Guest topbanana Posted August 30, 2020 Posted August 30, 2020 For movies, at the bottom, there's the 'Media Info' section that include the path to the media. One of the things this allows us to do is quickly check to see if the identified movies matches the filename of the movie file, spotting if emby has got it wrong again (which it does quite often, sometimes hilariously badly!!!) But for series and season, this Media Info section isn't there... Obviously it can't show the technical info for all the numerous episodes, the media files, resolution, codecs, etc... But it could still show the path to the series (and season?). Having the path there, again, would help us spot if emby had identified the series wrongly, just by scrolling down to the bottom and checking the path. Emby has made several mistakes identifying series in my libraries and for the one's i wasn't familiar with, i had to go and check it using the three dot 'More' button, then 'Identify', before it shows the dialog box showing the Path at the top and seeing it was wrong. TL;DR Can we have this at the bottom of the Series pages please. Quote ...Links IMDB TheMovieDb TheTVDB Trakt Zap2ItMedia Info Path S:\Series\The Wire
