ctaranto 16 Posted April 6, 2022 Posted April 6, 2022 I posted another topic similar to this (https://emby.media/community/index.php?/topic/101366-hw-transcoding-was-working-and-now-its-not/#comment-1063318) but that workaround no longer works well. The CUVID decoder results in a green screen for many movies. Environment: 2022-04-06 07:47:00.579 Info Main: Application path: /usr/lib/emby-server/EmbyServer.dll 2022-04-06 07:47:00.850 Info Main: Emby Command line: /usr/lib/emby-server/EmbyServer.dll -programdata /var/lib/emby -ffdetect /usr/bin/ffdetect-emby -ffmpeg /usr/bin/ffmpeg-emby -ffprobe /usr/bin/ffprobe-emby -restartexitcode 3 Operating system: Linux version 5.4.184-1-MANJARO (builduser@fv-az47-976) (gcc version 11.2.0 (GCC)) #1 SMP PREEMPT Fri Mar 11 13:59:07 UTC 2022 Framework: .NET Core 3.1.20 OS/Process: x64/x64 Runtime: usr/share/dotnet/shared/Microsoft.NETCore.App/3.1.20/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /usr/lib/emby-server 2022-04-06 07:47:00.850 Info Main: Logs path: /var/lib/emby/logs 2022-04-06 07:47:00.850 Info Main: Cache path: /var/lib/emby/cache 2022-04-06 07:47:00.850 Info Main: Internal metadata path: /var/lib/emby/metadata 2022-04-06 07:47:00.850 Info Main: Transcoding temporary files path: /var/lib/emby/transcoding-temp 2022-04-06 07:47:00.892 Info App: Application version: 4.6.7.0 Manjaro (latest) Linux server with an nvidia GTX 1660 Super card with fully updated nvidia drivers. Attached is the embyserver, hardware_detection, and ffmpeg-transcode of a movie where hardware decoding doesn't kick in even then NVDEC is selected in the H.265 (HEVC) decoding section of the Transcoding menu. When I select CUVID and put it above NVENC, hardware decoding kicks in, but for many movies, this results in a green screen. Reading other threads, CUVID is the "old" cuda decoding, and NVDEC is the newer decoding. I would like to understand why the newer decoding isn't working for me. Is there a test I could run at the command line to ensure nvdec is available? embyserver.txt ffmpeg-transcode-8fa45245-4e61-486e-b34f-637673ebb748_1.txt hardware_detection-63784828026.txt
Luke 42243 Posted April 6, 2022 Posted April 6, 2022 Hi, the reason why we offer both is for this very reason that on since systems one will work better and on others it could be the opposite. If that weren't the case and one of them consistently worked with all hardware then we wouldn't even provide the choice.
ctaranto 16 Posted April 6, 2022 Author Posted April 6, 2022 (edited) Thanks, Luke. Is there anything in the logs that indicates why NVDEC isn't working? Library compatibility? Missing libraries? After reading various forums, it seems like _cuvid is not the preferred hardware acceleration (https://forums.developer.nvidia.com/t/ffmpeg-unknown-decoder-h265-cuvid-for-geforce-rtx-2060/128265). I changed from -c:v:0 hevc_cuvid to -c:v:0 hevc_nvdec, but ffmpeg throws an error that hevc_nvdec isn't a valid decoder. But the forum I linked to mentions that the preferred way to turn on nvdec acceleration is to use -hwaccel nvdec (instead of the -c:v:0 hevc parameter). That turned on decoding hardware acceleration, presumably using nvdec. I did this test on the commend line (extracting the call emby makes from the log). How would I change emby's parameter list to use -hwaccel nvdec instead of "-c:v:0 hevc_cuvid" Edited April 6, 2022 by ctaranto
Happy2Play 9812 Posted April 6, 2022 Posted April 6, 2022 5 hours ago, ctaranto said: Is there anything in the logs that indicates why NVENC isn't working? What do you mean? Unless this is a typo and mean NVDEC, since the encoder is working. Dev will have to confirm, but is this not just a display name issue as HWA decoder is being used? @Luke@softworkz NVDEC NVIDIA GeForce GTX 1660 SUPER - H.265 (HEVC) Spoiler "4: NVDEC NVIDIA GeForce GTX 1660 SUPER - H.265 (HEVC)": { "MaxMacroBlocks": 262144, "IsEnabledByDefault": true, "DefaultPriority": 30, "NvidiaCodecInfo": { "Name": "NVDEC NVIDIA GeForce GTX 1660 SUPER - H.265 (HEVC)", "Description": "Adapter #0: 'NVIDIA GeForce GTX 1660 