu.com trusty/universe i386 Packages Hit http://us.archive.ubuntu.com trusty/multiverse i386 Packages Hit http://download.opensuse.org Release.gpg Get:16 http://security.ubuntu.com trusty-security/multiverse amd64 Packages [3,683 B] Get:17 http://security.ubuntu.com trusty-security/main i386 Packages [295 kB] Hit http://us.archive.ubuntu.com trusty/main Translation-en Hit http://ppa.launchpad.net trusty/main amd64 Packages Hit http://us.archive.ubuntu.com trusty/multiverse Translation-en Hit http://ppa.launchpad.net trusty/main i386 Packages Ign http://plex.r.worldssl.net lucid/main Translation-en_US Ign http://plex.r.worldssl.net lucid/main Translation-en Hit http://us.archive.ubuntu.com trusty/restricted Translation-en Get:18 http://security.ubuntu.com trusty-security/restricted i386 Packages [8,846 B] Err http://plex.r.worldssl.net lucid/main amd64 Packages 404 Not Found Err http://plex.r.worldssl.net lucid/main i386 Packages 404 Not Found Get:19 http://security.ubuntu.com trusty-security/universe i386 Packages [111 kB] Hit http://ppa.launchpad.net trusty/main Translation-en Hit http://us.archive.ubuntu.com trusty/universe Translation-en Get:20 http://security.ubuntu.com trusty-security/multiverse i386 Packages [3,838 B] Get:21 http://us.archive.ubuntu.com trusty-updates/main Sources [215 kB] Hit http://security.ubuntu.com trusty-security/main Translation-en Hit http://security.ubuntu.com trusty-security/multiverse Translation-en Hit http://security.ubuntu.com trusty-security/restricted Translation-en Ign http://extras.ubuntu.com trusty/main Translation-en_US Hit http://security.ubuntu.com trusty-security/universe Translation-en Ign http://extras.ubuntu.com trusty/main Translation-en Ign http://download.mono-project.com wheezy/snapshots/3.10.0/main Translation-en_US Get:22 http://us.archive.ubuntu.com trusty-updates/restricted Sources [3,433 B] Get:23 http://us.archive.ubuntu.com trusty-updates/universe Sources [125 kB] Ign http://download.mono-project.com wheezy/snapshots/3.10.0/main Translation-en Ign http://download.mono-project.com wheezy-apache24-compat/main Translation-en_US Get:24 http://us.archive.ubuntu.com trusty-updates/multiverse Sources [5,138 B] Ign http://download.mono-project.com wheezy-apache24-compat/main Translation-en Get:25 http://us.archive.ubuntu.com trusty-updates/main amd64 Packages [570 kB] Get:26 http://us.archive.ubuntu.com trusty-updates/restricted amd64 Packages [11.8 kB] Get:27 http://us.archive.ubuntu.com trusty-updates/universe amd64 Packages [296 kB] Get:28 http://us.archive.ubuntu.com trusty-updates/multiverse amd64 Packages [12.0 kB] Get:29 http://us.archive.ubuntu.com trusty-updates/main i386 Packages [555 kB] Get:30 http://us.archive.ubuntu.com trusty-updates/restricted i386 Packages [11.8 kB] Get:31 http://us.archive.ubuntu.com trusty-updates/universe i386 Packages [296 kB] Get:32 http://us.archive.ubuntu.com trusty-updates/multiverse i386 Packages [12.1 kB] Ign http://ppa.launchpad.net trusty/main Translation-en_US Hit http://us.archive.ubuntu.com trusty-updates/main Translation-en Hit http://us.archive.ubuntu.com trusty-updates/multiverse Translation-en Hit http://us.archive.ubuntu.com trusty-updates/restricted Translation-en Ign http://ppa.launchpad.net trusty/main Translation-en Hit http://us.archive.ubuntu.com trusty-updates/universe Translation-en Hit http://us.archive.ubuntu.com trusty-backports/main Sources Err http://ppa.launchpad.net trusty/main amd64 Packages 404 Not Found Hit http://us.archive.ubuntu.com trusty-backports/restricted Sources Hit http://us.archive.ubuntu.com trusty-backports/universe Sources Hit http://us.archive.ubuntu.com trusty-backports/multiverse Sources Err http://ppa.launchpad.net trusty/main i386 Packages 404 Not Found Hit http://us.archive.ubuntu.com trusty-backports/main amd64 Packages Hit http://us.archive.ubuntu.com trusty-backports/restricted amd64 Packages Hit http://us.archive.ubuntu.com trusty-backports/universe amd64 Packages Hit http://us.archive.ubuntu.com trusty-backports/multiverse amd64 Packages Hit http://us.archive.ubuntu.com trusty-backports/main i386 Packages Hit http://us.archive.ubuntu.com trusty-backports/restricted i386 Packages Hit http://us.archive.ubuntu.com trusty-backports/universe i386 Packages Hit http://us.archive.ubuntu.com trusty-backports/multiverse i386 Packages Hit http://us.archive.ubuntu.com trusty-backports/main Translation-en Hit http://us.archive.ubuntu.com trusty-backports/multiverse Translation-en Hit http://us.archive.ubuntu.com trusty-backports/restricted Translation-en Hit http://us.archive.ubuntu.com trusty-backports/universe Translation-en Ign http://us.archive.ubuntu.com trusty/main Translation-en_US Ign http://us.archive.ubuntu.com trusty/multiverse Translation-en_US Ign http://us.archive.ubuntu.com trusty/restricted Translation-en_US Ign http://us.archive.ubuntu.com