sameh1925 24 Posted May 10, 2023 Posted May 10, 2023 (edited) On this page https://emby.media/linux-server.html there are many versions of the server to download for Ubuntu, what is the difference between them, please explain in preference to use each of them Edited May 10, 2023 by sameh1925
Luke 42245 Posted May 10, 2023 Posted May 10, 2023 Hi, what is your system architecture? Once you know that, just choose one of the first three listed for Ubuntu,
Abobader 3485 Posted May 10, 2023 Posted May 10, 2023 @Luke Well he start a thread here: @sameh1925As I told you, the first file in the list at the download you post above, that what your cpu support. Also you still did not explain to us what was the problem when you installed the latest build.
sameh1925 24 Posted May 10, 2023 Author Posted May 10, 2023 (edited) قبل 4 ساعات قال أبو بكر: تضمين التغريدة حسنًا ، بدأ موضوعًا هنا: امينكما أخبرتك ، فإن الملف الأول في القائمة عند التنزيل الذي تنشره أعلاه ، هو ما يدعمه وحدة المعالجة المركزية. كما أنك ما زلت لم تشرح لنا ما كانت المشكلة عند تثبيت أحدث إصدار. انت مش بتكمل رد عليه ثانيا انا عايز اعرف الفرق بينهم Edited May 10, 2023 by sameh1925
Abobader 3485 Posted May 10, 2023 Posted May 10, 2023 First, we here to solve the issue about any issue you may face with your Emby server, we reply to you about the correct file to get for your CPU hardware: emby-server-deb_4.7.11.0_amd64.deb For the part about the CPU's deferential matters, simply search the internet, seem you misunderstand about the download for correct CPU model, you only can use the one for your hardware. You said before you faced some problem when you installed the latest Emby server build, if you manage to update your Emby server and again face some problem, please explain to us what the problem and as well provide us with Emby logs as it explain howto in the other thread in the Arabic forum section. Thanks.
sameh1925 24 Posted May 10, 2023 Author Posted May 10, 2023 31 minutes ago, Abobader said: First, we here to solve the issue about any issue you may face with your Emby server, we reply to you about the correct file to get for your CPU hardware: emby-server-deb_4.7.11.0_amd64.deb For the part about the CPU's deferential matters, simply search the internet, seem you misunderstand about the download for correct CPU model, you only can use the one for your hardware. You said before you faced some problem when you installed the latest Emby server build, if you manage to update your Emby server and again face some problem, please explain to us what the problem and as well provide us with Emby logs as it explain howto in the other thread in the Arabic forum section. Thanks. تمام اخي شكرا لاهتمامك بعد تنزيل حزمه امبي اين اضع الحزمه في مجلدات الابنتو
Abobader 3485 Posted May 10, 2023 Posted May 10, 2023 هلا اخى الكريم بعد تحميل الملف وانت فى نفس المجلد اعمل الامر الاتى sudo dpkg -i emby-server-deb_4.7.11.0_amd64.deb وبعد ذلك طبعا من متصفح الانترنت ضع الامر الاتى كما تعرف http://localhost:8096 هذا طبعا من نفس الكومبيتر اما اذا من كومبيتور اخر وهنا استعمل الابى للابونتو وكمثال http://192.168.1.1:8096 تحياتى
sameh1925 24 Posted May 10, 2023 Author Posted May 10, 2023 30 minutes ago, Abobader said: هلا اخى الكريم بعد تحميل الملف وانت فى نفس المجلد اعمل الامر الاتى sudo dpkg -i emby-server-deb_4.7.11.0_amd64.deb وبعد ذلك طبعا من متصفح الانترنت ضع الامر الاتى كما تعرف http://localhost:8096 هذا طبعا من نفس الكومبيتر اما اذا من كومبيتور اخر وهنا استعمل الابى للابونتو وكمثال http://192.168.1.1:8096 تحياتى تمام شكرا لك 1
Abobader 3485 Posted May 10, 2023 Posted May 10, 2023 Let us know how thing goes and good luck. اذا صادفت اى مشاكل الرجاء تحميل سجل خادم امبى وبالتوفيق اخى الكريم
sameh1925 24 Posted May 10, 2023 Author Posted May 10, 2023 9 hours ago, Abobader said: Let us know how thing goes and good luck. اذا صادفت اى مشاكل الرجاء تحميل سجل خادم امبى وبالتوفيق اخى الكريم تمام تسلم تم التحديث ولم اواجه اي مشاكل حتي الان 1