SUPER' ComputeCapability: 7.5", "DeviceInfo": { "ComputeCapability": { "Major": 7, "Minor": 5, "Build": -1, "Revision": -1, "MajorRevision": -1, "MinorRevision": -1 }, "HardwareContextFramework": "NvEncDec", "Capabilities": { "SupportsHwUpload": true, "SupportsHwDownload": true, "SupportsStandaloneDeviceInit": true, "Supports10BitProcessing": true, "SupportsNativeToneMapping": false }, "Adapter": 0, "Name": "NVIDIA GeForce GTX 1660 SUPER", "Desription": "Adapter #0: 'NVIDIA GeForce GTX 1660 SUPER' ComputeCapability: 7.5", "DeviceId": 0, "VendorId": 0 }, "SecondaryCodecTag": "cudaId0", "CommandGenerator": {}, "MaxMacroBlocks": 262144 }, "SecondaryFramework": "NvEncDec", "FrameworkCodec": "hevc", "SecondaryFrameworkCodec": "cudaId0", "IsHardwareCodec": true, "VideoMediaType": "hevc", "ProfilesWithLevel": [{ "Profile": "HevcProfileMain", "Level": "HevcLevel61" }, { "Profile": "HevcProfileMain10", "Level": "HevcLevel61" }, { "Profile": "HevcProfileMainRext", "Level": "HevcLevel61" } ], "SupportedProfiles": ["HevcProfileMain", "HevcProfileMain10", "HevcProfileMainRext"], "SupportedLevels": ["HevcLevel1", "HevcLevel2", "HevcLevel21", "HevcLevel3", "HevcLevel31", "HevcLevel4", "HevcLevel41", "HevcLevel5", "HevcLevel51", "HevcLevel52", "HevcLevel6", "HevcLevel61"], "Direction": "Decoder", "SupportedColorFormats": ["nv12", "p010", "p016", "cuda", "yuv420p", "yuv420p10", "yuv420p16", "yuv444p", "yuv444p10", "yuv444p16"], "CodecDeviceInfo": { "ComputeCapability": { "Major": 7, "Minor": 5, "Build": -1, "Revision": -1, "MajorRevision": -1, "MinorRevision": -1 }, "HardwareContextFramework": "NvEncDec", "Capabilities": { "SupportsHwUpload": true, "SupportsHwDownload": true, "SupportsStandaloneDeviceInit": true, "Supports10BitProcessing": true, "SupportsNativeToneMapping": false }, "Adapter": 0, "Name": "NVIDIA GeForce GTX 1660 SUPER", "Desription": "Adapter #0: 'NVIDIA GeForce GTX 1660 SUPER' ComputeCapability: 7.5", "DeviceId": 0, "VendorId": 0 }, "CodecKind": "Video", "MediaTypeName": "H.265 (HEVC)", "MinWidth": 144, "MaxWidth": 8192, "MinHeight": 144, "MaxHeight": 8192, "WidthAlignment": 2, "HeightAlignment": 2, "SupportedColorFormatStrings": ["NV12", "P010", "P016", "CUDA", "YUV420P", "YUV420P10", "YUV420P16", "YUV444P", "YUV444P10", "YUV444P16"], "ProfileAndLevelInformation": [{ "Profile": { "ShortName": "HevcProfileMain", "Description": "Main Profile", "Details": "The Main profile allows for a bit depth of 8-bits per sample with 4:2:0 chroma sampling, which is the most common type of video used with consumer devices.", "Id": "HevcProfiles.HevcProfileMain" }, "Level": { "ShortName": "HevcLevel61", "Description": "Level 6.1", "Ordinal": 61, "MaxBitRate": "117 Mbit/s", "MaxBitRateDisplay": "117 Mbit/s", "Id": "HevcLevels.HevcLevel61", "ResolutionRates": ["3840x2160@256", "7680x4320@64", "8192x4320@60", "8192x8192@30"], "ResolutionRateStrings": ["3840x2160@256", "7680x4320@64", "8192x4320@60", "8192x8192@30"], "ResolutionRatesDisplay": "3840x2160@256, 7680x4320@64, 8192x4320@60, 8192x8192@30" } }, { "Profile": { "ShortName": "HevcProfileMain10", "Description": "Main 10 Profile", "Details": "The Main 10 profile allows for a bit depth of 8-bits to 10-bits per sample with 4:2:0 chroma sampling. allows for improved video quality since it can support video with a higher bit depth than what is supported by the Main profile.[140] Additionally, in the Main 10 profile 8-bit video can be coded with a higher bit depth of 10-bits, which allows improved coding efficiency compared to the Main profile.", "Id": "HevcProfiles.HevcProfileMain10" }, "Level": { "ShortName": "HevcLevel61", "Description": "Level 6.1", "Ordinal": 61, "MaxBitRate": "117 Mbit/s", "MaxBitRateDisplay": "117 Mbit/s", "Id": "HevcLevels.HevcLevel61", "ResolutionRates": ["3840x2160@256", "7680x4320@64", "8192x4320@60", "8192x8192@30"], "ResolutionRateStrings": ["3840x2160@256", "7680x4320@64", "8192x4320@60", "8192x8192@30"], "ResolutionRatesDisplay": "3840x2160@256, 7680x4320@64, 8192x4320@60, 8192x8192@30" } }, { "Profile": { "ShortName": "HevcProfileMainRext", "Description": "Range