hjason7812 35 Posted May 7, 2024 Posted May 7, 2024 25 minutes ago, Luke said: Hi, have you tried the instructions on our website? https://emby.media/truenas-server.html Yes that is for beta versions only not the stable version.
Luke 42237 Posted May 15, 2024 Posted May 15, 2024 On 5/7/2024 at 5:07 PM, hjason7812 said: Yes that is for beta versions only not the stable version. Actually that is for both.
hjason7812 35 Posted May 16, 2024 Posted May 16, 2024 16 hours ago, Luke said: Actually that is for both. Then why does it only install beta version only? The new stable version worked just fine with the pkg upgrade for the stable update.
Luke 42237 Posted May 23, 2024 Posted May 23, 2024 On 5/16/2024 at 9:54 AM, hjason7812 said: Then why does it only install beta version only? The new stable version worked just fine with the pkg upgrade for the stable update. What link are you using that is installing the beta version?
hjason7812 35 Posted May 23, 2024 Posted May 23, 2024 2 hours ago, Luke said: What link are you using that is installing the beta version? It's the links in the download section for truenas and freebsd theyre all beta versions. I've ised them all and they all install the beta version of emby not one is the official stable version
Luke 42237 Posted May 27, 2024 Posted May 27, 2024 On 5/23/2024 at 5:39 PM, hjason7812 said: It's the links in the download section for truenas and freebsd theyre all beta versions. I've ised them all and they all install the beta version of emby not one is the official stable version Right what I'm asking is what makes you think they are links to the beta? (Because they are not).
hjason7812 35 Posted May 28, 2024 Posted May 28, 2024 On 5/27/2024 at 2:01 AM, Luke said: Right what I'm asking is what makes you think they are links to the beta? (Because they are not). Well the one for truenas core when you run it in shell like it is it installs the latest beta version. And the freebsd one installs from scratch the latest beta version of emby. Always has for some reason and this is why I never use them since I figured this out and why I use the plug in stable emby in truenas core.. the added pic is from what you currently have on the download page for freebsd and as you can see it's 4.9 version which isn't out for stable. it's a beta version is it not? This is what I'm saying there's beta version in your download page and only beta versions which there's should be both stable official and beta someone keeps only putting beta there and on that same page in the description says clear as day "beta" please fix this and ad both to this oage not only one version.. Thank you
Luke 42237 Posted June 2, 2024 Posted June 2, 2024 OK since you're on TrueNAS, I thought you would have used the TrueNAS-specfic install instructions: https://emby.media/truenas-server.html Have you seen those?
shanbax 0 Posted June 18, 2024 Posted June 18, 2024 (edited) wrong info Edited June 18, 2024 by shanbax
bluemonkey07 590 Posted June 18, 2024 Posted June 18, 2024 I have encountered a few issues since attempting to update to 4.8.8.0. i sorted my auto organise issue by deleting the file organisation.db.... but i am still having issues with downloading subtitles and playing some videos. attached log of trying to download subtitles and a failed attempt to watch "this is spinal tap" which played fine before the update embyserver.txt
Luke 42237 Posted June 19, 2024 Posted June 19, 2024 On 6/18/2024 at 7:15 AM, Vidman said: I have encountered a few issues since attempting to update to 4.8.8.0. i sorted my auto organise issue by deleting the file organisation.db.... but i am still having issues with downloading subtitles and playing some videos. attached log of trying to download subtitles and a failed attempt to watch "this is spinal tap" which played fine before the update embyserver.txt 111.39 kB · 0 downloads Was an ffmpeg log generated?
bluemonkey07 590 Posted June 20, 2024 Posted June 20, 2024 (edited) 8 hours ago, Luke said: Was an ffmpeg log generated? i can not see a new ffmpeg log generated when trying to play. tho i do see in the logs that hardware decoding=true but i have hardware decoding disabled in my settings could this be causing problems? Edited June 20, 2024 by Vidman
Luke 42237 Posted June 20, 2024 Posted June 20, 2024 3 hours ago, Vidman said: i can not see a new ffmpeg log generated when trying to play. tho i do see in the logs that hardware decoding=true but i have hardware decoding disabled in my settings could this be causing problems? How did you install Emby Server?
bluemonkey07 590 Posted June 20, 2024 Posted June 20, 2024 i have had it running on my FreeNAS server for years at this point. i have 2 instances one from the plugin store that i update via the freenas interface and another manual jail that i update manually. both e exhibit the same issues
Adeni 0 Posted June 21, 2024 Posted June 21, 2024 minha sugestão é fazer um guia de instalação fácil para ajudar aqueles que não conseguem fazer isso sozinhos. Eu até tive alguns problemas ao instalar o emby no truenas e uso-o há anos.
bluemonkey07 590 Posted June 22, 2024 Posted June 22, 2024 heres a ffmpeg log of a failed play attempt. ffmpeg-directstream-179ebf96-62ae-481b-abb2-f400b1982a77_1.txt
Happy2Play 9811 Posted June 22, 2024 Posted June 22, 2024 1 hour ago, Vidman said: heres a ffmpeg log of a failed play attempt. ffmpeg-directstream-179ebf96-62ae-481b-abb2-f400b1982a77_1.txt 12.52 kB · 1 download Don't really know this platform but point to issue with jail version ld-elf.so.1: /usr/local/lib/libtasn1.so.6: Undefined symbol "strverscmp@FBSD_1.7"
bluemonkey07 590 Posted June 24, 2024 Posted June 24, 2024 thanks for the reply. I have solved the playback issues by installing a new jail from the community jail store and pointing the config dir to my old emby config dataset. I still have can not get subtitle downloading to work tho. Is this a known issue with open subtitle ATM?
Luke 42237 Posted June 24, 2024 Posted June 24, 2024 1 hour ago, Vidman said: thanks for the reply. I have solved the playback issues by installing a new jail from the community jail store and pointing the config dir to my old emby config dataset. I still have can not get subtitle downloading to work tho. Is this a known issue with open subtitle ATM? HI, let's look at an example: How to Report a Problem Thanks !
bluemonkey07 590 Posted June 25, 2024 Posted June 25, 2024 On 6/24/2024 at 11:56 AM, Luke said: HI, let's look at an example: How to Report a Problem Thanks ! here's a fresh log of an attempt to download subtitles
Luke 42237 Posted June 26, 2024 Posted June 26, 2024 On 6/25/2024 at 7:01 AM, Vidman said: here's a fresh log of an attempt to download subtitles @Vidmandid you forget to attach the log file?
Luke 42237 Posted June 26, 2024 Posted June 26, 2024 1 hour ago, Vidman said: sorry here it isembyserver.txt I would try reconfiguring your open subtitles credentials. it looks like you're not getting past the login stage.
bluemonkey07 590 Posted June 27, 2024 Posted June 27, 2024 thanks @Lukethat did the trick. i just had to login to opensubtitles.com 1
hjason7812 35 Posted September 29, 2024 Posted September 29, 2024 New update won't go through for truenas core. Did the pkg upgrade and pkg update in the shell of the jail and it stays on the 4.8.8.0 version still but it did update the things like the dependencies that's all it updated..
