Oceanus 6 Posted August 14, 2021 Posted August 14, 2021 Hey, sometimes the youtube trailer links coming from moviedb are just crap. Is there a way to edit the trailer link? If not, could you add the possibility to edit the trailer link in metadata manager? Thanks in advance.
Happy2Play 9802 Posted August 14, 2021 Posted August 14, 2021 14 minutes ago, Oceanus said: Hey, sometimes the youtube trailer links coming from moviedb are just crap. Is there a way to edit the trailer link? If not, could you add the possibility to edit the trailer link in metadata manager? Thanks in advance. Currently the trailer url is not exposed to edit within Emby UI. Only options is to edit the url in the nfo if you write nfo files. If you don't write nfo files you would have to edit the database directly. 1 1
Oceanus 6 Posted August 14, 2021 Author Posted August 14, 2021 Could you expose it within the Emby UI?
MBSki 1115 Posted August 14, 2021 Posted August 14, 2021 21 minutes ago, Happy2Play said: Only options is to edit the url in the nfo if you write nfo files. Is there an nfo primer anywhere? I currently don't use them, but wondering if there's an easy way to create them for something like this. I'm curious what the other advantages would be as well.
Luke 42200 Posted August 14, 2021 Posted August 14, 2021 Yes it's something we can look at adding. Thanks for the feedback. 2
Carlo 4561 Posted August 14, 2021 Posted August 14, 2021 49 minutes ago, mbarylski said: Is there an nfo primer anywhere? I currently don't use them, but wondering if there's an easy way to create them for something like this. I'm curious what the other advantages would be as well. Turn on NFO use in the library and make a change to a movie/episode and it will write the NFO. Anything new will get an NFO written. Then you can look and see how the trailer is stored in the NFO. 1
Happy2Play 9802 Posted August 14, 2021 Posted August 14, 2021 2 minutes ago, cayars said: 52 minutes ago, mbarylski said: Is there an nfo primer anywhere? I currently don't use them, but wondering if there's an easy way to create them for something like this. I'm curious what the other advantages would be as well. Turn on NFO use in the library and make a change to a movie/episode and it will write the NFO. Anything new will get an NFO written. Then you can look and see how the trailer is stored in the NFO. All you have to do is enable the option, select edit metadata and hit save to write the file. But that still will not give you a full picture as it will only populate what the database has. So it really is not possible to see all the field Emby can/will use as they are not written as empty fields. 1
Oxide 139 Posted August 15, 2021 Posted August 15, 2021 This has been request way back in 2019, still living in hope Metadata field for Trailers - Feature Requests - Emby Community
DJkhaled 8 Posted August 15, 2021 Posted August 15, 2021 4 hours ago, Oxide said: This has been request way back in 2019, still living in hope Metadata field for Trailers - Feature Requests - Emby Community The pursuit of perfection for all the requests people want just impedes the more important things like stability on new releases etc.. patience my friend