Extension (REXT)", "Details": "Version 2 of HEVC adds 21 range extensions profiles, which are grouped together as REXT for now.", "Id": "HevcProfiles.HevcProfileMainRext" }, "Level": { "ShortName": "HevcLevel61", "Description": "Level 6.1", "Ordinal": 61, "MaxBitRate": "117 Mbit/s", "MaxBitRateDisplay": "117 Mbit/s", "Id": "HevcLevels.HevcLevel61", "ResolutionRates": ["3840x2160@256", "7680x4320@64", "8192x4320@60", "8192x8192@30"], "ResolutionRateStrings": ["3840x2160@256", "7680x4320@64", "8192x4320@60", "8192x8192@30"], "ResolutionRatesDisplay": "3840x2160@256, 7680x4320@64, 8192x4320@60, 8192x8192@30" } } ], "Id": "V-D-hevc-nv-cudaId0", "Name": "NVDEC NVIDIA GeForce GTX 1660 SUPER - H.265 (HEVC)", "Description": "Adapter #0: 'NVIDIA GeForce GTX 1660 SUPER' ComputeCapability: 7.5" }, CUVID NVIDIA GeForce GTX 1660 SUPER - H.265 (HEVC) Spoiler "6: CUVID NVIDIA GeForce GTX 1660 SUPER - H.265 (HEVC)": { "MaxMacroBlocks": 262144, "IsEnabledByDefault": false, "DefaultPriority": 0, "NvidiaCodecInfo": { "Name": "CUVID NVIDIA GeForce GTX 1660 SUPER - H.265 (HEVC)", "Description": "Adapter #0: 'NVIDIA GeForce GTX 1660 SUPER' ComputeCapability: 7.5", "DeviceInfo": { "ComputeCapability": { "Major": 7, "Minor": 5, "Build": -1, "Revision": -1, "MajorRevision": -1, "MinorRevision": -1 }, "HardwareContextFramework": "NvEncDec", "Capabilities": { "SupportsHwUpload": true, "SupportsHwDownload": true, "SupportsStandaloneDeviceInit": true, "Supports10BitProcessing": true, "SupportsNativeToneMapping": false }, "Adapter": 0, "Name": "NVIDIA GeForce GTX 1660 SUPER", "Desription": "Adapter #0: 'NVIDIA GeForce GTX 1660 SUPER' ComputeCapability: 7.5", "DeviceId": 0, "VendorId": 0 }, "SecondaryCodecTag": "cudaId0", "CommandGenerator": {}, "MaxMacroBlocks": 262144 }, "SecondaryFramework": "NvEncDec", "FrameworkCodec": "hevc_cuvid", "SecondaryFrameworkCodec": "cudaId0", "IsHardwareCodec": true, "VideoMediaType": "hevc", "ProfilesWithLevel": [{ "Profile": "HevcProfileMain", "Level": "HevcLevel61" }, { "Profile": "HevcProfileMain10", "Level": "HevcLevel61" }, { "Profile": "HevcProfileMainRext", "Level": "HevcLevel61" } ], "SupportedProfiles": ["HevcProfileMain", "HevcProfileMain10", "HevcProfileMainRext"], "SupportedLevels": ["HevcLevel1", "HevcLevel2", "HevcLevel21", "HevcLevel3", "HevcLevel31", "HevcLevel4", "HevcLevel41", "HevcLevel5", "HevcLevel51", "HevcLevel52", "HevcLevel6", "HevcLevel61"], "Direction": "Decoder", "SupportedColorFormats": ["nv12", "p010", "p016", "cuda", "yuv420p", "yuv420p10", "yuv420p16", "yuv444p", "yuv444p10", "yuv444p16"], "CodecDeviceInfo": { "ComputeCapability": { "Major": 7, "Minor": 5, "Build": -1, "Revision": -1, "MajorRevision": -1, "MinorRevision": -1 }, "HardwareContextFramework": "NvEncDec", "Capabilities": { "SupportsHwUpload": true, "SupportsHwDownload": true, "SupportsStandaloneDeviceInit": true, "Supports10BitProcessing": true, "SupportsNativeToneMapping": false }, "Adapter": 0, "Name": "NVIDIA GeForce GTX 1660 SUPER", "Desription": "Adapter #0: 'NVIDIA GeForce GTX 1660 SUPER' ComputeCapability: 7.5", "DeviceId": 0, "VendorId": 0 }, "CodecKind": "Video", "MediaTypeName": "H.265 (HEVC)", "MinWidth": 144, "MaxWidth": 8192, "MinHeight": 144, "MaxHeight": 8192, "WidthAlignment": 2, "HeightAlignment": 2, "SupportedColorFormatStrings": ["NV12", "P010", "P016", "CUDA", "YUV420P", "YUV420P10", "YUV420P16", "YUV444P", "YUV444P10", "YUV444P16"], "ProfileAndLevelInformation": [{ "Profile": { "ShortName": "HevcProfileMain", "Description": "Main Profile", "Details": "The Main profile allows for a bit depth of 8-bits per sample with 4:2:0 chroma sampling, which is the most common type of video used with consumer devices.", "Id": "HevcProfiles.HevcProfileMain" }, "Level": { "ShortName": "HevcLevel61", "Description": "Level 6.1", "Ordinal": 61, "MaxBitRate": "117 Mbit/s", "MaxBitRateDisplay": "117 Mbit/s", "Id": "HevcLevels.HevcLevel61", "ResolutionRates": ["3840x2160@256", "7680x4320@64", "8192x4320@60", "8192x8192@30"], "ResolutionRateStrings": ["3840x2160@256", "7680x4320@64", "8192x4320@60", "8192x8192@30"], "ResolutionRatesDisplay": "3840x2160@256, 7680x4320@64, 8192x4320@60, 8192x8192@30" } }, { "Profile": { "ShortName": "HevcProfileMain10", "Description": "Main 10 Profile", "Details": "The Main 10 profile allows for a bit depth of 8-bits to 10-bits per sample with 4:2:0 chroma sampling. allows for improved video quality since it can support video with a higher bit depth than what is supported by the Main profile.