johnbajer 3 Posted June 30, 2022 Posted June 30, 2022 (edited) Hello, after update it will not work anymore. It does respond to ping, but will not work. I use Truenas 12.07 I have installed emby version 4.7.4.0 It says: Unable to connect Firefox can’t establish a connection to the server at 192.168.1.100:8096. The site could be temporarily unavailable or too busy. Try again in a few moments. If you are unable to load any pages, check your computer’s network connection. If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web. Edited June 30, 2022 by johnbajer
johnbajer 3 Posted June 30, 2022 Author Posted June 30, 2022 I have installed via Truenas Plugins. 12.3-RELEASE-p5
johnbajer 3 Posted June 30, 2022 Author Posted June 30, 2022 Just now, johnbajer said: None of the emby listed work.
johnbajer 3 Posted June 30, 2022 Author Posted June 30, 2022 I have been using it with no issues up to today.
Luke 42237 Posted June 30, 2022 Posted June 30, 2022 Additionally it's possible you may be able to get your existing jail to work by enabling mlock on it.
johnbajer 3 Posted June 30, 2022 Author Posted June 30, 2022 I do not get what to do. It is a clear bug. When will it be resolved?
johnbajer 3 Posted June 30, 2022 Author Posted June 30, 2022 I have erased emby jail and install it back again. Also I installed emby-stable on another IP. None of them would work.
Luke 42237 Posted June 30, 2022 Posted June 30, 2022 Just now, johnbajer said: I do not get what to do. It is a clear bug. When will it be resolved? Hi, what i'm saying is that you installed a community package that wasn't put together by us, and therefore we may not have all of the answers about how to troubleshoot it. For the best results possible, the best thing to do is follow our official install instructions: https://emby.media/truenas-server.html
Luke 42237 Posted June 30, 2022 Posted June 30, 2022 The reason why this matters is because that community package is missing components that our official install process has. Having said that, you might be able to get the existing jail to work again by enabling mlock using this procedure here:
johnbajer 3 Posted June 30, 2022 Author Posted June 30, 2022 do you know when the missing components will be included on the community version?
Luke 42237 Posted June 30, 2022 Posted June 30, 2022 1 minute ago, johnbajer said: do you know when the missing components will be included on the community version? I'm actually working on putting together a pull request to submit them to their github repository. After that it's a question of whether they will accept them or not, and how long they will take to incorporate them. The last time I submitted something to them to try and improve the community package it took them a few weeks before they finally merged it in.
johnbajer 3 Posted June 30, 2022 Author Posted June 30, 2022 It will not work after following that procedure.
johnbajer 3 Posted June 30, 2022 Author Posted June 30, 2022 (edited) I did SSH as root to my server then iocage set allow_mlock=1 emby as emby is the name of my jail. restarted it is still not working Edited June 30, 2022 by johnbajer
NachoMan77 1 Posted July 1, 2022 Posted July 1, 2022 On 6/30/2022 at 12:04 AM, Luke said: Is any emby server log file generated? Hi Luke, I'm having the same problem. Here's my log file. Thanks! embyserver.txt
Luke 42237 Posted July 4, 2022 Posted July 4, 2022 I've submitted a pull request that should correct this: https://github.com/freenas/iocage-plugin-emby/pull/7 Now we just have to wait and see if the maintainers of the Emby TrueNAS plugin will merge it in and publish an update. In the meantime you could install Emby Server by manually installing our package using the instructions here: https://emby.media/truenas-server.html This is put together by us and will work. Please let us know if this helps. Thanks. 1
NachoMan77 1 Posted July 4, 2022 Posted July 4, 2022 1 hour ago, Luke said: I've submitted a pull request that should correct this: https://github.com/freenas/iocage-plugin-emby/pull/7 Now we just have to wait and see if the maintainers of the Emby TrueNAS plugin will merge it in and publish an update. In the meantime you could install Emby Server by manually installing our package using the instructions here: https://emby.media/truenas-server.html This is put together by us and will work. Please let us know if this helps. Thanks. Thanks! Do you have a direct link for the correct overlay/usr/local/etc/rc.d/emby-server file? I'd prefer to replace the offending file in the meantime instead of dealing with reinstalling the offiicial package.
damaddbomma 0 Posted July 6, 2022 Posted July 6, 2022 Luke, On the instructions to install it ... do we do that from the main shell or a shell within a jail? Also, the link to adding storage to Emby server is returning a 404 Thanks!
Luke 42237 Posted July 6, 2022 Posted July 6, 2022 17 minutes ago, damaddbomma said: Luke, On the instructions to install it ... do we do that from the main shell or a shell within a jail? Also, the link to adding storage to Emby server is returning a 404 Thanks! Hi, what link exactly do you mean?
damaddbomma 0 Posted July 7, 2022 Posted July 7, 2022 Luke, You had given a link on how to install directly instead of using the community version. On that page is a link on how to add storage to the jail. That link is broken... Probably because it is pointing to version 11 of the Freenas manual.
Carlo 4561 Posted July 7, 2022 Posted July 7, 2022 Hi, I would take a look at the manual/documentation here for working with storage pools and expanding storage. https://www.truenas.com/docs/core/coretutorials/jailspluginsvms/jails/settingupjailstorage/ Typically you don't want to store your data inside the container but outside on a ZFS vdev. This allows you to install a newer jail quite easily. Are you running ZFS?
