francoisp 13 Posted April 28, 2024 Author Posted April 28, 2024 On 4/26/2024 at 6:03 PM, Luke said: HI, please let me know if 4.9.0.16 resolves it, once available for your platform. Thanks. Yes it has solved the shuffle issue on both my Android Emby App and my Google TV Chromecast. Thank you. 1
EZEd 60 Posted April 29, 2024 Posted April 29, 2024 6 hours ago, francoisp said: Try 4.9.0.16. It has solved the shuffle issue for my Google TV Chromecast. Is 4.9.0.16 a beta version? I prefer not to run betas. I don't mind reverting back to a previous stable version. I just can't find any instructions on how to do it nor locations on where to find previous versions.
francoisp 13 Posted April 29, 2024 Author Posted April 29, 2024 5 hours ago, EZEd said: Is 4.9.0.16 a beta version? I prefer not to run betas. I don't mind reverting back to a previous stable version. I just can't find any instructions on how to do it nor locations on where to find previous versions. I'm like you. However in this instance I made an exception. I also read that's it not always possible to go back due to changes to the database.
EZEd 60 Posted April 29, 2024 Posted April 29, 2024 Okay thanks for info 16 hours ago, francoisp said: Try 4.9.0.16. It has solved the shuffle issue for my Google TV Chromecast. Is 4.9.0.16 a beta version? I prefer not to run betas. I don't mind reverting back to a previous stable version. I just can't find any instructions on how to do it nor locations on where to find previous versions.
mGraziano 2 Posted April 29, 2024 Posted April 29, 2024 I'm using 4.9.0.16 (64-bit NAS) and on the Amazon Firestick under genre (Play All/Shuffle All) does not work. The server hangs up for several minutes and never plays. Same thing in a browser at the Song level. For example, click 'Genres', click 'Instrumental rock', click 'Songs >', click either 'Play All' or 'Shuffle All' button. Although Music>Genres>Instrumental Rock>Shuffle works now, it plays songs where the album's genre is 'Instrumental Rock' not the track. I think what's broken is track level genre play.
francoisp 13 Posted April 29, 2024 Author Posted April 29, 2024 54 minutes ago, mGraziano said: Although Music>Genres>Instrumental Rock>Shuffle works now, it plays songs where the album's genre is 'Instrumental Rock' not the track. I think what's broken is track level genre play. I did notice that but I wasn't sure if it was by design or a defect.
Luke 42244 Posted April 29, 2024 Posted April 29, 2024 1 hour ago, francoisp said: I did notice that but I wasn't sure if it was by design or a defect. It’s by design because if it didn’t work that way, then you wouldn’t be able to assign a genre to an album and then have that genre flow down to the tracks. So you would instead by required to add it to every single track.
mGraziano 2 Posted April 29, 2024 Posted April 29, 2024 I would think that track genre would have higher priority than album if it exists. I tested tracks that have a genre, for example, 'Instrumental Rock', and made sure the album did not. The Play/shuffle does not include the tracks with 'Instrumental Rock' unless the album does. And in another example, if the album has 'Instrumental Rock' but one for the tracks has a different genre, that track is still included. Even if that's by design, I assume under the 'Song >' section of the genre, that would be the track genre. It does display the right number of tracks with that genre but if I click either 'Play All' or 'Shuffle All' button the server hangs up for several minutes and it never plays.
EZEd 60 Posted April 30, 2024 Posted April 30, 2024 8 hours ago, Luke said: It’s by design because if it didn’t work that way, then you wouldn’t be able to assign a genre to an album and then have that genre flow down to the tracks. So you would instead by required to add it to every single track. Which is precisely what I do and is very easy to do when using MP3Tag meta editor. Each song file is tagged with the Genre. I also use multiple genre per album/song file and still believe that it is at least involved in the problem @Luke can you please go back and review the code about how this was implemented in server 4.7.x and re-implement that capability in the latest versions? This used to work perfectly. Also can you please post instructions on how to revert Emby Server back to previous versions to include where to get the executable file for reversion/reinstallation? Would appreciate...thanks
mGraziano 2 Posted May 25, 2024 Posted May 25, 2024 Just tried 4.9.0.21. The server still hangs up for several minutes and never plays when clicking either the 'Play All' or 'Shuffle All' button at the song level. For example, click 'Genres', click 'Progressive Rock', click 'Songs >', click either 'Play All' or 'Shuffle All' button.