[140] Additionally, in the Main 10 profile 8-bit video can be coded with a higher bit depth of 10-bits, which allows improved coding efficiency compared to the Main profile.", "Id": "HevcProfiles.HevcProfileMain10" }, "Level": { "ShortName": "HevcLevel61", "Description": "Level 6.1", "Ordinal": 61, "MaxBitRate": "117 Mbit/s", "MaxBitRateDisplay": "117 Mbit/s", "Id": "HevcLevels.HevcLevel61", "ResolutionRates": ["3840x2160@256", "7680x4320@64", "8192x4320@60", "8192x8192@30"], "ResolutionRateStrings": ["3840x2160@256", "7680x4320@64", "8192x4320@60", "8192x8192@30"], "ResolutionRatesDisplay": "3840x2160@256, 7680x4320@64, 8192x4320@60, 8192x8192@30" } }, { "Profile": { "ShortName": "HevcProfileMainRext", "Description": "Range Extension (REXT)", "Details": "Version 2 of HEVC adds 21 range extensions profiles, which are grouped together as REXT for now.", "Id": "HevcProfiles.HevcProfileMainRext" }, "Level": { "ShortName": "HevcLevel61", "Description": "Level 6.1", "Ordinal": 61, "MaxBitRate": "117 Mbit/s", "MaxBitRateDisplay": "117 Mbit/s", "Id": "HevcLevels.HevcLevel61", "ResolutionRates": ["3840x2160@256", "7680x4320@64", "8192x4320@60", "8192x8192@30"], "ResolutionRateStrings": ["3840x2160@256", "7680x4320@64", "8192x4320@60", "8192x8192@30"], "ResolutionRatesDisplay": "3840x2160@256, 7680x4320@64, 8192x4320@60, 8192x8192@30" } } ], "Id": "V-D-hevc_cuvid-nv-cudaId0", "Name": "CUVID NVIDIA GeForce GTX 1660 SUPER - H.265 (HEVC)", "Description": "Adapter #0: 'NVIDIA GeForce GTX 1660 SUPER' ComputeCapability: 7.5" },
ctaranto 16 Posted April 6, 2022 Author Posted April 6, 2022 Thanks, H2P. Yes, I meant NVDEC. I edited the post to avoid further confusion. I think it's more than a display name issue. When CUVID is selected, I see "-c:v:0 hevc_cuvid" in the ffmpeg command line. When NVDEC is selected, I see "-c:v:0 hevc". It may be the problem I'm having is that instead of -c:v:0 hevc, it should be "-hwaccel nvdec".
Happy2Play 9812 Posted April 6, 2022 Posted April 6, 2022 Pretty sure this is the reason HWA NVDEC is not happening. Info Scaling >> False False Ffmpeg does not include 'scale_cuda' ... Info ToneMapping (when possible) >> False False Ffmpeg does not include 'scale_cuda' ... But know there is a lot of changes for this in beta 4.7.
ctaranto 16 Posted April 7, 2022 Author Posted April 7, 2022 Thanks again, H2P! I look forward to the next release that (hopefully) will address this!
softworkz 5133 Posted April 7, 2022 Posted April 7, 2022 @ctaranto The difference between CUVID and NVDEC in ffmpeg is that in case of CUVID, the whole video stream is sent to and processed by the Nvidia Media API and in case of NVDEC, the parsing is done by ffmpeg and only the video frame data is sent to the Nvidia API. The API has formerly been called NVCUVID, now NVDEC, but that CUDA decoding that you read about has gone away long time ago while the name stayed for much longer. The decoding is the same (done by the fixed-function hardware "chips" in either case. Those chips are called NVDEC as well) The whole story is really confusing, because there's the ffmpeg naming, the Nvidia API naming and the Nvidia hardware feature naming - three different things... The green artifacts with HEVC_cuvid are a know issue, that's why HEVC_nvdec is the default. From the log I can't see any error, so I'm no sure what it could be. Could you please retry with NVDEC and then grab the first transcoded segment from transcoding_temp? (a subfolder is created there) You can send it to me via PM. Thanks, sw
ctaranto 16 Posted April 13, 2022 Author Posted April 13, 2022 Hi Luke. Not yet. I sent sw a PM last week. I assume he will look at it when he has time.
