28charro 0 Posted February 27, 2023 Posted February 27, 2023 Video files while playing they go out of sync,and when that happens i have to skip back to fix it,i have synology ds720+ and nvidia tv pro,and also 2 sony android tvs any help please and Thanks
Luke 42242 Posted February 27, 2023 Posted February 27, 2023 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
28charro 0 Posted February 28, 2023 Author Posted February 28, 2023 It's the same problem as in this post: Bill LeDuc Regular 4 34 Posted September 25, 2021 (edited) I believe this issues is not clearly stated here and i'm surprised there isn't more complaints. I'm using an nvidia Shield pro with Emby and I am having constant sync issues. The issue is not in the source. I will be playing a video (many different formats) and audio is fine. Then I may pause it skip forward or skip back and the audio will be out of sync. Then if I skip back one or two times the audio is back in sync. It's very frustrating. It's obviously a problem with the the player. The same content plays fine on other devices like a LG TV. Thankfully, the skip back fix I found on an old post about this problem or I would not be able to use Emby on my Shield. So this problem has been around awhile. Edited September 25, 2021 by Bill LeDuc
Luke 42242 Posted March 17, 2023 Posted March 17, 2023 @28charro can you please provide an example? Thanks !
