scottiamit 0 Posted May 14, 2019 Posted May 14, 2019 Hi guys, I am using a very old MCE remote control which works OK, but seems tolag quite badly which I think may be IR related somehow but sometimes it can take 10-20 seconds before button presses are received. however my keyboard and mouse always work fine straight away. I am running emby server and client on a windows 10 PC. What kind of remote control would you recommend? I preume bluetooth will disconnect and reconnect all the time to save battery and will therefore also have lag? Thanks all.
nyplayer 90 Posted May 14, 2019 Posted May 14, 2019 (edited) Hi guys, I am using a very old MCE remote control which works OK, but seems tolag quite badly which I think may be IR related somehow but sometimes it can take 10-20 seconds before button presses are received. however my keyboard and mouse always work fine straight away. I am running emby server and client on a windows 10 PC. What kind of remote control would you recommend? I preume bluetooth will disconnect and reconnect all the time to save battery and will therefore also have lag? Thanks all. I use this one to control my windows PC ... https://www.amazon.com/gp/product/B078NT49MJ/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1 Here is a video on it ... Edited May 14, 2019 by nyplayer
scottiamit 0 Posted May 14, 2019 Author Posted May 14, 2019 Great thanks I will check it out, cheers for the super fast reply too!
