zodac01 3 Posted July 23, 2023 Posted July 23, 2023 Hi, Is it normal for Emby fmto generate fresh audio fingerprints for TV shows that have been scanned/imported before? For example, I have old seasons of multiple that were imported long ago (some I have watched since importing, some not), and have had their 'skip intro' detection completed. However, almost every day when I check my dashboard I see my library scan hanging at ~94% as it generates fresh audio fingerprints. Is this normal, or is there some way to disable fingerprinting if one exists? Thanks!
Luke 42185 Posted July 24, 2023 Posted July 24, 2023 Hi there, why do you think it's generating fresh fingerprints?
rbjtech 5335 Posted July 24, 2023 Posted July 24, 2023 see - https://emby.media/community/index.php?/topic/120197-core-skip-intro-new-episodes-do-re-scan-of-all-episodes/#comment-1268355 @zodac01- A debug log of the events will show what's going on. 1
zodac01 3 Posted July 26, 2023 Author Posted July 26, 2023 On 24/07/2023 at 18:29, Luke said: Hi there, why do you think it's generating fresh fingerprints? I was seeing the following logs each day when I did a library scan, for the same show/season: 2023-07-26 15:38:31.913 Info App: Best title sequence for B:\TV\Show\Season 1\S01E01.mkv is 00:00:29.4776119 - 00:01:58.5323382. Confidence: 0.93 2023-07-26 15:38:34.510 Info App: Best title sequence for B:\TV\Show\Season 1\S01E02.mkv is 00:00:30.2238805 - 00:01:57.1641790. Confidence: 1 2023-07-26 15:38:37.114 Info App: Best title sequence for B:\TV\Show\Season 1\S01E03.mkv is 00:08:43.1343283 - 00:09:01.0447760. Confidence: 0.9 My understanding was if a time window + confidence level was being logged, it was generating a fresh fingerprint? On 24/07/2023 at 21:42, rbjtech said: see - https://emby.media/community/index.php?/topic/120197-core-skip-intro-new-episodes-do-re-scan-of-all-episodes/#comment-1268355 @zodac01- A debug log of the events will show what's going on. This actually helped me figure out what was going on - I guess the fingerprinting occurs for a full season if/when new episodes are added? I had some corrupted files from an old restore, and they were spread across a few different shows/seasons. I suppose when the ffprobe failed, it would still attempt to extract info from these files on subsequent scans, and therefore keep generating fingerprints for the season? The error I was getting was: ffprobe version 5.0.0-emby_2022_05_27-u1 Copyright (c) 2007-2022 the FFmpeg developers and softworkz for Emby LLC built with gcc 10.3.0 (Rev5, Built by MSYS2 project) [matroska,webm @ 0000022328760840] Format matroska,webm detected only with low score of 1, misdetection possible! [matroska,webm @ 0000022328760840] EBML header parsing failed file:A:\TV\Show\Season 1\S01E04.mkv: Invalid data found when processing input at Emby.Server.MediaEncoding.Probing.MediaProbeManager.GetMediaInfoInternal(String inputPath, String primaryPath, MediaProtocol protocol, String userAgent, Boolean extractChapters, String probeSizeArgument, Boolean isAudio, Boolean forceEnableLogging, CancellationToken cancellationToken) at Emby.Providers.MediaInfo.FFProbeVideoInfo.ProbeVideo[T](MetadataResult`1 metadataResult, MetadataRefreshOptions options, LibraryOptions libraryOptions, CancellationToken cancellationToken) at Emby.Providers.Manager.MetadataService`2.RunCustomProvider(ICustomMetadataProvider`1 provider, MetadataResult`1 itemResult, String logName, MetadataRefreshOptions options, LibraryOptions libraryOptions, RefreshResult refreshResult, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() I've since replaced/removed the corrupted files, and after a fresh run of generating fingerprints for the impacted seasons, things look to be running smoothly again. 1 1
Solution rbjtech 5335 Posted July 27, 2023 Solution Posted July 27, 2023 9 hours ago, zodac01 said: I was seeing the following logs each day when I did a library scan, for the same show/season: 2023-07-26 15:38:31.913 Info App: Best title sequence for B:\TV\Show\Season 1\S01E01.mkv is 00:00:29.4776119 - 00:01:58.5323382. Confidence: 0.93 2023-07-26 15:38:34.510 Info App: Best title sequence for B:\TV\Show\Season 1\S01E02.mkv is 00:00:30.2238805 - 00:01:57.1641790. Confidence: 1 2023-07-26 15:38:37.114 Info App: Best title sequence for B:\TV\Show\Season 1\S01E03.mkv is 00:08:43.1343283 - 00:09:01.0447760. Confidence: 0.9 My understanding was if a time window + confidence level was being logged, it was generating a fresh fingerprint? This actually helped me figure out what was going on - I guess the fingerprinting occurs for a full season if/when new episodes are added? I had some corrupted files from an old restore, and they were spread across a few different shows/seasons. I suppose when the ffprobe failed, it would still attempt to extract info from these files on subsequent scans, and therefore keep generating fingerprints for the season? The error I was getting was: ffprobe version 5.0.0-emby_2022_05_27-u1 Copyright (c) 2007-2022 the FFmpeg developers and softworkz for Emby LLC built with gcc 10.3.0 (Rev5, Built by MSYS2 project) [matroska,webm @ 0000022328760840] Format matroska,webm detected only with low score of 1, misdetection possible! [matroska,webm @ 0000022328760840] EBML header parsing failed file:A:\TV\Show\Season 1\S01E04.mkv: Invalid data found when processing input at Emby.Server.MediaEncoding.Probing.MediaProbeManager.GetMediaInfoInternal(String inputPath, String primaryPath, MediaProtocol protocol, String userAgent, Boolean extractChapters, String probeSizeArgument, Boolean isAudio, Boolean forceEnableLogging, CancellationToken cancellationToken) at Emby.Providers.MediaInfo.FFProbeVideoInfo.ProbeVideo[T](MetadataResult`1 metadataResult, MetadataRefreshOptions options, LibraryOptions libraryOptions, CancellationToken cancellationToken) at Emby.Providers.Manager.MetadataService`2.RunCustomProvider(ICustomMetadataProvider`1 provider, MetadataResult`1 itemResult, String logName, MetadataRefreshOptions options, LibraryOptions libraryOptions, RefreshResult refreshResult, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() I've since replaced/removed the corrupted files, and after a fresh run of generating fingerprints for the impacted seasons, things look to be running smoothly again. Good analysis - and I suspect that is exactly what it is doing. Remember, Chromaprint requires all the existing fingerprints from that Season to compare against (that's what the 'confidence' score is - it's a calculation.) If a FP doesn't exist, then it will try and generate it each time, thus keep looping.
