Red5ive 30 Posted October 23, 2019 Posted October 23, 2019 In Kodi I'm using the Emby for kodi plugin, Embuary skin and using NextPVR as my backend. I'm using an MCE remote that I got working using the scripts here: http://xbmccustomregis.sourceforge.net/remote_auto.html The buttons now work in every part of Kodi except live TV where the pause/play and skip buttons do nothing. Strangely if I play back a recorded show or some other media the play/pause/skip buttons work fine. They also work fine in Emby theatre (Emby is setup to use NextPVR as well) Any ideas? I am so close to having it all working!
sualfred 677 Posted October 24, 2019 Posted October 24, 2019 You better ask there: https://forum.kodi.tv/forumdisplay.php?fid=175 It sounds like Kodi doesn't "know" that you are able to timeshift and pause.
Solution Red5ive 30 Posted October 24, 2019 Author Solution Posted October 24, 2019 Thanks for the hint sualfred, I found the setting! It's under the NextPVR plugin settings in Kodi, have to enable timeshift or extended timeshift (though I found I was getting picture break up artifacts on some channels with extended enabled).
