lightsout 138 Posted September 9, 2019 Share Posted September 9, 2019 I always see traces of emby after I uninstall this plugin. I recently got an Odroid N2 and have been testing if I want to use Emby for Kodi or standard Kodi DB. I uninstalled the plugin and everything that says emby under add-ons. But I still see this. What have I missed? Link to comment Share on other sites More sharing options...
Angelblue05 4128 Posted September 10, 2019 Share Posted September 10, 2019 Reset the local database, then uninstall. Link to comment Share on other sites More sharing options...
lightsout 138 Posted September 10, 2019 Author Share Posted September 10, 2019 Reset the local database, then uninstall. Your saying reset database before uninstalling? I did the update library and clean library a couple things but they wouldn't go away. I decided to use the add on so my watched counts sync among other reasons. But I'll keep that in mind. Thank you for the work you have done on this. Link to comment Share on other sites More sharing options...
Solution Angelblue05 4128 Posted September 10, 2019 Solution Share Posted September 10, 2019 Yes, install the add-on, then launch it > reset local database to reset everything. This will remove all traces. 1 Link to comment Share on other sites More sharing options...
