Pepper Jobs W10 Gyro Remote (remapping buttons)
aaronsomek
I bought one of these remotes for my setup and it works great except the remote doesn't have any software to remap keys. I Played around with AutoHotkey and other similar software trying to get the buttons remapped to shortcuts in Emby Theatre but I had limited success.
Then while installing an update for Windows PowerToys I found it has a function to remap keyboard keys and shortcuts. It works perfectly, it will detect the incoming button press for you too so you don't have to try to figure out what instructions the remote is sending.
Just thought I'd leave this here to help anyone else who was searching for a solution.
Hi, thanks for the info !
