macki_b 0 Posted December 12, 2021 Posted December 12, 2021 Hi! I updated to the latest stable release then my admin settings went missing? Im not able to manage my server settings anymore. Truenas 12
Happy2Play 9811 Posted December 12, 2021 Posted December 12, 2021 Please post a server log. But same issue was mentioned here. https://emby.media/community/index.php?/topic/103818-server-management-menus-disapeared-with-latest-version/
Townsey 1 Posted December 12, 2021 Posted December 12, 2021 Think they might return if you click the wheel top right.
macki_b 0 Posted December 12, 2021 Author Posted December 12, 2021 I tried the steps in other post but did not help emby.txt
macki_b 0 Posted December 12, 2021 Author Posted December 12, 2021 Its strange because it was there at first but the next day it was gone. I have not played with any settings
macki_b 0 Posted December 12, 2021 Author Posted December 12, 2021 (edited) I have this in the adressbar: .html?userId=6d9a136226714c5fbb0cb748f8869765&serverId=6b8a7cc36b1b4ac493aa016b7f00c976 The above user has: <IsAdministrator>true</IsAdministrator> Edited December 12, 2021 by macki_b
CBers 7554 Posted December 13, 2021 Posted December 13, 2021 58 minutes ago, macki_b said: Has anyone found a solution? Have you tried @Luke's suggestion here? Your plugins folder may be named differently, depending on OS.
macki_b 0 Posted December 13, 2021 Author Posted December 13, 2021 1 hour ago, CBers said: Have you tried @Luke's suggestion here? Your plugins folder may be named differently, depending on OS. Yes. Did that and the other suggestion. Did not do the trick.
Happy2Play 9811 Posted December 13, 2021 Posted December 13, 2021 It is really impossible to say as you appear to have the exact same errors in your log but fix for other users is not working for you.\ Only thing we really know is this is platform specific.
Luke 42237 Posted December 14, 2021 Posted December 14, 2021 Try opening the browser to just ip:port and see if that helps. Thanks.
macki_b 0 Posted December 14, 2021 Author Posted December 14, 2021 8 hours ago, Luke said: Try opening the browser to just ip:port and see if that helps. Thanks. Nothing. I still dont get admin settings. Would a new install be the solution or will i end up with the same result? Not the first choice but if its a must....
macki_b 0 Posted December 14, 2021 Author Posted December 14, 2021 (edited) If i update to 4.7.0.18 i get my admin menu back. But then my outside home network movieplayback dont work. This is crazy Edited December 14, 2021 by macki_b
Carlo 4561 Posted December 14, 2021 Posted December 14, 2021 So right now for you 4.7.0.18 works but 4.6.7 has the missing menu? If you copied your data and config folders before upgrading to the beta you can restore those and try 4.6.7 again. I have seen this a couple of times and it's always been a cache issue that you can clear with CTRL-F5. Or try a different browser that you haven't used before. Do you have a reverse proxy inline or use Cloudflare (a proxy)?
macki_b 0 Posted December 14, 2021 Author Posted December 14, 2021 (edited) 21 minutes ago, cayars said: So right now for you 4.7.0.18 works but 4.6.7 has the missing menu? If you copied your data and config folders before upgrading to the beta you can restore those and try 4.6.7 again. I have seen this a couple of times and it's always been a cache issue that you can clear with CTRL-F5. Or try a different browser that you haven't used before. Do you have a reverse proxy inline or use Cloudflare (a proxy)? Well the menu is back in 4.7.0.18 but im not able to do playback outside my network ctrl-f5 does notihing. I have even tried three different browsers. You meen copy config and data from 4.6.0.7 and paste in 4.70.18 updated install. I could do as you suggested but then server wont playback movies outside of network. Or? Edited December 14, 2021 by macki_b
Carlo 4561 Posted December 14, 2021 Posted December 14, 2021 No I meant in order to revert back to 4.6.0.7 (downgrade) you would want to restore those things first as you shouldn't downgrade setups due to new changes that could have been made. Were you ever able to playback remotely before? If you do a test from www.canyouseeme.org using the port shown on the Dashboard does it pass or fail?
macki_b 0 Posted December 15, 2021 Author Posted December 15, 2021 How do i restore the settings? I have now been playing with down and upgrade a while to get it working. Port is working! Not blocked with 4.6.0.7 My playback outside network is working without problem with 4.6.0.7 I can wipe emby and start allover. Even if this isnt my first choice
Luke 42237 Posted December 15, 2021 Posted December 15, 2021 9 hours ago, macki_b said: How do i restore the settings? I have now been playing with down and upgrade a while to get it working. Port is working! Not blocked with 4.6.0.7 My playback outside network is working without problem with 4.6.0.7 I can wipe emby and start allover. Even if this isnt my first choice Have you taken a look at this? https://support.emby.media/support/solutions/articles/44001159936-backup
macki_b 0 Posted December 16, 2021 Author Posted December 16, 2021 (edited) I ended up with a new clean install. When i copied the backup files to new install the problem was back Edited December 16, 2021 by macki_b
Happy2Play 9811 Posted December 16, 2021 Posted December 16, 2021 1 hour ago, macki_b said: I ended up with a new clean install. When i copied the backup files to new install the problem was back Are you saying a clean install the admin pages work, but after restoring a backup it doesn't? If so that points to an existing config, but according to the log should be plugin related.
macki_b 0 Posted December 17, 2021 Author Posted December 17, 2021 Hmmmm.... strange. I did a manual backup according to lukes link. I ended up with the same problem. Wiped emby again and started over clean. Worked! I used the emby plugin that comes with truenas with both of my tries if that can make any difference?
Luke 42237 Posted December 17, 2021 Posted December 17, 2021 That's interesting. Thanks for the info.
fantaxp7 191 Posted January 3, 2022 Posted January 3, 2022 Hello, So I had an unrelated issue an needed to start from scratch. Yesterday I made a clean debian container on proxmox, installed latest beta and restored a backup emby config. All was good. Today I log in after rebooting my server and noticed the admin settings were gone. I restored the one auto backup that proxmox made an luckily all settings are back. Just another FYI 1
