MarcusJ 18 Posted August 30, 2022 Author Posted August 30, 2022 Thanks Rob. That's actually very encouraging. I'll drop the provider's XML and try the DirectTV setup.
BillOatman 597 Posted August 31, 2022 Posted August 31, 2022 5 hours ago, RobDenny said: EPG data from your provider, as in my experience its c.r.a.p Provider EPG data being crap is pretty much a universal truth Another option for guide data along with a way to manicure your providers channels into something useful can be found in this thread
darrenkdean 31 Posted September 3, 2022 Posted September 3, 2022 On 8/30/2022 at 1:29 PM, RobDenny said: Is the emby EPG that bad? I find it really good! Has all the episode data and everything. No. Emby EPG is very good. When you're working with an IPTV Provider that offers several thousand channels, it can be time consuming to associate the guide data with the channel, upgrade the channel icon provided to color, categorize the channels the way you want them, & order the channel numbers. A m3u editor makes quick work of this. Best-
buster714 0 Posted March 9, 2024 Posted March 9, 2024 Is there any way to select a channel when setting up Emby channel order and move it to the top of the channel list quickly? Drag and drop is great but dragging channel 4000 and scrolling to the top if the list to drop it takes FOREVER.
Luke 42241 Posted March 10, 2024 Posted March 10, 2024 On 3/9/2024 at 8:08 AM, buster714 said: Is there any way to select a channel when setting up Emby channel order and move it to the top of the channel list quickly? Drag and drop is great but dragging channel 4000 and scrolling to the top if the list to drop it takes FOREVER. Hi, yes improvements to this are coming. Thanks for the feedback.
