CassTG 113 Posted July 15, 2022 Posted July 15, 2022 As per the Ubuntu thread i downloaded the latest theatre via DNF as your flatpak does nothing when clicking on it (opens app store for install but just goes to app store home screen which is by the way the only flatpak that has done that) Go to play various files and it just sits there with a spinning circle, for minutes on end. This is on 4.8.0.3 beta and latest DNF install as of today. Whats worse is if it is set to maximised when you try to switch to a different desktop it pulls u back to the emby viewpoint every time, this is most likely fedora however Anyways zero issues showing in the log no errors but also no playback position update info either
Luke 42239 Posted August 12, 2022 Posted August 12, 2022 Hi @CassTG can you try starting Theater from the terminal and then supplying the complete terminal output? Thanks.
CassTG 113 Posted August 13, 2022 Author Posted August 13, 2022 16 hours ago, Luke said: Hi @CassTG can you try starting Theater from the terminal and then supplying the complete terminal output? Thanks. i shall do so and report back 1
Luke 42239 Posted August 16, 2022 Posted August 16, 2022 Hi, first I would update to the new 3.0.16 release: https://emby.media/emby-theater-linux.html Then if the issue persists, please provide the information I requested above. Thanks !
CassTG 113 Posted September 10, 2022 Author Posted September 10, 2022 (edited) Hi sorry for the delay @Luke been manic. I had wiped my Fedora install and now i have a good stable daily driver, i have just installed 3.0.16. See results below: Flatpak version - Does not install / run RPM version via Emby Guide - Installs fine, shortcut created but app does not open at all If i try via terminal to start it : $ sudo emby-theater /opt/emby-theater/electron/emby-theater: /opt/emby-theater/lib/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /lib64/libicuuc.so.69) Edited September 12, 2022 by CassTG
CassTG 113 Posted September 18, 2022 Author Posted September 18, 2022 SO manually installed the Flatpak version (other FP bundles open Fedoras app store to install but emby does not) and all seems fine. 1