softworkz 5133 Posted April 18, 2022 Posted April 18, 2022 (edited) @ctaranto - Thanks for the test segment. It appears to be fine as far as I can see. Do you have any playback problems when choosing NVDEC? On 4/6/2022 at 2:24 PM, ctaranto said: I would like to understand why the newer decoding isn't working for me. In what way doesn't it work for you? I think I got it now, what you're asking about: The Emby installation package which you are using includes an ffmpeg version which doesn't include all of the features like the version we have in most other Linux packages. As such, it doesn't include the scale_cuda filter: Due to the fact that the input source is 4k and the scaling needs to be done in software, the processing pipeline builder might have decided not to use hw decoding at all, considering the tradeoff between copying video data (encoded + raw) to and back from the hardware just for decoding (as the same copying will be required for encoding again). In case of CUVID, the decision process is a bit different for various reasons, but in either case, the primary concern is not the decoding, but the lack of the scale_cuda and tonemap_cuda filters in the ffmpeg which is included in that installation package. I'm not an expert in that area, but maybe you can try to use one of our official Linux installation packages (e.g. for Debian) instead. Edited April 18, 2022 by softworkz
ctaranto 16 Posted April 18, 2022 Author Posted April 18, 2022 Thanks for the details, sw. I think that's part of the problem - Emby doesn't think my video card can do all the fun things it's supposed to do. There's no way I could use a Debian distribution on an Arch-based distribution. As an experiment, I replaced the Emby ffmpeg with the latest distribution of ffmpeg available (using symlinks). While it did use the latest ffmpeg, It did not make a difference. I think another part of the reason is that when NVDEC is selected, "-hwaccel nvdec" should be part of the ffmpeg command. Instead, Emby sends "-c:v:0 hevc" which does nothing useful with regards to hardware decoding. Can Emby make a change so when NVDEC is selected, "-hwaccel nvdec" is sent on the command line? Or provide a way to override the default of "-c:v:0 hevc"?
ctaranto 16 Posted April 18, 2022 Author Posted April 18, 2022 (edited) I went back and tried this again. This time, I copied (not symlink) the manjaro-installed ffmpeg executable (in /usr/bin) to a new one (/usr/bin/ffmpeg-emby). I backed up the original ffmpeg-emby first. [ctaranto@thor-pc bin]$ ls -al ffmpeg* -rwxr-xr-x 1 root root 280584 Mar 6 10:40 ffmpeg -rwxr-xr-x 1 root root 280584 Apr 18 17:25 ffmpeg-emby -rwxr-xr-x 1 root root 21702520 Apr 6 17:12 ffmpeg-emby.back [ctaranto@thor-pc bin]$ It appears that emby is sending the -hwaccel parameters: /usr/bin/ffmpeg-emby -y -copyts -start_at_zero -f matroska,webm -c:v:0 hevc -hwaccel:v:0 cuda -hwaccel_device:v:0 0 -hwaccel_output_format:v:0 cuda -i "/storage/red3/movies/Murder on the Orient Express.mkv" -filter_complex "[0:0]scale_cuda@f1=w=1920:h=1080:format=nv12,setsar@f2=sar=sar[f2_out0]" -map [f2_out0] -map 0:1 -sn -c:v:0 h264_nvenc -b:v:0 19616000 -g:v:0 72 -maxrate:v:0 19616000 -bufsize:v:0 39232000 -sc_threshold:v:0 0 -keyint_min:v:0 72 -r:v:0 23.976024627685547 -profile:v:0 high -c:a:0 libmp3lame -ab:a:0 192000 -ac:a:0 2 -metadata:s:a:0 language=eng -filter:a:0 "volume=2" -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "/var/lib/emby/transcoding-temp/E4EFD2.m3u8" -segment_list_type m3u8 -segment_time 3 -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 "/var/lib/emby/transcoding-temp/E4EFD2_%d.ts" Also appears that hardware acceleration is being used. I'll confirm that there aren't any green screens next... Thanks for the help, sw! Update: Appears no green screens with testing on movies that previously would green screen using CUVID! For me, using the latest and greatest ffmpeg from my Linux distribution instead of the emby-supplied ffmpeg has enabled NVDEC support. Edited April 18, 2022 by ctaranto
softworkz 5133 Posted April 19, 2022 Posted April 19, 2022 You need to be aware, though, that this ffmpeg version lacks many of the customizations we have and you will sooner or later run into other issues. Also, it doesn't have CUDA tone mapping and the scale_cuda doesn't support format conversions. Recently, another user reported how he extracted the ffmpeg from our Debian package for use on Arch Linux. This might be a better solution for you.
