hebertpl 5 Posted October 19, 2023 Posted October 19, 2023 On 1/19/2023 at 10:27 PM, ronaldonizula said: Il me semble que je suis en IPv6. Dans les choix de.la redirection je trouve mon ancien tel je le sélectionne donc en IPv6 mais ça ne fonctionne pas. Bonjour, Vous avez trouvex une solution? Cdlt, Philippe
Luke 42239 Posted November 1, 2023 Posted November 1, 2023 @hebertplHi, can you please describe your issue in more detail? Thanks !
hebertpl 5 Posted November 4, 2023 Author Posted November 4, 2023 hello Luke.. you've helped me many more times over the years.. I'm on SFR fibre and unable to access my server externally.... thanks
Lenders57 21 Posted November 7, 2023 Posted November 7, 2023 (edited) On 11/4/2023 at 2:35 PM, hebertpl said: hello Luke.. you've helped me many more times over the years.. I'm on SFR fibre and unable to access my server externally.... thanks J'ai la fibre sfr / red et ça fonctionne sans problème. J'ai également un nom de domaine Du coup c'est quoi le problème ? A savoir que j'ai une ipv4 full stack (sfr qui a essayé de me donner une ipv6 dynamique, j'ai dit non) Edited November 7, 2023 by Lenders57
Luke 42239 Posted November 8, 2023 Posted November 8, 2023 On 11/4/2023 at 9:35 AM, hebertpl said: hello Luke.. you've helped me many more times over the years.. I'm on SFR fibre and unable to access my server externally.... thanks @hebertpl I would suggest checking out our Connection Troubleshooter: Connectivity Please try the steps listed there and let us know which ones succeed and which ones do not. Thanks !
