renefw 9 Posted May 5 Posted May 5 I saved the script as CertRenew.sh: #!/bin/sh now="$(date)" # Password for exported PFX PFX_PASSWORD="my password" # Output file PFX_FILE="/share/SSL-Certificate/emby.p12" # Log file PFX_Log="/share/SSL-Certificate/check-p12.log" # Search filesystem for latest QNAP cert file CRT_FILE=$(find /mnt -type f -name "cert" 2>/dev/null \ | while read -r file; do stat -c "%Y %n" "$file" done \ | sort -nr \ | head -n 1 \ | cut -d' ' -f2-) if [ -z "$CRT_FILE" ]; then echo "$now - No certificate file found." >> $PFX_Log exit 1 fi CERT_DIR=$(dirname "$CRT_FILE") KEY_FILE="$CERT_DIR/key" echo "CERT_DIR: $CERT_DIR" >> $PFX_Log echo "CRT_FILE: $CRT_FILE" >> $PFX_Log echo "KEY_FILE: $KEY_FILE" >> $PFX_Log if [ ! -f "$KEY_FILE" ]; then echo "$now - Private key not found: $KEY_FILE" >> $PFX_Log exit 1 fi if ! find "$CRT_FILE" -mtime -1 | grep -q .; then echo "$now - Certificate key has not changed" >>$PFX_Log else echo "$now - Using certificate directory: $CERT_DIR" >> $PFX_Log echo "$now - Certificate: $CRT_FILE" >> $PFX_Log echo "$now - Private Key: $KEY_FILE" >> $PFX_Log # Build the OpenSSL command OPENSSL_CMD="openssl pkcs12 -export \ -out \"$PFX_FILE\" \ -inkey \"$KEY_FILE\" \ -in \"$CRT_FILE\" \ -passout pass:$PFX_PASSWORD" # rename existing pfx file mv -f $PFX_FILE $PFX_FILE.old 2>/dev/null # Execute eval "$OPENSSL_CMD" if [ $? -eq 0 ]; then echo "$now - PFX successfully created: $PFX_FILE" >> $PFX_Log else echo "$now - PFX creation failed." >> $PFX_Log exit 1 fi fi 1
renefw 9 Posted May 5 Posted May 5 How can I tell if Emby needs to be restarted if the emby.p12 file has been updated? The only thing I can think of is to leave Emby and the NAS running until the old certificate expires. Since that would take about a month, it's probably not feasible, as I either update the NAS firmware in the meantime, if an update is available, or Emby automatically restarts during an unused moment when a plugin is updated. How would I be able to see this in Emby, or compare the before and after? 29 minutes ago, sa2000 said: Ok – Ihre emby.p12 wurde also manuell von Ihnen aktualisiert und läuft im Juni 2026 ab. Wenn dies der Fall ist, müssen Sie jetzt nichts tun, um es zu aktualisieren No, it was updated by the script that I was supposed to undo. 32 minutes ago, sa2000 said: Ich bin mir sicher, dass es bei viel komplexeren Skripten möglich sein könnte, es ganz anders zu machen - das Ablaufdatum des Zertifikats zu vergleichen und die emby pfx-Datei zu aktualisieren, wenn sie im Rückstand ist - Sie können Starten Sie einen Dialog mit chatGPT und erkunden Sie diese Idee I'll wait until the end of the month to see if the script works as intended. In any case, thank you very much for your expert support. If it works, I can try extending it via chatGPT, as you suggested... Thank you so much! 1
renefw 9 Posted May 5 Posted May 5 Did I understand you correctly that I could theoretically set the cron job to run every 6 hours? However, on the days the certificate was updated, wouldn't it then be created 3 or 4 times (as with a daily cron job) and recorded 4 times in the check-p12.log file? Could this cause any other problems?
sa2000 890 Posted May 5 Posted May 5 7 minutes ago, renefw said: I could theoretically set the cron job to run every 6 hours? However, on the days the certificate was updated, wouldn't it then be created 3 or 4 times (as with a daily cron job) you could 7 minutes ago, renefw said: Could this cause any other problems? I don't think so - not sure how often the certificate pfx file is read by emby server and if only on launch. Each time the file is replaced, it will not exist for a very short time
sa2000 890 Posted May 7 Posted May 7 @renefwFYI I am working on a new script that will cover QTS and QuTS and will only update emby server pfx file once and will have option to tell Emby Server to use the updated file rather than wait for next server restart
renefw 9 Posted May 7 Posted May 7 Thanks a lot for the info! That sounds absolutely fantastic! You mention that "the Emby server's PFX file is updated only once." Do you mean that the PFX file is updated just a single time whenever the certificate is renewed? That appears to be exactly what I suggested the day before yesterday as a potential improvement for the current script. Assuming you manage to have it ready by May 25, 2026, I would be happy to install it on my system and provide you with feedback once I have updated both of my NAS systems to QuTS hero. The only crucial question for me is: where will I be able to find the finished script? Will you post it within this thread, link to it here, or could you please send it to me via private message?
