Gronnie 8 Posted June 20, 2014 Posted June 20, 2014 When I add my server in the app, the internal as well as external ip address is added (I am presuming it gets whichever was not used to add the connection from the server itself?). I have a dynamic ip address, so I use dyndns.org through my router to keep the ip address updated. When I change the external address to use myname.dyndns.org, it gets overwritten with the actual external ip address every time I connect to the server. How do I make myname.dyndns.org stick?
Solution Gronnie 8 Posted June 20, 2014 Author Solution Posted June 20, 2014 Well, I feel dumb now for not looking around some more. It appears there is a setting for this in the server settings under Advanced --> Server. 1
