sargenthp 35 Posted March 13, 2024 Posted March 13, 2024 App version: 2.1.10g So I have 2 accounts for local network use... 1 called Parents with a password, and 1 called Family without a password. I have found if I do not specifically logout of the Parents account, and close out the app: I can go into the later app as Family and then at the top bar go to "Switch to Parents", and it will let me in without a password.
GrimReaper 4898 Posted March 13, 2024 Posted March 13, 2024 (edited) Passwords are remembered on device until Sign Out - you need to protect Parents account with optional Profile PIN. Passwords Edited March 13, 2024 by GrimReaper
sargenthp 35 Posted March 13, 2024 Author Posted March 13, 2024 Must be a change since 4.8, eh? It worked as expected before.
GrimReaper 4898 Posted March 13, 2024 Posted March 13, 2024 1 minute ago, sargenthp said: Must be a change since 4.8, eh? It worked as expected before. Yep, login process has been revamped for 4.8+.
Luke 42244 Posted March 13, 2024 Posted March 13, 2024 Hi, have you checked out the new profile pin feature?