sa2000 890 Posted May 7 Posted May 7 13 minutes ago, renefw said: You mention that "the Emby server's PFX file is updated only once." Do you mean that the PFX file is updated just a single time whenever the certificate is renewed? That appears to be exactly what I suggested the day before yesterday as a potential improvement for the current script. Assuming you manage to have it ready by May 25, 2026, I would be happy to install it on my system and provide you with feedback once I have updated both of my NAS systems to QuTS hero. The only crucial question for me is: where will I be able to find the finished script? Will you post it within this thread, link to it here, or could you please send it to me via private message? It will remember the UTC modfied date/time of the QNAP cert file and only convert to pfx if that is higher from last update - it does mean the first time you run the script it will convert the cert file but after that it should not do any unnecessary updates I am limited in testing it because my QNAP is ancient and I am trying to see if I can get it to have a cert file ! (It is using legacy .pem file)
renefw 9 Posted May 7 Posted May 7 That is exactly what I suggested the day before yesterday! I am absolutely delighted that you have decided to go ahead with it after all. I am sure many other Emby users will be thrilled once it is finished! Since I am extremely grateful to you, I don't view it as a major issue that you only have a very old QNAP device available for testing. I have two current models—a TS-264 and a TS-664—both running QuTS hero, as I mentioned previously. Unfortunately, I won't have quite as much time tomorrow (Friday) as I did yesterday; however, on Monday, my availability should be just as open as it was yesterday. I still have the expired .p12 certificate on hand. Therefore, I would be more than happy to assist: if you could send me the scripts for testing—along with instructions on what information you need me to extract via PuTTY or the log files—I would be delighted to do so as quickly as possible. You are welcome to decide whether you would prefer to handle this via this thread or via a private message. What do you think?
sa2000 890 Posted May 7 Posted May 7 10 minutes ago, renefw said: Since I am extremely grateful to you, I don't view it as a major issue that you only have a very old QNAP device available for testing. I have two current models—a TS-264 and a TS-664—both running QuTS hero, as I mentioned previously. Unfortunately, I won't have quite as much time tomorrow (Friday) as I did yesterday; however, on Monday, my availability should be just as open as it was yesterday. I still have the expired .p12 certificate on hand. Therefore, I would be more than happy to assist: if you could send me the scripts for testing—along with instructions on what information you need me to extract via PuTTY or the log files—I would be delighted to do so as quickly as possible. Thank you for your offer. My old QNAP is on QTS 3.3.4 and version 4.2 onwards is required I will continue through private messaging until we get the script working and then i will post it here Thank you
sa2000 890 Posted May 8 Posted May 8 4 hours ago, renefw said: How do I delete ".last_processed_time"? The "rm" command is what you use in linux to delete a file so it would be "rm" followed by a space and the full path to the file. Ihave given you the exact command in Private Message
sa2000 890 Posted May 11 Posted May 11 (edited) Thanks to @renefwfor helping me develop the QNAP script further by running a lot of tests for me. And of course great thanks to @dieffe70who provided the original script. The new script should work on QuTS as well as QTS It allows for specifying a fixed path for the QNAP renewed certificate (QTS) or no path specified and the filesystem is searched for the latest certificate (QuTS) Emby Server is notified and updated with the new certificate (and password) when a new QNAP Certificate is detected, The conversion and emby server update happens only once after renewal. Emby Server would automatically restart when idle time is detected after the update. There is an option to disable the auto update of Emby Server The pfx filenames used are unique each time giving as part of the filename, the time (UTC) when QNAP renewed the certificate and the time (UTC) when the converrsion to a pfx file for Emby Server was done. The script would purge old pfx files created with the same filename syntax when they are found to be over 6 months old. The new script is here - save it as "RenewCert.sh" on the QNAP CertRenew_2026-05-11.sh It has been preset to assume that you will have this share directory available on the QNAP /share/Emby-SSL-Certificate The file as it is, does not have any windows inserted carriage return characters at end of lines - so should be usable on the QNAP directly Edit the script file to add your pfx password, your emby server local IP address and port - if different from 8096. Also to notify Emby Server, you will need an Api Key which you can