ctaranto 16 Posted April 19, 2022 Author Posted April 19, 2022 (edited) Ah. That's what you meant by using the Debian package. Thanks! I'll give that a shot. Update: That died a quick death. The ffmpeg-emby that is installed by Arch is statically linked (21MB). The ffmpeg installed by the Arch itself is 275KB (dynamically linked). The ffmpeg inside of the Debian X64 package is also dynamically linked (275KB). Unfortunately, that package expects the dependent libraries to be in the "Debian" locations, not the Arch locations. I'm sure even if it could find the libraries, they would be out of sync (Arch is always at the latest; Debian is release-based). ./ffmpeg-emby: symbol lookup error: ./ffmpeg-emby: undefined symbol: avfilter_alloc, version LIBAVFILTER_7 Do any other Linux distributions supply a statically linked ffmpeg (or a link to the post how to better extract the Debian ffmpeg)? UPDATE: See the post below for a link how to get ffmpeg from the Debian package working on Arch Edited April 19, 2022 by ctaranto
softworkz 5133 Posted April 19, 2022 Posted April 19, 2022 18 minutes ago, ctaranto said: Ah. That's what you meant by using the Debian package. Thanks! I'll give that a shot. Update: That died a quick death. The ffmpeg-emby that is installed by Arch is statically linked (21MB). The ffmpeg installed by the Arch itself is 275KB (dynamically linked). The ffmpeg inside of the Debian X64 package is also dynamically linked (275KB). Unfortunately, that package expects the dependent libraries to be in the "Debian" locations, not the Arch locations. I'm sure even if it could find the libraries, they would be out of sync (Arch is always at the latest; Debian is release-based). ./ffmpeg-emby: symbol lookup error: ./ffmpeg-emby: undefined symbol: avfilter_alloc, version LIBAVFILTER_7 The ffmpeg in the Debian package is self-contained, i.e. it includes everything, the ffmpeg libs, all dependent libs, even the Intel drivers with libva, etc in the lib folder of the installation. Essentially, it shouldn't use anything from the OS folders, but all from the lib folder of the package instead.
ctaranto 16 Posted April 19, 2022 Author Posted April 19, 2022 Thanks again. I just discovered (through reading another thread) the Emby Diagnostic plugin. This will hopefully let me put the Debian ffmpeg (and all libraries) into it's own folder segmented away from the OS libraries, and point emby to that ffmpeg executable.
softworkz 5133 Posted April 19, 2022 Posted April 19, 2022 Also look at the emby server startup script. You might need to make some adjustments there to env variables being set. (the purpose of the emby-ffmpeg, emby-ffprobe stubs is only to allow running those for testing from the command line but with the same environment in which the server runs them)
ctaranto 16 Posted April 19, 2022 Author Posted April 19, 2022 (edited) Thanks again, sw. I found the post you were referring to Following that, I was able to get the debian ffmpeg working with my Arch (Manjaro) emby server. Hardware decoding works and tone-mapping options appeared in the advanced transcoding menu! Edited April 19, 2022 by ctaranto 1
softworkz 5133 Posted April 19, 2022 Posted April 19, 2022 Yup - that's what I meant! Let us know how it works out for you.
ctaranto 16 Posted April 19, 2022 Author Posted April 19, 2022 Appears to be working perfectly! >>>>>> Processing Plan Info Name CanDoInHardware WillDoInHardware Reason Info NVDEC NVIDIA GeForce GTX 1660 SUPER -... >> True True Hardware Codec Info VideoInput >> True True Matching hardware context Info Scaling >> True True Info ToneMapping (when possible) >> True True Info VideoOutput >> True True Hardware encoder Info NVENC NVIDIA GeForce GTX 1660 SUPER -... >> True True Hardware Codec >>>>>> Projected Processing Formats Info Previous HW-Context Format SW-Format Size Next Info hevc >> CUDA cuda yuv420p10 3840x2160 >> scale_cuda Info scale_cuda >> CUDA cuda yuv420p10 1920x1080 >> setsar Info setsar >> CUDA cuda yuv420p10 1920x1080 >> setparams Info setparams >> CUDA cuda yuv420p10 1920x1080 >> tonemap_cuda Info tonemap_cuda >> CUDA cuda nv12 1920x1080 >> Everything comes back as True/True. Jumping around a movie is quick. Very little CPU load. Thanks everyone (especially sw)! 1