Luke 42244 Posted May 25, 2024 Posted May 25, 2024 2 hours ago, mGraziano said: Just tried 4.9.0.21. The server still hangs up for several minutes and never plays when clicking either the 'Play All' or 'Shuffle All' button at the song level. For example, click 'Genres', click 'Progressive Rock', click 'Songs >', click either 'Play All' or 'Shuffle All' button. Hi, please let us know how the next build compares, thanks.
francoisp 13 Posted May 25, 2024 Author Posted May 25, 2024 (edited) Here are the tests I performed using a web client. I'm running server 4.9.0.22 beta. 1) I selected a Genre and clicked Shuffle at the "top": a playlist got generated after a few seconds. PASSED 2) Within the Genre, I clicked Shuffle from both the Albums and Songs pages. In both instances EmbyServer consumed a third of my CPU for several minutes before a playlist got generated. FAILED I also performed a test on my Google TV Chromecast by doing a Shuffle from a Genre. It was very fast at generating a playlist and play the first song. PASSED Edited May 25, 2024 by francoisp added server version 1
viking19 32 Posted May 25, 2024 Posted May 25, 2024 As this isn't specifically an AndroidTV app problem I was posting about it on this thread Latest update broke Genre even more, but the thread got sidetracked. With server v4.8.7 on either the web browser or the mobile app 3 of 5 ways to shuffle/play are broken, server 4.9.0.16 improved this to 2 of 5 but there has been no improvement up to 4.9.0.22. 1: Music->Genre->Icon Context Menu->Shuffle or Play : Working 2: Music->Genre->Main Page->Shuffle or Play : Working 3: Music->Genre->Artists->Shuffle or Play : Slow playlist creation, high cpu usage during that time (fixed in 4.9.0.16+) 4: Music->Genre->Albums->Shuffle or Play : Very slow playlist creation, high cpu usage during that time (mobile app just give up) 5: Music->Genre->Songs->Shuffle or Play : Slow playlist creation, high cpu usage during that time The speed is somewhat dependant on the number of items in the genre. 1
mGraziano 2 Posted June 9, 2024 Posted June 9, 2024 On 5/25/2024 at 10:40 AM, Luke said: let us know how the next build compares I tried 4.9.0.23. The server still hangs up for several minutes and never plays. Tested using chrome browser (Music->Genre->Songs->Shuffle or Play) and firestick app (selecting a Genre then selecting Play All, Shuffle All, or Add to Queue).
HFBoroni 3 Posted July 22, 2024 Posted July 22, 2024 Hi! I am assuming this issue has not been resolved. Would that be correct? And you're still working on a solution? Thanks!
Luke 42244 Posted July 23, 2024 Posted July 23, 2024 16 hours ago, HFBoroni said: Hi! I am assuming this issue has not been resolved. Would that be correct? And you're still working on a solution? Thanks! HI, yes we are looking into it. Thanks.
fahdb 1 Posted July 26, 2024 Posted July 26, 2024 hey! im brand new and clueless. can someone help me? how can i get an agent to connect me to a server??? i purchased a premier membership thinking its a streaming service lol idk what im doing tbh
Happy2Play 9812 Posted July 26, 2024 Posted July 26, 2024 (edited) 14 minutes ago, fahdb said: hey! im brand new and clueless. can someone help me? how can i get an agent to connect me to a server??? i purchased a premier membership thinking its a streaming service lol idk what im doing tbh Sound like you need to email billingsupport@emby.media Otherwise https://emby.media/support/articles/Quick-Start.html Quote Emby is NOT a media streaming service. We provide no content. Emby is a Personal Media Server platform. You must have your own server installed and your own media (or Live TV tuner). Please DO NOT purchase one of these items unless you are using your own server that you installed. Edited July 26, 2024 by Happy2Play 1
fahdb 1 Posted July 26, 2024 Posted July 26, 2024 5 minutes ago, Happy2Play said: Sound like you need to email billingsupport@emby.media Otherwise https://emby.media/support/articles/Quick-Start.html hey thanks for the reply i appreciate it. i did email them over an hour ago i didnt get a reply do they usually take long?
Happy2Play 9812 Posted July 26, 2024 Posted July 26, 2024 2 minutes ago, fahdb said: hey thanks for the reply i appreciate it. i did email them over an hour ago i didnt get a reply do they usually take long? Sorry only the admins can answer that but will guess it can as I really doubt someone watches it 24/7. 1
fahdb 1 Posted July 26, 2024 Posted July 26, 2024 Just now, Happy2Play said: Sorry only the admins can answer that but will guess it can as I really doubt someone watches it 24/7. thank u for the help
