orbdust 0 Posted December 10, 2021 Posted December 10, 2021 (edited) Hey there Emby, I am at wit's end, I am confident that I am following Emby's movie naming convention strictly, as per title, they just won't merge. This happens on Emby Server Linux ARM 4.7.0.15 beta. Are there really no other solution apart from merging manually? Edited December 10, 2021 by orbdust
Happy2Play 9813 Posted December 10, 2021 Posted December 10, 2021 Best guess is you have exceeded the limit of 8 versions and all versions appear separately. https://emby.media/community/index.php?/topic/89807-movie-grouping-does-not-work-for-more-than-8-versions/ You can use the plugin. Automatic version grouping for movies - Plugins - Emby Community 1
orbdust 0 Posted December 10, 2021 Author Posted December 10, 2021 I see, thanks for the info, appreciate it