softworkz 5133 Posted April 19, 2022 Posted April 19, 2022 Thanks for the feedback, you're welcome. PS: We're thinking about ways to make this easier for Arch/Manjaro users in the future. 1
Luke 42243 Posted June 17, 2022 Posted June 17, 2022 On 4/19/2022 at 5:02 PM, softworkz said: PS: We're thinking about ways to make this easier for Arch/Manjaro users in the future. And this is in our 4.7 stable package. Thanks. 1
ctaranto 16 Posted August 1, 2022 Author Posted August 1, 2022 (edited) I recently updated to 4.7.5 and tried the included stable packages of ffmpeg. Unfortunately, this didn't allow for hardware decoding on Manjaro on my system (fully updated as of today). I then reverted back (using Diagnostic Options / FFmpeg Options) to override ffmpeg, ffprobe, and ffdetect to continue to use the Ubuntu versions. I seems that 4.7.5 isn't honoring those overrides anymore. Here's an excerpt from the transcoding log. Note how the ffmpeg being used is /usr/bin (the default) and not /opt/emby-server/bin like I have set in the Diagnostic Options. Also, when I don't override ffmpeg, I do not see any Tone Mapping options. When I override it, I do see those options. I then edited /etc/conf.d/emby-server to point to the Ubuntu binaries. This did make the transcode log change to show it using those binaries, but it now shows that "superscale_cuda" isn't supported (which it used to be before 4.7). Update: After sleeping on it, I figured I would update the Ubuntu ffmpeg binaries from the 4.7.5 release. Doing this solved the problem. Quote 2022-07-31 21:40:06.374 Operating System: Linux version 5.4.207-1-MANJARO (builduser@fv-az108-856) (gcc version 12.1.0 (GCC)) #1 SMP PREEMPT Fri Jul 22 07:12:32 UTC 2022 OS/Process: x64/x64 Emby Server version: 4.7.5.0 Operating system: Unix 5.4.207.1 Command Line: /usr/lib/emby-server/EmbyServer.dll -programdata /var/lib/emby -ffdetect /usr/bin/ffdetect-emby -ffmpeg /usr/bin/ffmpeg-emby -ffprobe /usr/bin/ffprobe-emby -restartexitcode 3 App: Emby Web 4.7.5.0 Chrome Windows http://172.20.0.166:8096/emby/videos/2507234/main.m3u8?DeviceId=614be3e2-adda-435b-bf6a-c1c0d14b6245&MediaSourceId=abec581fbd85326589c7dfcae1d8ca2c&PlaySessionId=42f1e2b466db4040aa73f25c4e6f01e4&api_key=8b56f06e4d594be697e593702f241506&VideoCodec=h264&AudioCodec=ac3,mp3,aac&VideoBitrate=19616000&AudioBitrate=384000&AudioStreamIndex=1&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&TranscodeReasons=ContainerBitrateExceedsLimit http://172.20.0.166:8096/emby/videos/2507234/hls1/main/0.ts?PlaySessionId=42f1e2b466db4040aa73f25c4e6f01e4 {"Protocol":"File","Id":"abec581fbd85326589c7dfcae1d8ca2c","Path":"/storage/red2/movies/10 Cloverfield Lane.mkv","Type":"Default","Container":"mkv","Size":45752504721,"Name":"10 Cloverfield Lane","IsRemote":false,"RunTimeTicks":62147930000,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[{"Codec":"hevc","Language":"eng","ColorTransfer":"smpte2084","ColorPrimaries":"bt2020","ColorSpace":"bt2020nc","TimeBase":"1/1000","VideoRange":"HDR10","DisplayTitle":"4K HEVC HDR10","DisplayLanguage":"English","IsInterlaced":false,"BitRate":58894968,"BitDepth":10,"RefFrames":1,"IsDefault":true,"IsForced":false,"Height":2160,"Width":3840,"AverageFrameRate":23.976025,"RealFrameRate":23.976025,"Profile":"Main 10","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"yuv420p10le","Level":153,"IsAnamorphic":false,"AttachmentSize":0},{"Codec":"truehd","Language":"eng","TimeBase":"1/1000","DisplayTitle":"English TRUEHD 7.1 (Default)","DisplayLanguage":"English","IsInterlaced":false,"ChannelLayout":"7.1","BitDepth":24,"Channels":8,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","AttachmentSize":0},{"Codec":"dts","Language":"eng","TimeBase":"1/1000","DisplayTitle":"English DTS-HD MA 7.1","DisplayLanguage":"English","IsInterlaced":false,"ChannelLayout":"7.1","BitDepth":24,"Channels":8,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Profile":"DTS-HD MA","Type":"Audio","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","AttachmentSize":0},{"Codec":"PGSSUB","Language":"eng","TimeBase":"1/1000","Title":"English-PGS","DisplayTitle":"English (Default