trusty/universe Translation-en_US Ign http://download.opensuse.org Release Hit http://download.opensuse.org Release Hit http://download.opensuse.org Packages Err http://download.opensuse.org Packages 404 Not Found Ign http://download.opensuse.org Translation-en_US Ign http://download.opensuse.org Translation-en Ign http://download.opensuse.org Translation-en_US Ign http://download.opensuse.org Translation-en Fetched 3,218 kB in 18s (171 kB/s) W: Conflicting distribution: http://download.mono-project.com wheezy/snapshots/3.10.0 InRelease (expected wheezy/snapshots but got wheezy) W: Failed to fetch http://plex.r.worldssl.net/PlexMediaServer/ubuntu-repo/dists/lucid/main/binary-amd64/Packages 404 Not Found W: Failed to fetch http://plex.r.worldssl.net/PlexMediaServer/ubuntu-repo/dists/lucid/main/binary-i386/Packages 404 Not Found W: Failed to fetch http://ppa.launchpad.net/apps-z/mediabrowser/ubuntu/dists/trusty/main/binary-amd64/Packages 404 Not Found W: Failed to fetch http://ppa.launchpad.net/apps-z/mediabrowser/ubuntu/dists/trusty/main/binary-i386/Packages 404 Not Found W: Failed to fetch http://download.opensuse.org/repositories/home:/emby/{Repository}/Packages 404 Not Found E: Some index files failed to download. They have been ignored, or old ones used instead. ian@ubuntu-basement:~$ sudo apt-get install mono-runtime mediainfo libsqlite3-dev imagemagick-6.q8 libmagickwand-6.q8-2 libmagickcore-6.q8-2 Reading package lists... Done Building dependency tree Reading state information... Done libsqlite3-dev is already the newest version. mediainfo is already the newest version. imagemagick-6.q8 is already the newest version. libmagickcore-6.q8-2 is already the newest version. libmagickwand-6.q8-2 is already the newest version. mono-runtime is already the newest version. The following packages were automatically installed and are no longer required: libmono-corlib2.0-cil libmono-corlib4.0-cil libmono-entityframework-sqlserver6.0-cil libmono-entityframework6.0-cil libmono-opensystem-c4.0-cil libmono-sharpzip2.6-cil libmono-system2.0-cil libmono-web4.0-cil libnunit2.6-cil Use 'apt-get autoremove' to remove them. 0 upgraded, 0 newly installed, 0 to remove and 29 not upgraded. W: Duplicate sources.list entry http://ppa.launchpad.net/apps-z/mediabrowser/ubuntu/ trusty/main amd64 Packages (/var/lib/apt/lists/ppa.launchpad.net_apps-z_mediabrowser_ubuntu_dists_trusty_main_binary-amd64_Packages) W: Duplicate sources.list entry http://ppa.launchpad.net/apps-z/mediabrowser/ubuntu/ trusty/main i386 Packages (/var/lib/apt/lists/ppa.launchpad.net_apps-z_mediabrowser_ubuntu_dists_trusty_main_binary-i386_Packages) W: Duplicate sources.list entry http://download.opensuse.org/repositories/home:/emby/xUbuntu_14.04/ Packages (/var/lib/apt/lists/download.opensuse.org_repositories_home:_emby_xUbuntu%5f14.04_Packages) W: Duplicate sources.list entry http://download.opensuse.org/repositories/home:/emby/xUbuntu_14.04/ Packages (/var/lib/apt/lists/download.opensuse.org_repositories_home:_emby_xUbuntu%5f14.04_Packages) W: Duplicate sources.list entry http://download.opensuse.org/repositories/home:/emby/xUbuntu_14.04/ Packages (/var/lib/apt/lists/download.opensuse.org_repositories_home:_emby_xUbuntu%5f14.04_Packages) W: You may want to run apt-get update to correct these problems ian@ubuntu-basement:~$ sudo apt-get install emby-server Reading package lists... Done Building dependency tree Reading state information... Done The following packages were automatically installed and are no longer required: libmono-corlib2.0-cil libmono-corlib4.0-cil libmono-entityframework-sqlserver6.0-cil libmono-entityframework6.0-cil libmono-opensystem-c4.0-cil libmono-sharpzip2.6-cil libmono-system2.0-cil libmono-web4.0-cil libnunit2.6-cil Use 'apt-get autoremove' to remove them. The following packages will be upgraded: emby-server 1 upgraded, 0 newly installed, 0 to remove and 28 not upgraded. Need to get 13.5 MB of archives. After this operation, 186 kB of additional disk space will be used. Get:1 http://download.opensuse.org/repositories/home:/emby/xUbuntu_14.04/ emby-server 3.0.5675.1 [13.5 MB] Fetched 13.5 MB in 6s (1,980 kB/s) Preconfiguring packages ... (Reading database ... 440111 files and directories currently installed.) Preparing to unpack .../emby-server_3.0.5675.1_all.deb ... * EmbyServer: not running Unpacking emby-server (3.0.5675.1) over (3.0.5666.9) ... Processing triggers for ureadahead (0.100.0-16) ... ureadahead will be reprofiled on next reboot Setting up emby-server (3.0.5675.1) ... * EmbyServer: started but exited rightaway, please check logs in /var/lib/mediabrowser/logs invoke-rc.d: initscript emby-server, action "start" failed. E: Sub-process /usr/bin/dpkg returned an error code (1) ian@ubuntu-basement:~$ sudo service emby-server start * EmbyServer: started but exited rightaway, please check logs in /var/lib/mediabrowser/logs
