VPN connection closed on stream start (OpenVPN, Android 10)
Go to solution Solved by 28daniel28,
Hi,
I've recently switched from iOS to Android and I am very satisfied. The only issue I have is with the emby app: I can use the app in my local network just fine, but when I'm somewhere else and I'm connected to my raspberry VPN via OpenVPN (emby-server is also running on the same machine) I can open the emby app and browse content as well, but as soon as I try to actually stream something a really weird behavior can be seen: The VPN connection randomly closes before any content is streamed at all. I've tried several different WiFis and my mobile connection but the same thing happens all the time. This was never an issue with iOS. Please fix ASAP, as I cannot use the emby app on the go.
I'm on Android 10 (MIUI 11) and I've tried both, the current stable and the current beta version of the emby android app.
Best regards from Germany,
Daniel
Edited by 28daniel28
  • Solution
Seems like this was fixed with a reboot, sometimes the solution is that simple! Still weird tho. Sorry for thr inconvenience :)
  • Like 1
Thanks for the feedback.
