Luke 42237 Posted June 25, 2022 Posted June 25, 2022 56 minutes ago, Vidman said: it didn't work because it didn't update and instead installed another copy of emby-server Why exactly do you think it installed another copy?
bluemonkey07 590 Posted June 25, 2022 Author Posted June 25, 2022 (edited) because it installed another copy 2 hours ago, Luke said: Why exactly do you think it installed another copy? The first time i issued the commands i had a jail called emby-server running the second time i had another jail called emby-server_1 Edited June 25, 2022 by Vidman
Luke 42237 Posted June 30, 2022 Posted June 30, 2022 Are you still having an issue of a double install? Are you sure one of them isn't the community plugin installed through the GUI?
bluemonkey07 590 Posted June 30, 2022 Author Posted June 30, 2022 yes i still don't know how to update the version installed using your recommended method
Luke 42237 Posted July 3, 2022 Posted July 3, 2022 On 6/30/2022 at 5:34 PM, Vidman said: yes i still don't know how to update the version installed using your recommended method You would just follow the same procedure again to install the update over the top of your existing version. But I've asked our packaging developer to look at this and comment about the duplicates. Thanks.
alucryd 318 Posted July 3, 2022 Posted July 3, 2022 @Vidman Updating an existing install is more akin to the regular freebsd install instructions. You should open a shell in the jail you want to update and install the latest emby package like you would on freebsd. pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.7.5.0/emby-server-freebsd13_4.7.5.0_amd64.pkg Or freebsd12 if your jail is version 12.
bluemonkey07 590 Posted July 6, 2022 Author Posted July 6, 2022 On 7/4/2022 at 12:34 AM, alucryd said: @Vidman Updating an existing install is more akin to the regular freebsd install instructions. You should open a shell in the jail you want to update and install the latest emby package like you would on freebsd. pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.7.5.0/emby-server-freebsd13_4.7.5.0_amd64.pkg Or freebsd12 if your jail is version 12. that worked, thanks 1
Pegasus650 1 Posted July 9, 2022 Posted July 9, 2022 Hello, When I run the command ''pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.7.5.0/emby-server-freebsd12_4.7.5.0_amd64.pkg'' the installation does not continue and I get an error message. The Jail is in version 12 ? What did I do wrong? Thanks
Luke 42237 Posted July 9, 2022 Posted July 9, 2022 2 minutes ago, Pegasus650 said: Hello, When I run the command ''pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.7.5.0/emby-server-freebsd12_4.7.5.0_amd64.pkg'' the installation does not continue and I get an error message. The Jail is in version 12 ? What did I do wrong? Thanks Hi, I think you need to go through the initial install process first: https://emby.media/truenas-server.html
Luke 42237 Posted July 11, 2022 Posted July 11, 2022 On 7/10/2022 at 9:20 AM, Pegasus650 said: Hi, I install it on the existing Emby jail? Re:
dolphin 17 Posted August 11, 2022 Posted August 11, 2022 pkg add --force https://github.com/MediaBrowser/Emby.Releases/releases/download/4.7.6.0/emby-server-freebsd13_4.7.6.0_amd64.pkg This command run in the emby-server jail worked to upgrade the emby-server package from 4.7.5.0 to 4.7.6.0. Running the iocage fetch command from the TrueNAS host creates a new jail, it doesn't upgrade the existing one. Then I ran pkg upgrade in the emby-server jail, restarted the jail and everything is working as it should. The following packages were upgraded/installed: New packages to be INSTALLED: brotli: 1.0.9,1 Installed packages to be UPGRADED: ca_root_nss: 3.78 -> 3.81 freetype2: 2.12.1 -> 2.12.1_2 glib: 2.72.2,2 -> 2.72.3,2 harfbuzz: 4.4.1 -> 5.1.0 libdrm: 2.4.111,1 -> 2.4.112_1,1 libiconv: 1.16 -> 1.17 libxml2: 2.9.13_2 -> 2.9.14 most: 5.1.0 -> 5.2.0 nettle: 3.8 -> 3.8.1 pango: 1.50.7 -> 1.50.8 tesseract: 5.2.0 -> 5.2.0_1 webp: 1.2.2 -> 1.2.3 1
