Syncing Issues
Go to solution Solved by Angelblue05,
@@Angelblue05 it might be one of these
Seeing Is Believing..... No Regrets..... Too Close to the Sun
Edited by Drego344
Angelblue05
EMBY.objects.core.tvshows -> Skipping stacked episode Too Close to the Sun [40521]
That seems to be the reason, does editing the metadata on the episode (just hit save in the metadata editor for the episode), does that make the episode appear? Rather than doing a library update I mean.
Can you tell me if both episodes exists in the folder for some time when this happen?
Edited by Angelblue05
@@Angelblue05 if i edit the meta data it appears yes....no they are not in the same folder..
  • Like 1
@@Angelblue05 im not sure whats going on, had this problem twice before and you fixed it on your end.... its seem like whenever i update emby something breaks
Angelblue05
@@Drego344
If I give you a build to test right now, is this something you can test real quick for me? To see if my fix works?
@@Angelblue05 sorry.... i could, but to replicate the problem i would have to wait until episodes get updated
  • Like 1
  • Solution
Angelblue05
Ok no problem, I'm getting ready to release 4.1.15
Let me know if it still happens with it. Looking at your log, it seems things are happening a little out of order, where it processed some updates before removing older content and that seemed to trigger the stacking detection. My fix should force removed items to be processed first, and hopefully it will resolve the newer episode not getting added and then removing the older version leaving you with no episode at all.
@@Angelblue05 it seems like it's working now, will still keep an eye on it.... Thanks again
  • Like 1
Guest
