NTFS usb Library folders not recognized
al92780
 Share
Below are several system configuration outputs.   Files are accessible using file manager.
EMBY Library Access
pi@raspberrypi:~ $ ls -l /media/pi
total 12
drwxr-xr-x 2 pi   pi   8192 Dec 31  1969 'AL USB'
drwxrwxr-x 1 emby emby 4096 Sep 26 09:49  embydisk
pi@raspberrypi:~ $ sudo lsblk -o UUID,NAME,FSTYPE,SIZE,MOUNTPOINT,LABEL,MODEL
UUID                                 NAME    FSTYPE  SIZE MOUNTPOINT LABEL MODEL
                                     sda            57.7G                  USB_D
EC68CD1868CCE306                     └─sda1  ntfs   57.7G /media/pi/ EmbyDisk
                                     sdb            14.5G
8280-12EE                            └─sdb1  vfat   14.5G /media/pi/ AL USB
                                     mmcblk0        59.5G
6284-658D                            ├─mmcblk0p1
                                     │       vfat    256M /boot      boot
3a324232-335f-4617-84c3-d4889840dc93 └─mmcblk0p2
                                             ext4   59.2G /          rootfs
pi:x:1000:1000:,,,:/home/pi:/bin/bash
/etc/fstab
/dev/sda1 /media/pi/embydisk ntfs-3g rwx,uid=emby,gid=emby,dmask=0002,fmask=0003 0 0
 Thanks for any help.
Link to comment
Share on other sites
I thought there would be a group called EMBY.  What command do I use to add EMBY?  Should I mount USB at the same level as Media ?
pi@raspberrypi:~ $ groups
pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi
Link to comment
mastrmind11
18 hours ago, al92780 said:
Permission fixed, can access files.  Changed both Owner and Group, are both necessary?
Home videos choppy, will start new topic.
Thanks
both are not necessary and are specific to your needs.  ie, if you need any other user to have access to the files, then creating a new group called media or whatever and adding emby (and other users) to that group would be the proper way to set permissions.  if not, then emby:emby is fine.
  • Like 1
Link to comment
 Share
