woodsb02 17 Posted September 16, 2018 Posted September 16, 2018 Hi @@embytestit, FreeBSD uses a quarterly branch of packages by default. You can switch to the head branch if you prefer more rapid updates. Follow the instructions here: https://emby.media/community/index.php?/topic/45000-emby-server-updates-for-freebsd/&do=findComment&comment=422798 Regards, Ben 1
embytestit 1 Posted September 17, 2018 Posted September 17, 2018 Hi Ben, thanks - it worked like a charme!I could install 3.5.2.0 now! Best regards embytestit 1
dolphin 17 Posted September 20, 2018 Posted September 20, 2018 (edited) As it could be helpful to other beginners, let me report that following the official instructions is not enough to have an Emby Server running. After running the pkg add command, you need to add the following line to /etc/rc.conf emby_server_enable="YES" Be careful, that is an underscore between the words "emby" and "server", not a hyphen as in the package name! Then reboot (or logout and restart the jail if you're in a jail). By the way, how am I supposed to update the Emby server from now on? Thanks. Edited September 20, 2018 by dolphin
Luke 42234 Posted September 20, 2018 Author Posted September 20, 2018 As it could be helpful to other beginners, let me report that following the official instructions is not enough to have an Emby Server running. After running the pkg add command, you need to add the following line to /etc/rc.conf emby_server_enable="YES" Be careful, that is an underscore between the words "emby" and "server", not a hyphen as in the package name! Then reboot (or logout and restart the jail if you're in a jail). By the way, how am I supposed to update the Emby server from now on? Thanks. That's just to run at startup, right, as opposed to running manually?
woodsb02 17 Posted September 21, 2018 Posted September 21, 2018 That's just to run at startup, right, as opposed to running manually?Hi @@Luke,No, that will enable the service to run at startup, but is also required to run the service now. Instead of people editing /etc/rc.conf manually, there is a tool for it. The total 3 step process is: # pkg add ... # sysrc emby_server_enable=“YES” # service emby-server start The _ and - differences above are deliberate. Note the 3rd line will error if the 2nd line is not performed.
dolphin 17 Posted September 21, 2018 Posted September 21, 2018 # sysrc emby_server_enable=“YES” Thank you, that is even more convenient! The _ and - differences above are deliberate. Note the 3rd line will error if the 2nd line is not performed. Interesting! I'm curious to know why such difference is deliberate!
adrianwi 279 Posted September 21, 2018 Posted September 21, 2018 service emby-server onestart will work without the line added to rc.conf, although it makes sense to add it so it starts automatically after restarting the jail or rebooting the server.
zmediaserver 5 Posted October 1, 2018 Posted October 1, 2018 (edited) # sysrc emby_server_enable=“YES” # service emby-server start Request to add this info to the FreeBSD installation page. Might be obvious for some, but as someone who's still learning FreeBSD, this would be helpful as part of the installation instructions. Edited October 1, 2018 by zmediaserver
Luke 42234 Posted October 3, 2018 Author Posted October 3, 2018 Request to add this info to the FreeBSD installation page. Might be obvious for some, but as someone who's still learning FreeBSD, this would be helpful as part of the installation instructions. Thanks. I think we can just build this into the package though.
Luke 42234 Posted October 4, 2018 Author Posted October 4, 2018 Hi @@Luke, No, that will enable the service to run at startup, but is also required to run the service now. Instead of people editing /etc/rc.conf manually, there is a tool for it. The total 3 step process is: # pkg add ... # sysrc emby_server_enable=“YES” # service emby-server start The _ and - differences above are deliberate. Note the 3rd line will error if the 2nd line is not performed. Any comments on this? Freebsd explicitly forbids it: https://www.freebsd.org/doc/en/books/porters-handbook/pkg-install.html
adrianwi 279 Posted October 4, 2018 Posted October 4, 2018 You could argue that you are not 'modify(ing) the currently running system' as the script is being run in the FreeNAS shell and the changes are being applied to the jail it is creating. Usually, you are using pkg to install inside a jail, so have to set the rc.conf settings manually. Scripting the creation of iocage jails from FreeNAS moves the goal posts a little?
woodsb02 17 Posted October 4, 2018 Posted October 4, 2018 I can only speak for FreeBSD, where the current policy is to not enable and start services automatically during pkg install or upgrade - that is left to the user. FreeNAS may have different policies - I am not aware.
Luke 42234 Posted October 5, 2018 Author Posted October 5, 2018 @@woodsb02 based on your comments in post #81, what are you suggesting that we do? It sounded like you were suggesting that we make these changes to the package. Thanks !
woodsb02 17 Posted October 7, 2018 Posted October 7, 2018 I suggest the FreeBSD instructions page are just updated to include these steps, as it is not normal practice in FreeBSD to automate them. Anyone that is using FreeBSD should be used to these steps from other software they have installed.
Luke 42234 Posted October 7, 2018 Author Posted October 7, 2018 OK great, thanks for the advice. I will do that.
Luke 42234 Posted October 9, 2018 Author Posted October 9, 2018 I'm updating the website instructions now. please check them out later today. Thanks !
Smartypants 0 Posted October 10, 2018 Posted October 10, 2018 I can only speak for FreeBSD, where the current policy is to not enable and start services automatically during pkg install or upgrade - that is left to the user. FreeNAS may have different policies - I am not aware. I think it's the same for freeNAS as it's basically freeBSD with a UI. I agree with you, I like to enable my services myself after the install. Just gives me the impression of control over the machine I just installed Emby in a FreeNAS jail following the instructions and everything work #1. If someone really want to make it a one line install just add && between the commands. No need for scripting anything. Again you only save 2 copy and paste.. nothing to be excited about. pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/3.5.3.0/emby-server-freebsd_3.5.3.0_amd64.txz && sysrc emby_server_enable="YES" && service emby-server start Just one thing I noticed after the install. Is the "Restart" button working for you in the dashboard? I'm not personally attached to it as it never worked before anyway but sometime I would find it useful to have it working.
Luke 42234 Posted October 10, 2018 Author Posted October 10, 2018 That's clever, thanks! And yea we may need to do more testing on the restart button.
Drego344 23 Posted October 12, 2018 Posted October 12, 2018 so i did the steps above and got my emby working again.....but now the plugin keep shutting itself down......on freenas 11.1 U6
Luke 42234 Posted October 12, 2018 Author Posted October 12, 2018 Why do you feel it keeps shutting down? How are you determining that?
Drego344 23 Posted October 12, 2018 Posted October 12, 2018 i am trying to do a sync in kodi....and it keeps disconnecting.....when i check freenas the plugin is off....it stays on for about a sec or two then turns off again
