Jonathan1683 29 Posted March 2, 2024 Posted March 2, 2024 Hello, I have been using my appleTVs for many years with out issues, but now I am constantly noticing Audio being slightly of sync. Is anyone else having this issue and are there anything I can do to try and fix this issue? When I play on my PC it plays fine, this is on lan/direct play as well. Sometimes it will start happening when i pause/resume, but I now notice it a lot even when I am not pausing. Thank you!
Luke 42239 Posted March 2, 2024 Posted March 2, 2024 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Jonathan1683 29 Posted March 3, 2024 Author Posted March 3, 2024 (edited) Here are the logs the show i played to show the error is love is blind user jonathan Thanks for your help edit: the logs are not anonymized when I click that option I had to remove them. Should I pm them? It shows my server info on these lines, it seems to be hiding some info , but not others. 024-03-02 05:07:06.583 Info Server: http/1.1 GET http://xxxx:xxx/emby/videos/231613/hls1/main/1.ts?PlaySessionId=eddace9a4276421c8dc5b0460d2d1feb. Accept=*/*, Connection=keep-alive, Host=host13, User-Agent=libmpv, Icy-MetaData=1 Edited March 3, 2024 by Jonathan1683
Jonathan1683 29 Posted March 3, 2024 Author Posted March 3, 2024 Hello i redacted some of my info from the log files I think the anonymize button is not working fully. embyserver.txt ffmpeg-transcode-51d0ad37-508a-4716-8255-fb39885e212d_1.txt hardware_detection-63845073739.txt
whytea 5 Posted March 4, 2024 Posted March 4, 2024 I think it's the same problem as this one. https://emby.media/community/index.php?/topic/123542-audio-lag-when-playing-with-mpv-video-player/ 1
Jonathan1683 29 Posted March 4, 2024 Author Posted March 4, 2024 hello i think you are right, at least I am not alone thank you
sdragon001 25 Posted March 12, 2024 Posted March 12, 2024 @Jonathan1683try turning off framerate matching in the AppleTV settings. So far this is reported to work and a workaround for now, if you want to use it for other Apple TV apps you’ll have to turn it back on. Alternatively you can also use DLNA to AppleTV or other 3rd party apps as well. (VidHub, infuse**paid sub**) infuse is the most recommended 3rd party app to use on AppleTV for features that are not available yet for the official Emby app for appleTV. 1
Jonathan1683 29 Posted March 12, 2024 Author Posted March 12, 2024 Never heard of any of that before I will check on that when i get home. Thanks for the tips! 1
Jonathan1683 29 Posted March 13, 2024 Author Posted March 13, 2024 (edited) I turned off frame rate matching and it seemed to fix the audio issue. Thanks for the help, I don't know what I am missing out on without that option, but I think I rather have the audio in sync, it was very annoying. Edited March 13, 2024 by Jonathan1683 1 1
Jonathan1683 29 Posted April 5, 2024 Author Posted April 5, 2024 Actually it looks like there is still this issue after turning that off. Is there any idea when this might be fixed? There is nothing worse than trying to watch shows and the audio is out of sync
Luke 42239 Posted April 5, 2024 Posted April 5, 2024 2 hours ago, Jonathan1683 said: Actually it looks like there is still this issue after turning that off. Is there any idea when this might be fixed? There is nothing worse than trying to watch shows and the audio is out of sync Hi, we are looking into it. Thanks.
mallinss 0 Posted May 22, 2024 Posted May 22, 2024 Hello, I'm new to Emby, just moved across from Plex and the first time I tried the Emby TVOS app, I noticed the same thing, the audio is out of sync, back to Plex, no issue. Checked on a browser session on my MacBook, no issue, seems like an issue with the TVOS app.... not incline to make the Apple TV setting change as described above, as I use a lot of other apps without issue and don't want to upset these... Is there going to be a fix for the TVOS app ? Steve
Jonathan1683 29 Posted May 23, 2024 Author Posted May 23, 2024 20 hours ago, mallinss said: Hello, I'm new to Emby, just moved across from Plex and the first time I tried the Emby TVOS app, I noticed the same thing, the audio is out of sync, back to Plex, no issue. Checked on a browser session on my MacBook, no issue, seems like an issue with the TVOS app.... not incline to make the Apple TV setting change as described above, as I use a lot of other apps without issue and don't want to upset these... Is there going to be a fix for the TVOS app ? Steve Why did you move from plex? I was considering moving to that because of this issue and I noticed this problem has been here for about 6 months so I am worried it may not be fixed. I just don't want to do put all the effort into moving everything over and end up having other things I don't like about plex. I really like emby minus this big issue and it has always been rock solid for apple tv until recent and I have been using emby over 7 years now, but I don't know what else to do.