PGSSUB)","DisplayLanguage":"English","IsInterlaced":false,"IsDefault":true,"IsForced":false,"Type":"Subtitle","Index":3,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","AttachmentSize":0,"SubtitleLocationType":"InternalStream"},{"Codec":"PGSSUB","Language":"eng","TimeBase":"1/1000","Title":"English-SDH-PGS","DisplayTitle":"English (PGSSUB)","DisplayLanguage":"English","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":4,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","AttachmentSize":0,"SubtitleLocationType":"InternalStream"},{"Codec":"mjpeg","ColorSpace":"bt470bg","TimeBase":"1/90000","IsInterlaced":false,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":176,"Width":120,"RealFrameRate":90000,"Profile":"Baseline","Type":"EmbeddedImage","AspectRatio":"15:22","Index":5,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"yuvj444p","Level":-99,"AttachmentSize":0},{"Codec":"mjpeg","ColorSpace":"bt470bg","TimeBase":"1/90000","IsInterlaced":false,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":120,"Width":213,"RealFrameRate":90000,"Profile":"Baseline","Type":"EmbeddedImage","AspectRatio":"71:40","Index":6,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"yuvj444p","Level":-99,"AttachmentSize":0},{"Codec":"mjpeg","ColorSpace":"bt470bg","TimeBase":"1/90000","IsInterlaced":false,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":882,"Width":600,"RealFrameRate":90000,"Profile":"Baseline","Type":"EmbeddedImage","AspectRatio":"100:147","Index":7,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"yuvj444p","Level":-99,"AttachmentSize":0},{"Codec":"mjpeg","ColorSpace":"bt470bg","TimeBase":"1/90000","IsInterlaced":false,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":600,"Width":1067,"RealFrameRate":90000,"Profile":"Baseline","Type":"EmbeddedImage","AspectRatio":"1067:600","Index":8,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"yuvj444p","Level":-99,"AttachmentSize":0}],"Formats":[],"Bitrate":58894968,"RequiredHttpHeaders":{},"ReadAtNativeFramerate":false} >>>>>> User policy for Craig Enable Playback Remuxing: True Enable Video Playback Transcoding: True Enable Audio Playback Transcoding: True >>>>>> Hardware Decoders for hevc [X] NVDEC NVIDIA GeForce GTX 1660 SUPER - H.265 (HEVC) [ ] CUVID NVIDIA GeForce GTX 1660 SUPER - H.265 (HEVC) >>>>>> Hardware Encoders for h264 [X] NVENC NVIDIA GeForce GTX 1660 SUPER - H.264 (AVC) >>>>>> Selected Codecs Decoder NVDEC NVIDIA GeForce GTX 1660 SUPER - H.265 (HEVC) Adapter #0: 'NVIDIA GeForce GTX 1660 SUPER' ComputeCapability: 7.5 Max Bitrate: 117 Mbit/s - Frame Sizes: 144x144...8192x8192 - Width Alignment: 2 - Height Alignment: 2 Color Formats: NV12, P010, P016 - Bit Depths: 8, 10, 12, 14, 16 Profiles: Main Profile (Level 6.1), Main 10 Profile (Level 6.1), Range Extension (REXT) (Level 6.1) Encoder NVENC NVIDIA GeForce GTX 1660 SUPER - H.264 (AVC) Adapter #0: 'NVIDIA GeForce GTX 1660 SUPER' ComputeCapability: 7.5 Max Bitrate: 781 Mbit/s - Frame Sizes: max 4096x4096 - Width Alignment: 2 - Height Alignment: 2 Color Formats: NV12, P010, P016 - Bit Depths: 8, 10, 12, 14, 16 Profiles: Baseline Profile (Level 6.2), Main Profile (Level 6.2), High Profile (Level 6.2), High 4:4:4 Predictive Profile (Level 6.2) >>>>>> FindVideoEncoder - MediaType: h264, UseHardwareCodecs: True, HWA-Mode: Advanced Info Checking: 'NVENC NVIDIA GeForce GTX 1660 SUPER - H.264 (AVC)' Info Check successful - selecting 'NVENC NVIDIA GeForce GTX 1660 SUPER - H.264 (AVC)' >>>>>> FindVideoDecoder - MediaType: hevc, UseHardwareCodecs: True, HWA-Mode: Advanced Info Checking: 'NVDEC NVIDIA GeForce GTX 1660 SUPER - H.265 (HEVC)' Info Check successful - selecting 'NVDEC NVIDIA GeForce GTX 1660 SUPER - H.265 (HEVC)' >>>>>> Processing Plan Name CanDoInHW WillDoInHW Reason NVDEC NVIDIA GeForce GTX 1660 SUPER -... >> True True Hardware Codec VideoInput >> True False Matching hardware context Scaling >> False False Ffmpeg does not include 'superscale_cuda' filter ToneMapping (when possible) >> False False Ffmpeg does not include 'superscale_cuda' filter VideoOutput >> True True Hardware encoder NVENC NVIDIA GeForce GTX 1660 SUPER -... >> True True Hardware Codec >>>>>> Video Processing Steps for [0:0]: H.265 (HEVC) Step HW-Context Format SW-Format Size Next HEVC >> - yuv420p10 yuv420p10 3840x2160 >> scale scale >> - yuv420p10 yuv420p10 1920x1080 >> format format >> - yuv420p yuv420p 1920x1080 >> Edited August 1, 2022 by ctaranto