obtain through the emby server dashboard, Advaned / Api Keys / +New Api Key And if you do not know want Emby Server to be updated, flip the setting for AUTO_EMBY_UPDATE to "NO" Lines to change PFX_PASSWORD="Replace-This-With-Your-PFX-Password" AUTO_EMBY_UPDATE="YES" EMBY_API_KEY="Replace-This-With-Your-an-API-Key-For-EmbyServer" EMBY_IP="x.x.x.x EMBY_PORT="8096" The script will maintain a log file within the same directory The log file will be named "cert-2-pfx-check.log" and with this path /share/Emby-SSL-Certificate/cert-2-pfx-check.log If you do end up with the sctipt having lines ending with CR LF instead of the Linux LF, then you can use the tool dos2unix to correct that You can check what your end of line characters are by viewing the sh file using Notepad++ and selecting View / Show Symbols / View All Characters On the QNAP ensure ssh is enabled - See QNAP: How Do I Access My QNAP NAS Using ssh For Windows, use PuTTY For MacOS, use existing Utility / Terminal tool Suggest the script is place in the pre-defined directory, so you end up with it named and placed here /share/Emby-SSL-Certificate/RenewCert.sh Ensure it has execute permissions, so in your terminal ssh session, enter this command chmod +x /share/Emby-SSL-Certificate/RenewCert.sh Suggest you first test the script before adding it to the crontab to run daily To test the script /bin/sh /share/Emby-SSL-Certificate/RenewCert.sh Inspect the cert-2-pfx-check.log after running it to see of completed ok The first time the script runs, it will update Emby Server and lead to a restart when idle. To add the script to crontab, read the QNAP Article here QNAP: How to- Add Jobs to crontab to schedule a job Learn how to edit using the linux editor "vi" - a good basic guide here Introduction: vi editor It is suggested that you run the script once daily - at say 1am The following line would need adding to the end of the /etc/config/crontab file 0 1 * * * /bin/sh /share/Emby-SSL-Certificate/CertRenew.sh It is important that after you edit, you exit the editor and run the following to pick the changes and restart crontab crontab /etc/config/crontab && /etc/init.d/crond.sh restart You can now check that your cron tab line was added by executing this command crontab -l Check the "cert-2-pfx-check.log the following day. There should be entries at 1am for the check on the QNAP certificate and whethere a change was detected Edited May 11 by sa2000
sa2000 890 Posted May 30 Posted May 30 This solution is now documented in Emby Server Documentation KB Article QNAP SSL Certificate Renewal Thank you @dieffe70for providing the initial script on which I based the one appearing in the article and thank you @renefwfor all the help with testing on the QuTS hero QNAP NAS.
renefw 9 Posted May 30 Posted May 30 @sa2000 Thank you very much for the mention. I was more than happy to do it! 1
RedNo7 43 Posted June 9 Posted June 9 I have been going through this thread. I think I haver it all sorted except for `PFX_PASSWORD`. Where/how am I supposed to obtain it?
sa2000 890 Posted June 9 Posted June 9 7 minutes ago, RedNo7 said: Where/how am I supposed to obtain it You make it up. It is an output rather than input. Whatever you specify will be set for the pfx file and that would be the password set in Emby Server when it is updated
RedNo7 43 Posted June 9 Posted June 9 (edited) 28 minutes ago, sa2000 said: You make it up. perfect. Thanks, @sa2000 (I see you also answered over on Github) edit: 2 follow-up questions: - I had already run the script (to test it) with the default writing for PFX_PASSWORD. I have now changed it to something random and long but the script will not update the cert as it has not changed. Is this an issue? - How does Emby know PFX_PASSWORD in order to read the cert or is that actually not necessary? Edited June 9 by RedNo7
sa2000 890 Posted June 9 Posted June 9 1 hour ago, RedNo7 said: I had already run the script (to test it) with the default writing for PFX_PASSWORD. I have now changed it to something random and long but the script will not update the cert as it has not changed. Is this an issue? - How does Emby know PFX_PASSWORD in order to read the cert or is that actually not necessary? It was designed to update Emby Server only once after a QNAP certificate change is detected with the first run being an exception where it would be treated as a new certificate To force it to run as a first run again and update Emby Server, just delete this file in the configured path and rerun the script. .last_processed_time
RedNo7 43 Posted June 9 Posted June 9 thanks - done. Do I need to share PFX_PASSWORD with Emby somehow?
sa2000 890 Posted June 9 Posted June 9 9 minutes ago, RedNo7 said: Do I need to share PFX_PASSWORD with Emby somehow There is a field for it within the Network Settings but with the script doing an auto update to Emby, you do not need to do anything yourself as the update to Emby will be for both the certificate and its password and will be active on the auto restart after the update when Emby Server detects idle state 1
