ur5fyg 0 Posted January 22, 2022 Posted January 22, 2022 (edited) Hello. I still stood EMBY PREMIUM 4.1.0.26 - yesterday I updated the server to the version 4.6.7.0. Before that, my playlist .M3U8 worked perfectly perfectly. After the update, the message also pops up that there are no compatible streams. I tried to put the IPTV plugin - it does not reproduce and displays the same message. My 7th summer daughter complains that you can not watch your favorite cartoons Edited January 22, 2022 by ur5fyg
Luke 42243 Posted January 24, 2022 Posted January 24, 2022 Hi there @ur5fyg can we please look at an example? Thanks !
ur5fyg 0 Posted January 24, 2022 Author Posted January 24, 2022 What example is you to show? For information, My Emby Server works on TrueNAS
Luke 42243 Posted January 24, 2022 Posted January 24, 2022 @ur5fyg The information requested in how to report a media playback issue. thanks !
ur5fyg 0 Posted January 24, 2022 Author Posted January 24, 2022 Only file embyserver.txt is created in my LOGS folder. Files ffmpeg not created. File *.m3u took from another topic, he behaves just like my embyserver.txt ToonamiAftermath.m3u
Luke 42243 Posted January 28, 2022 Posted January 28, 2022 Ok, this should be resolved for the next release. Workaround for now would be to make sure it ends with .m3u8 instead of just .m3u. Thanks.
ur5fyg 0 Posted January 28, 2022 Author Posted January 28, 2022 Unfortunately there is no workaround. Since both type sheets do not work .m3u and .m3u8 1
Luke 42243 Posted January 28, 2022 Posted January 28, 2022 Hi, can we please look at an m3u8 example? Thanks.
Luke 42243 Posted January 30, 2022 Posted January 30, 2022 5 hours ago, ur5fyg said: playlist.m3u8 775 B · 0 downloads Can you please attach the emby server log? Thanks.
Solution ur5fyg 0 Posted January 30, 2022 Author Solution Posted January 30, 2022 I rolled back to the old version 4.1.0.26, as problems started not only with IPTV viewing, but also with viewing video files. If this file is suitable for you from version 4.1.0.26, I will give it.
ur5fyg 0 Posted June 24, 2022 Author Posted June 24, 2022 (edited) I was updated to version 7.4.2.0 (Truenas) and I see that the question with the reproduction of the playlist M3U8 or just M3U has not yet been resolved. This is very sad. I attach the playlist. Fill this playlist to the server, and tell me how to make the server play it? Once again I want to notice, on the old version (4.1) of the server, this playlist works well Thanks. freeiptv.m3u Edited June 24, 2022 by ur5fyg
Luke 42243 Posted June 25, 2022 Posted June 25, 2022 9 hours ago, ur5fyg said: I was updated to version 7.4.2.0 (Truenas) and I see that the question with the reproduction of the playlist M3U8 or just M3U has not yet been resolved. This is very sad. I attach the playlist. Fill this playlist to the server, and tell me how to make the server play it? Once again I want to notice, on the old version (4.1) of the server, this playlist works well Thanks. freeiptv.m3u 75.37 kB · 0 downloads Hi @ur5fyg can you please attach the emby server log from when you tried to play with this? Thanks !
ur5fyg 0 Posted June 25, 2022 Author Posted June 25, 2022 Here are logs embyserver.txt ffmpeg-directstream-b0964975-ffea-49a3-a7a9-3b48798901b7_1.txt ffmpeg-directstream-f9224cca-4a9b-481f-8bfa-8be97b31fda2_1.txt ffmpeg-transcode-0f1bbcf4-5874-469b-916e-2b1d4bfd1459_1.txt ffmpeg-transcode-8e88004a-3c21-45e1-b1ad-673c6fbea634_1.txt ffmpeg-transcode-533eb16e-8202-47c9-a856-52149b8b3f03_1.txt ffmpeg-transcode-97688ddf-99f9-472c-a7d5-40f407ece4a3_1.txt
Luke 42243 Posted June 25, 2022 Posted June 25, 2022 You don't by any chance have log files from the old working version that I could compare with, do you?
ur5fyg 0 Posted June 25, 2022 Author Posted June 25, 2022 Specially rolled up to version 4.5.4.0 (truenas) here, too, everything works. I attach logs. embyserver.txt ffmpeg-directstream-60d4a93d-d636-4824-8012-e0421302866a_1.txt
Luke 42243 Posted June 26, 2022 Posted June 26, 2022 How did you install Emby Server? You're using an install package that wasn't put together by us, so here's two things you can try: Switch to an install package that is built by us by following the install steps on our website https://emby.media/download In the m3u setup, try customizing the user agent to: VLC/3.0.0-git LibVLC/3.0.0-git This will make it match the older version of the server. That's basically the only difference in the ffmpeg command line.
ur5fyg 0 Posted June 26, 2022 Author Posted June 26, 2022 I can’t install the package manually since I use Truenas (freeenas), I use the plugin offered in the system. I do not quite understand where I can try to configure user agent, can be possible in more detail? Thank you.
Luke 42243 Posted June 26, 2022 Posted June 26, 2022 Yes you can manually install by following this: https://emby.media/truenas-server.html The user agent can be configured by clicking on the m3u tuner in emby live tv setup.
ur5fyg 0 Posted June 27, 2022 Author Posted June 27, 2022 I don't understand what I should do here, please help me.
Luke 42243 Posted June 27, 2022 Posted June 27, 2022 Yea try setting that to: VLC/3.0.0-git LibVLC/3.0.0-git
ur5fyg 0 Posted June 27, 2022 Author Posted June 27, 2022 (edited) Unfortunately, this did not help. I installed the server over your recommendation (https://emby.media/download), it solved the problem, and Live TV works normally. But, I had a question, version 4.7.1.0_1 was established, This is fine? And how to update my emby server in the future? Thank you. Edited June 27, 2022 by ur5fyg
Luke 42243 Posted July 3, 2022 Posted July 3, 2022 Quote But, I had a question, version 4.7.1.0_1 was established Hi, what do you mean by established? What version number do you have now?
ur5fyg 0 Posted July 3, 2022 Author Posted July 3, 2022 (edited) Hi, I have Truenas 12. Version 4.7.1.0 was established but it is written in the Embubi panel that the version 4.7.5.0 is subject and recommends stopping the server and update. Edited July 3, 2022 by ur5fyg
Luke 42243 Posted July 4, 2022 Posted July 4, 2022 Sorry, can you try following the procedure here again: https://emby.media/truenas-server.html You should get 4.7.5 this time. Thanks.
