Emby - sound problems - Sonos
Go to solution Solved by Guest Allehaderos,
Guest Allehaderos
Hi guys,
I got my emby server on my synology, and i just bought a sonos playbar and a sub.
When I try to start my movies with DTS sound, no sound comes, I've read that sonos have problems with dts.
I have also read that people using PLEX may well make DTS work, does anyone know if I can get the emby the same?
Hope someone can help me
Guest asrequested
What app are you using?
Guest Allehaderos
Emby on my Nvidia shield
My Emby server is on my synology
My sonos playbar is connected with a optical cable
Guest asrequested
Shield doesn't have an optical output, so are you using the optical output from your TV?
Guest Allehaderos
Yes, HDMI from sheild to TV and optical from tv to sonos...
Guest asrequested
So the issue will be with what your TV supports. If your TV supports DTS, the shield will send that to the TV, and then your TV is responsible for the rest. So, more questions. Is your TV configured correctly? Does the Sonos support multi channel audio?
Guest Allehaderos
The last question I dont understand/know
I just set up my sonos to day, without my sonos my DTS movie played fine :/
Guest asrequested
Looking at it, it does.
So you need to make sure your TV audio is configured correctly, to let AC3 and DTS passthrough.
Guest Allehaderos
my tv is a SONY KD55XE8096 4K TV
  • Solution
Guest Allehaderos
I found some settings on my shield where I could select audio formats, so now it works..
Thank you very much for your help
Thanks for the feedback !
