quicktrick 0 Posted December 18, 2018 Posted December 18, 2018 (edited) @@Luke Luke, with the permanent mount share library scan works properly (see the picture). Thanks a lot! But the "Task Triggers" page is empty, it somewhat "hangs", it only shows the progress ring in Chrome. I remember it worked fine with v.3.5.3.0 and v.3.6.0.68. Edit: And the real time monitoring does not work on that library either. Unfortunately. Edited December 18, 2018 by quicktrick
makarai 109 Posted December 18, 2018 Posted December 18, 2018 (edited) hey, i thought, correct me if i am wrong, that some of the features of emby need write permissions. So, should your mount not be writeable ... i.e. //guest@voyo/Video /mnt/voyo/Video smbfs rw,-N,-I 192.168.1.10,-E utf8:utf8 0 0 Edited December 18, 2018 by makarai
quicktrick 0 Posted December 18, 2018 Posted December 18, 2018 Write permissions? Really? Hmm... not too secure, but... alright then, I'll try it. Thank you, makarai!
makarai 109 Posted December 18, 2018 Posted December 18, 2018 Write permissions? Really? Hmm... not too secure, but... alright then, I'll try it. Thank you, makarai! I am not sure if you can avoid writing files into the movie folders, or maybe i am completely missinformed, i write some things into the folders, metadata etc pp.
quicktrick 0 Posted December 18, 2018 Posted December 18, 2018 I mounted the share as rw. "Task Triggers" page and Real time monitoring don't work anyway. That's a pity.
makarai 109 Posted December 18, 2018 Posted December 18, 2018 I mounted the share as rw. "Task Triggers" page and Real time monitoring don't work anyway. That's a pity. I think i always mention this, why do you need real time monitoring ? If you use sonarr or radarr to get your homevideos you can just set it up that sonarr or radarr send an update call to emby after something has successfully been moved to the proper folder. 1
quicktrick 0 Posted December 18, 2018 Posted December 18, 2018 @@Luke I found that "Task Triggers" page does not load in Chrome (though I have "HTTP Response 200" in the log), but it works fine in Firefox (I use the obsolete v.56.0 for some reasons) and in Opera. And the WebUI does not work at all in IE and Pale Moon. Previously the "Task Triggers" page worked in Chrome too, but perhaps in some earlier version of Chrome.
Luke 42237 Posted December 18, 2018 Author Posted December 18, 2018 Task triggers seem to work fine here in Chrome, at least in my testing. What version of Chrome are you on?
quicktrick 0 Posted December 18, 2018 Posted December 18, 2018 (edited) Google Chrome is up to date Version 71.0.3578.98 (Official Build) (64-bit) Edit: I'm sorry, Luke, after cleaning cache, cookies etc. everything is working fine in my Chrome too! Sorry for bothering you. Edited December 18, 2018 by quicktrick
unhooked 17 Posted December 19, 2018 Posted December 19, 2018 I nuked my old db and upgraded to the latest beta and found this to be the case as well, but it was only happening while scans were running. After they finished I was able to load triggers and edit them just fine.
Luke 42237 Posted December 19, 2018 Author Posted December 19, 2018 We work hard to make you all as happy as possible. Thanks.
Duffyx 25 Posted January 12, 2019 Posted January 12, 2019 (edited) Hi Luke, when 3.6 is released I will try and work hard to push the new package in our ports tree (also resolving shared library errorrs). Currently the idea is that we have the custom ffmpeg from Emby getting compiled and then installed with the binary package of Emby. Although this begs me to question what exactly is it that we would "lose" if we use the ffmpeg already available in our package repository? What exactly are the changes you made to ffmpeg tailored for Emby. Are those changes that could be potentially upstreamed to ffmpeg? Another idea could be that you distribute all libraries and binaries in the Emby package itself; this would also fix the shared library errors (this is how Plex does it). Edited January 12, 2019 by driesmp
Luke 42237 Posted January 12, 2019 Author Posted January 12, 2019 Some of our changes were actually submitted by others and we're using those patches, but they have not yet been merged into ffmpeg master. Others are related to our throttle feature. Yes it's possible to embed the whole thing in the future if you think that's the best approach. It probably will be difficult to turn that around quickly though.
metsuke 27 Posted January 19, 2019 Posted January 19, 2019 FYI - on a native FreeBSD system, I used pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.0.0.2/emby-server-freebsd_4.0.0.2_amd64.txz to install Emby and it is working perfectly.
