Python Exception "argument "value" for method "setProperty" must be unicode or str"
themightylc
 Hi guys. Don't know what my problem is but since 0.6.something i have not done a single xbmb3c install without problems.
I just made a fresh install (i.e. new xbmc + xbmb3c) and get the following error:
19:00:16 T:1351967840 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting 'None' as 0 minutes
19:00:16 T:1351967840   ERROR: EXCEPTION: argument "value" for method "setProperty" must be unicode or str
19:00:16 T:1351967840   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                             - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
                                            Error Type: <type 'exceptions.TypeError'>
                                            Error Contents: argument "value" for method "setProperty" must be unicode or str
                                            Traceback (most recent call last):
                                              File "/root/.xbmc/addons/MediaBrowser.XBMC-master/default.py", line 2246, in <module>
                                                displaySections()
                                              File "/root/.xbmc/addons/MediaBrowser.XBMC-master/default.py", line 610, in displaySections
                                                dirItems.append(addGUIItem(s_url, details, extraData))
                                              File "/root/.xbmc/addons/MediaBrowser.XBMC-master/default.py", line 514, in addGUIItem
                                                list.setProperty('TotalSeasons',extraData.get('TotalSeasons'))
                                            TypeError: argument "value" for method "setProperty" must be unicode or str
                                            -->End of Python script error report<--
Not sure but it seems the "None" value for duration mustbe causing this, but i don't know which item this is referring to.
I'll take a quick look at the source now.
Complete log: http://pastebin.com/NdA2fq3g
themightylc
Inserted a check for None at the lines that set the list.properties from the extraData. Works as expected.
xnappo
Thanks - can you post the exact changes?
xnappo
im85288
I think I found what changes you were meaning, can you try the latest version (0.9.511) to see if it's resolved.
Guest
