Fast Forward or Rewind not working
Hi,
I am running MB android app 1.0.45 on my Nexus 5 (Jellybean ver 4.4.4). MB Server is Win7 version 3.0.5326.13255.  Unfortunately the rewind and fast forward are not working. If I tap on either it just jumps back to the very beginning of the video. If I tap and hold, the same thing happens  This is a video streamcopy (MKV file) with transcode audio.  Is this a known issue?  I can provide more information if that would be useful.
Also, it would be nice if when you use the slider to skip to a location, the timer would update to show the current location of the slider.
Thank you for such a great app!
Redshirt
I'll look into the seek behaviour.
  • 1 year later...
efigalaxie
I am having this issue as well. My videos are mp4 in origin.
bluemonkey07
This thread is 1 year old and was for the old app developed by someone no longer around. ..but I suspect you issue is as i described in your other thread about items not identified correctly by the server for some reason
  • Like 1
efigalaxie
Yes, Vidman!! - You had the answer. Thanks!!!