Luke 42237 Posted January 19, 2019 Author Posted January 19, 2019 Thanks for the feedback. We are also working on getting it ready to submit to FreeBSD ports.
hjason7812 35 Posted January 26, 2019 Posted January 26, 2019 Starting a new topic. The download page will point to here for more info. Installation Instructions See https://emby.media/download FreeBSD is an advanced computer operating system used to power modern servers, desktops and embedded platforms. A large community has continually developed it for more than thirty years. Its advanced networking, security and storage features have made FreeBSD the platform of choice for many of the busiest web sites and most pervasive embedded networking and storage devices. This new installation through shell doesn't work, it never finds the repository's that you sudo in..
makarai 109 Posted January 26, 2019 Posted January 26, 2019 (edited) This new installation through shell doesn't work, it never finds the repository's that you sudo in.. you mean: Install dependencies: sudo pkg install mono libass fontconfig freetype2 fribidi gnutls iconv opus samba48 sqlite3 libtheora libva libvorbis webp libx264 libzvbi libraw Install Emby Server: pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.0.1.0/emby-server-freebsd_4.0.1.0_amd64.txz sysrc emby_server_enable="YES" service emby-server start when i browse to https://github.com/MediaBrowser/Emby.Releases/releases/download/4.0.1.0/emby-server-freebsd_4.0.1.0_amd64.txz it works fine tho Edited January 26, 2019 by makarai 1
dolphin 17 Posted January 26, 2019 Posted January 26, 2019 It would help me and possibly other FreeBSD users if the installation instructions page https://emby.media/freebsd-server.html also instructed on how to keep the Emby server up-to-date. 1
gbarone123 4 Posted January 26, 2019 Posted January 26, 2019 (edited) dolphin, Keeping the server up-to-date is very simple. From the jail shell, run the following commands: pkg install libraw (this step required to upgrade from 3.5.3.0, not required after that) pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.0.1.0/emby-server-freebsd_4.0.1.0_amd64.txz service emby-server restart That’s it. Edited January 26, 2019 by gbarone123
Luke 42237 Posted January 26, 2019 Author Posted January 26, 2019 It would help me and possibly other FreeBSD users if the installation instructions page https://emby.media/freebsd-server.html also instructed on how to keep the Emby server up-to-date. Yes I agree, thanks for the feedback.
Lilan 0 Posted January 27, 2019 Posted January 27, 2019 (edited) Is the idea to ultimately transition to moving the recommended install method directly into ports? I don't like the idea of having to use a externally managed package, and when the ports infrastructure is available, I'm wondering why it isn't being used. From what I can tell you are creating your own package and community maintainers are moving it into ports when they can. Would it be possible for the developers to take a more direct role in getting packages into ports so that they don't lag behind releases? Edited January 27, 2019 by Lilan
Luke 42237 Posted January 27, 2019 Author Posted January 27, 2019 We also maintain the ports version. We should have 4.0 submitted there within a week or so. Thanks.
hjason7812 35 Posted January 27, 2019 Posted January 27, 2019 @@makarai this is a new install of emby. I just updated freenas to 11.2.u1 and wanted to see if everything from before was fixed now. But the sudo install doesn't work and the package install gets to 100% but doesn't install because it can't find the sudo install.. not only that but emby from the plugin page doesn't even install.. lol this is just horrible
