Audiomixer 374 Posted June 11, 2022 Posted June 11, 2022 15 minutes ago, ebr said: That's very interesting. Perhaps it was the sound effects causing the issue... I dont think so. It seems stable with this setting set either way.
FrostByte 5454 Posted June 11, 2022 Posted June 11, 2022 Agree. It very well could be that or the Dolby Process which I turned off also, or the combination of both being on. The combination of the two being on is what triggered the sound effects issue on the OSD for both TrueHD and DTS-HD for both Audiomixer and myself.
ebr 16337 Posted June 11, 2022 Posted June 11, 2022 4 minutes ago, Audiomixer said: I dont think so. It seems stable with this setting set either way. The app is no longer sending any navigation sound effects when bitstreaming audio.
FrostByte 5454 Posted June 11, 2022 Posted June 11, 2022 4 minutes ago, Audiomixer said: I dont think so. It seems stable with this setting set either way. Ahh, so you turned both back on and the FF DTS-HD without issue using .77?
ebr 16337 Posted June 11, 2022 Posted June 11, 2022 1 minute ago, FrostByte said: Ahh, so you turned both back on and the FF DTS-HD without issue using .77? System sounds will no longer matter because the app is no longer trying to trigger them.
FrostByte 5454 Posted June 11, 2022 Posted June 11, 2022 1 minute ago, ebr said: System sounds will no longer matter because the app is no longer trying to trigger them. However, with .77 and both those options on both Audiomixer and I still get the sound issue with the OSD.
ebr 16337 Posted June 11, 2022 Posted June 11, 2022 1 minute ago, FrostByte said: However, with .77 and both those options on both Audiomixer and I still get the sound issue with the OSD. In exactly what scenario?
Audiomixer 374 Posted June 11, 2022 Posted June 11, 2022 (edited) 10 minutes ago, FrostByte said: Ahh, so you turned both back on and the FF DTS-HD without issue using .77? Correct. The major factor it seems is the DAP switch. Edited June 11, 2022 by Audiomixer
FrostByte 5454 Posted June 11, 2022 Posted June 11, 2022 (edited) 6 minutes ago, ebr said: In exactly what scenario? Turn both Dolby processing and Systems sounds on 2019 Shield (you have to have both on, turning one or the other off won't produce the error) Start a movie with TrueHD Atmos or DTS:X Click Down on remote to bring up the OSD Now start scrolling right I immediately get a slight pause in sound and then static using .77 When I fell back to .75 I can't reproduce this Edited June 11, 2022 by FrostByte
Audiomixer 374 Posted June 11, 2022 Posted June 11, 2022 Just now, FrostByte said: Turn both Dolby processing and Systems sounds on 2019 Shield (you have to have both on, turning one or the other off won't produce the error) Start a movie with TrueHD Atmos or DTS:X Click Down on remote to bring up the OSD Now start scrolling right I immediately get a slight pause in sound and the static using .77 When I fell back to .75 I can't reproduce this I would add to that DTS HD MA as well but @FrostByte sums it up exactly. The FF on DTS-HD audio regardless of those two settings seems solved. 1
ebr 16337 Posted June 12, 2022 Posted June 12, 2022 16 hours ago, FrostByte said: Turn both Dolby processing and Systems sounds on 2019 Shield (you have to have both on, turning one or the other off won't produce the error) Start a movie with TrueHD Atmos or DTS:X Click Down on remote to bring up the OSD Now start scrolling right I immediately get a slight pause in sound and then static using .77 When I fell back to .75 I can't reproduce this What does stats for nerds show for the audio playback?
FrostByte 5454 Posted June 12, 2022 Posted June 12, 2022 Says Direct for audio for both TrueHD Atmos and DTS:X. The soundbar even displays that so it should be passing everything correctly. 1
Juan Simón 12 Posted June 15, 2022 Author Posted June 15, 2022 I have updated my NVidia Shield to the june beta firmware but the problem persist.
ebr 16337 Posted June 15, 2022 Posted June 15, 2022 5 hours ago, Juan Simón said: I have updated my NVidia Shield to the june beta firmware but the problem persist. Hi. Exactly which problem?
Juan Simón 12 Posted June 15, 2022 Author Posted June 15, 2022 4 hours ago, ebr said: Hi. Exactly which problem? The one I reported when I opened this thread. The rest of the posts from other people are about topics that I don't know if they are related to my problem.
ebr 16337 Posted June 15, 2022 Posted June 15, 2022 Okay, thanks. There were recent discussions of other problems so I wanted to confirm. I'm not really sure why this would be solved for some and not others.
Juan Simón 12 Posted June 15, 2022 Author Posted June 15, 2022 Just now, Audiomixer said: Did you update the ATV to beta .77? What is ATV? I have upgraded to the latest beta of Nvidia Shield TV. The June beta that it released a few days ago.
FrostByte 5454 Posted June 15, 2022 Posted June 15, 2022 41 minutes ago, Juan Simón said: What is ATV? I have upgraded to the latest beta of Nvidia Shield TV. The June beta that it released a few days ago. ATV = AndroidTV. Version .77 is the latest beta
Juan Simón 12 Posted June 15, 2022 Author Posted June 15, 2022 2 hours ago, FrostByte said: ATV = AndroidTV. Version .77 is the latest beta But Android TV is in Nvidia Shield TV firmware. How can I update Android TV on an Nvidia Shield?
Audiomixer 374 Posted June 15, 2022 Posted June 15, 2022 We are talking about Emby’s android TV client. According to your original post you are already running a beta for this which is version 2.0.75g. You want the latest beta which is 2.0.77g.
Juan Simón 12 Posted June 16, 2022 Author Posted June 16, 2022 Ok, so please stop with the acronyms and write more clearly. Android TV is one thing and Emby client for Android TV is another. Yes, the client is in the latest beta version. The problem persists. I play a movie with DTS-HD audio, press fast forward 3 times and the image is already "stuck".
ebr 16337 Posted June 16, 2022 Posted June 16, 2022 7 hours ago, Juan Simón said: Ok, so please stop with the acronyms and write more clearly. Android TV is one thing and Emby client for Android TV is another. Yes, the client is in the latest beta version. The problem persists. I play a movie with DTS-HD audio, press fast forward 3 times and the image is already "stuck". Can you confirm the Nvidia firmware version?
Audiomixer 374 Posted June 16, 2022 Posted June 16, 2022 (edited) 9 hours ago, Juan Simón said: Ok, so please stop with the acronyms and write more clearly. Android TV is one thing and Emby client for Android TV is another. Yes, the client is in the latest beta version. The problem persists. I play a movie with DTS-HD audio, press fast forward 3 times and the image is already "stuck". I cannot duplicate what you are seeing with the FF 3 times. For dolby audio processing, is your setting on or off? Edited June 16, 2022 by Audiomixer
FrostByte 5454 Posted June 16, 2022 Posted June 16, 2022 @Juan Simóndo you have Rewind Resume set? If not, could you try setting it to 10 seconds and see if that helps any? It may require you to set it on both server and client, not sure.
