psychedelicu 3 Posted March 2, 2024 Posted March 2, 2024 I have the exact same issue on my Tizen tv. Audio is DTS, video is direct play, but the audio is transcoded to ac3. I had the se issue with jellyfin too, and it seems that this issue persist for years and is nothing new on forums. Any fix for this? @SamES
Luke 42239 Posted March 6, 2024 Posted March 6, 2024 @psychedelicu Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
psychedelicu 3 Posted March 6, 2024 Author Posted March 6, 2024 1 hour ago, Luke said: @psychedelicu Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! I created a post here, with logs too https://emby.media/community/index.php?/topic/126951-movie-freeze-when-audio-is-transcoded/#comment-1336078
FrostByte 5453 Posted March 6, 2024 Posted March 6, 2024 (edited) There is no fix for Samsung apps transcoding DTS. Samsung TVs haven't supported DTS since 2017. There should be a chart in your user's manual like in the link below. That is a list of all audio codecs your TV supports. Anything else will need to be transcoded. https://developer.samsung.com/smarttv/develop/specifications/media-specifications/2023-tv-video-specifications.html For best results always preselect a compatible audio codec if available. Otherwise, you can see buffering which gets worse the higher the bitrate of the input. Edited March 6, 2024 by FrostByte 3
rbjtech 5341 Posted March 6, 2024 Posted March 6, 2024 42 minutes ago, FrostByte said: There is no fix for Samsung apps transcoding DTS. Samsung TVs haven't supported DTS since 2017. There should be a chart in your user's manual like in the link below. That is a list of all audio codecs your TV supports. Anything else will need to be transcoded. https://developer.samsung.com/smarttv/develop/specifications/media-specifications/2023-tv-video-specifications.html For best results always preselect a compatible audio codec if available. Otherwise, you can see buffering which gets worse the higher the bitrate of the input. ..and from the video codec side, refusal to support Dolby Vision MUST be hurting their sales as it's pretty much a mainstream / defacto standard now on most devices. It's either Samsung being extremly stubborn or maybe some tie in with the HDR10+ Alliance that is restricting them from supporting it .. A shame, as it's the end consumer that ultimately suffers when they find out their shiny new Samsung won't play mainstream audio and video formats... 2
SamES 1084 Posted March 6, 2024 Posted March 6, 2024 1 hour ago, FrostByte said: There is no fix for Samsung apps transcoding DTS. Samsung TVs haven't supported DTS since 2017. There should be a chart in your user's manual like in the link below. That is a list of all audio codecs your TV supports. Anything else will need to be transcoded. https://developer.samsung.com/smarttv/develop/specifications/media-specifications/2023-tv-video-specifications.html For best results always preselect a compatible audio codec if available. Otherwise, you can see buffering which gets worse the higher the bitrate of the input. @psychedelicu, this is your answer, unfortunately. This can work for, there is also a batch version if you have a lot of files 1
