Issue playing a currently recording
DamnedUndies
Thanks ebr, will do.
Just so I understand:
The HDHR Extend is enabled to do HW transcoding.
Does Emby server also do some level of transcoding on top of this?
Hi @@DamnedUndies, sometimes. We do avoid it when possible, but it depends on what Emby app you're using, what the device supports playing, what your video quality settings in the app are, etc.
  • 2 weeks later...
Any update on this? It's a really annoying bug that means I can't watch recordings until they've finished airing.
We are looking into this. Thanks for reporting.
This is resolved in the upcoming 4.4 release of Emby Server. Thanks for reporting.
  • Like 1
Any idea when 4.4 (non beta) might be released? Just curious if it's close.
  • Like 1
Hey,
I installed the beta, it's perfect now!
The only thing, a pretty minor thing, is that it's possible to fast forward past live while watching a recording in progress, and the time remaining isn't accurate, but more importantly watching the recording in progress works perfectly, and I can fast forward through the ads!
A very happy camper here. Thanks!
  • Like 1
Thanks for the feedback!
Can anyone point me to something that details how to install beta versions?  I downloaded embyserver-win-x64-4.4.0.9.7z and already had something to extra it, but I'm not sure if I should just take all the contents and overwrite the existing server files or what.
  • Like 1
Hi.  We don't suggest installing beta versions just to get early access to new features or fixes so please be aware of all the implications that come with running a beta version (possible instability, errors, etc.).
Thanks.
DamnedUndies
Huge improvement!
What a difference.
Keep up the great work.
Edited by DamnedUndies
Thanks for the feedback.
Thanks.
Understood. I am a software developer myself so I get the concept/intent of beta code. So is 4.4 anywhere close to being released officially? I won't hold you to anything of course! Edited by bcm00re
  • Like 2