mallinss 0 Posted May 23, 2024 Posted May 23, 2024 8 hours ago, Jonathan1683 said: Why did you move from plex? I was considering moving to that because of this issue and I noticed this problem has been here for about 6 months so I am worried it may not be fixed. I just don't want to do put all the effort into moving everything over and end up having other things I don't like about plex. I really like emby minus this big issue and it has always been rock solid for apple tv until recent and I have been using emby over 7 years now, but I don't know what else to do. I looked at Emby, I thought it was a bit more 'polished' than Plex, I was an early adaptor of Plex, been using it since its inception with a lifetime pass, whilst Plex has worked well for me, they have become a bit stale, not much change, so I thought I would load up Emby and have a closer look, I liked how it presented and looked and felt much cleaner, but I have found some things that need to be addressed by Emby, the above with the Apple TV app being a real problem for me.... the good thing is, I'm sharing my file repositories with both Plex and Emby, so its no real issue to run them both, which is what I'm doing for now... I use Sonarr and Radarr to keep all my files in check, so this helps both Plex and Emby... I also run these on Ubuntu Linux, hope this helps
beanhammer 0 Posted May 29, 2024 Posted May 29, 2024 Has there been anymore updates on this? I had the same issue with an Apple TV 4k and I really want to use the native app but had to cancel emby premiere until it's resolved.
linedpaper 3 Posted June 3, 2024 Posted June 3, 2024 (edited) Having this issue as well. Looks like it’s being going on for a long time, that’s unfortunate hopefully it gets worked on soon! Happy to provided any logs needed. Edited June 3, 2024 by linedpaper 1
mallinss 0 Posted June 10, 2024 Posted June 10, 2024 Yep, still an issue for me. Is development been able to reproduce this ? I note they are looking into it Steve
Luke 42239 Posted June 12, 2024 Posted June 12, 2024 On 6/9/2024 at 11:57 PM, mallinss said: Yep, still an issue for me. Is development been able to reproduce this ? I note they are looking into it Steve Hi, yes, we are looking into it. Thanks.
KaptainKrypton 2 Posted June 21, 2024 Posted June 21, 2024 Same boat for me as well. Having to pay for and use an Infuse subscription as a front end since this hasn't been remedied. Infuse plays perfectly and uses the database smoothly. Only issue is that Infuse doesn't have the ability to see the "extras folder" and play any special features.
linedpaper 3 Posted June 21, 2024 Posted June 21, 2024 Exactly! And there are other topics on this same subject, this has been “we’re looking into it” for at least a year so don’t hold your breath. Infuse is sadly the way. 1
simonmason 19 Posted July 4, 2024 Posted July 4, 2024 I been having this issue for a while and had given up - But was watching something today and the lip sync was so far out I decided to take another look. I did turn off the Match Frame Rate and the same content seems to now align perfectly. I googled this setting and don't understand what the impact of turning it off is to other apps. But other apps seem to work fine with this turned on, so would like to learn more about this? 1
toddla 0 Posted July 4, 2024 Posted July 4, 2024 I'm experiencing the same issue with audio out of sync on Apple TV with ripped content. Live TV via my HDHomerun works fine without any sync issues.
Jonathan1683 29 Posted July 4, 2024 Author Posted July 4, 2024 56 minutes ago, simonmason said: I been having this issue for a while and had given up - But was watching something today and the lip sync was so far out I decided to take another look. I did turn off the Match Frame Rate and the same content seems to now align perfectly. I googled this setting and don't understand what the impact of turning it off is to other apps. But other apps seem to work fine with this turned on, so would like to learn more about this? one thing i notice is all the black scenes on movies look terrible washed out and blocky like im watching it on 56k real player when doesn’t matter if its in 4k still looks bad and i have to keep toggling between either out of sync audio or bad quality video
