macgarcia82 0 Posted December 11, 2021 Posted December 11, 2021 Hello I bought a new fire stick 4k max (wifi6), when I go to the app store to install it says its not compatible? Is this correct, will it be made available to this fire stick?
GrimReaper 4898 Posted December 11, 2021 Posted December 11, 2021 It is likely not compatible with your phone, why don't you install directly from Firestick?
macgarcia82 0 Posted December 11, 2021 Author Posted December 11, 2021 I did try searching for it using the fire stick and couldn't find it. So I tried through the amazon app store, and figured with the incompatibility statement that was the reason.
Solution GrimReaper 4898 Posted December 11, 2021 Solution Posted December 11, 2021 You can sideload latest stable apk from here: Emby for Fire TV - Emby And latest beta apk from here: 1
ebr 16337 Posted December 11, 2021 Posted December 11, 2021 Is your Stick logged into the same Amazon account as your phone? If so, you should be able to push it to the device. Are you outside an area that Amazon actually sells these Sticks?
macgarcia82 0 Posted December 11, 2021 Author Posted December 11, 2021 Hi, yes it is the same account as my phone, but I think the issue was a firmware update that got pushed this morning. I can now get it through the appstore
