jbark 1 Posted March 24, 2024 Posted March 24, 2024 I can't get my card setup to do hardware transcoding with the latest version of Emby running in Docker. The hardware_detection log attached shows "Message": "Failed to initialize VA /dev/dri/renderD128. Error -1". I've installed the following: - NVIDIA-Linux-x86_64-550.57.run (the latest Linux drivers from the Nvidia web site), - NVIDIA_Container_Toolkit (and I following the install guide found here) I'm able to run "sudo docker run --rm --gpus all nvidia/cuda:11.6.2-base-ubuntu20.04 nvidia-smi" successfully. (See the attached screen shot.) However, when I run Emby, I don't see any evidence that hardware transcoding is taking place. My CPU shots up to 100% and stays there while playing a 4k video, for example. I'm new to Emby, Linux, and Docker but have made some good headway. Emby works great except for this one issue. Any ideas what I could be doing wrong? embyserver.txt hardware_detection-63846886126.txt
Luke 42244 Posted March 25, 2024 Posted March 25, 2024 hi @jbarkas a test, are you able to try our native ubuntu package and see how things compare? https://emby.media/linux-server.html
jbark 1 Posted March 26, 2024 Author Posted March 26, 2024 I managed to fix the problem on my own although I'm not exactly sure what did the trick. I reinstalled the linux headers, nvidia linux drivers, and the nvidia container toolkit. Next, I rebooted the computer and, presto, Emby showed my 1050 as a hardware decoder/encoder and hw transcoding works! Thank you for taking the time to respond. 1