osborni 1 Posted July 22, 2015 Posted July 22, 2015 So the latest install seamed to have worked despite the errors when I ran the install. HOWEVER, the server isn't updating images and xml/nfo information properly. Sometimes it works, most times it doesn't. It seams to be creating 0 kb image files (poster, banner. logo, fanart) and it will fail to download the image if I do a "Browse Image > download". System says "error downloading to /../../ folder" I can download the image into the movie folder just fine and it will work. I can then press the "download" button and it will recognize the image and make the association in the metadata-manager. It doesn't seam to matter if I wait for the overnight library update or force a manual library update. 9/10 times it will fail. I am running Ubuntu 14.04, server is Version 3.0.5675.1 I have the movies on a Synology DS712+ with the latest software - DSM 5.2-5592 Update 1. I typically use a WIndows 7 client machine to view the movies.
Luke 42242 Posted July 22, 2015 Author Posted July 22, 2015 So the latest install seamed to have worked despite the errors when I ran the install. HOWEVER, the server isn't updating images and xml/nfo information properly. Sometimes it works, most times it doesn't. It seams to be creating 0 kb image files (poster, banner. logo, fanart) and it will fail to download the image if I do a "Browse Image > download". System says "error downloading to /../../ folder" I can download the image into the movie folder just fine and it will work. I can then press the "download" button and it will recognize the image and make the association in the metadata-manager. It doesn't seam to matter if I wait for the overnight library update or force a manual library update. 9/10 times it will fail. I am running Ubuntu 14.04, server is Version 3.0.5675.1 I have the movies on a Synology DS712+ with the latest software - DSM 5.2-5592 Update 1. I typically use a WIndows 7 client machine to view the movies. can you give an example? http://emby.media/community/index.php?/topic/790-how-to-report-a-problem/
silvanet 0 Posted July 22, 2015 Posted July 22, 2015 (edited) OK guys, I'm still not getting emby to work completely and I don't know if it's a configuration problem or if it was in the original installation on Ubuntu 14.04. Right now it appears to be working, but I am getting "Video Error: There was an error playing the video" pop-up when I try to play a video. I don't know if I should try to clean out my installation and start all over again, or proceed from here and try to see if someone can help me get it to work. Luke & hurricanehernandez were helpful, but I'm still stuck. I've read a lot on this forum and found that at least some people had a lot of trouble installing emby on Ubuntu 14.04 LTS. I've also seen posts referring to a lot of the same error messages I'm seeing in the log files. hurricanehernandez, if that offer to help me still stands, I'd like to try. Sorry, my profile time zone was wrong. I'm not in Casablanca. Edited July 22, 2015 by silvanet
drhill 2 Posted July 23, 2015 Posted July 23, 2015 ps aux shows no instances of emby and a netstat shows nothing for 8920 and 8096. Is there setting in the default (or a config) I can set the ports or disable https? This server is just used for organizing, tracking playback progress, and server files to local Kodi devices. Nothing fancy for me. I tried changing the ports in the system.xml with the same results. Is there anywhere I can get an older version so I can see if it is the latest version or a dependency?
Luke 42242 Posted July 23, 2015 Author Posted July 23, 2015 well by default https is purely optional, so you should be able to do everything with just http.
drhill 2 Posted July 23, 2015 Posted July 23, 2015 well by default https is purely optional, so you should be able to do everything with just http. Well I'm in a better state. I noticed if I let it start to the default path it would start. So I renamed my emby data folder and let it start up to the spot I wanted and it started. Stopped it and copied over my config/system.xml as well as metadata, data, and plugin folder from the old folder. It starts but I have no library and no entries in Media Library->Folders. I do have my path substitutions as I saw they were in the system.xml. Is there a file I'm missing to get the library and folders back or do I need to readd folder entries, rescan, and then go cleanup misidentified items again?
Luke 42242 Posted July 23, 2015 Author Posted July 23, 2015 Glad to hear. I'm not exactly sure what you did so i would just re-add them because that will repopulate the database. depending on where your metadata is you might not need to re-identify. also if you feel the identification is an error on the part of the server, then make sure to report some examples so that we can improve it for future use.
