XPEnology Users - What loaders are you currently using?
XPEnology
  • Please log in to reply
27 replies to this topic
#1 solabc16 OFFLINE
solabc16
    Advanced Member
  • ForumMod
  • 1967 posts
  • Local time: 03:42 AM
Posted 15 November 2018 - 01:01 PM
Hello All
If you've been following the XPEnology support threads closely, you'll know that we work hard to make sure you get a great experience with Emby Server on this platform.
You're also likely aware there are a number of loaders available now, when we started there was only one and that was based on DSM 5.2.
Please can you drop us a line here and let us know what loaders you are currently running with, so we can look at how best to develop and optimise the Emby Server package going forward.
Best
- James
#2 RobsterUK OFFLINE
RobsterUK
    Advanced Member
  • Members
  • 69 posts
Posted 19 November 2018 - 08:10 AM
Hey James,
Surprised no-one else has replied to this yet!
I am still using the same platform as when the Synology/XPEnology isntallation came out of beta.
Using boot loader 5.2-5967 & DSM Version 5.2-5967 Update 6
Plan on sticking with this for a while.
Everything is working well & I see no reason to upset the apple cart and upgrade the bootloader & DSM version any time soon.
Thanks for your continued effort in developing the platform ;)
#3 solabc16 OFFLINE
solabc16
    Advanced Member
  • ForumMod
  • 1967 posts
Posted 19 November 2018 - 10:32 AM
Hi @RobsterUK
People only tend to come here when something is broken, so it was probably a little hopeful to expect to much immediate traction!
One of the test systems here is also based on that loader. It was one of the reasons for asking, to see whether we need to continue support for DSM 5.2.
It does work well as a foundation for running a system such as Emby Server, so as you say no real need to 'upset the apple cart'.
I've seen mixed feedback on users getting h/w transcoding working with the more recent loaders, and I see 1.04b has updated GPU support. If this starts to work reliably, I can see that being a significant driver for users to explore switching to a new loader.
Best
- James
Edited by solabc16, 19 November 2018 - 10:33 AM.
#4 RobsterUK OFFLINE
RobsterUK
    Advanced Member
  • Members
  • 69 posts
Posted 21 November 2018 - 12:33 PM
GPU H/W transcoding! That would be a big enough reason to try and upgrade.
Will pop over to the XPENo forums and check out what's going on there.
Emby is the most frequently used (practically daily) function of my XPENo NAS.
Which is partly why I haven't upgraded Emby server or thought about upgrading the boot loader.
I plan to be sticking with the current boot loader for a while yet. So if you could continue support for this version it would be most appreciated.
Thanks.
#5 solabc16 OFFLINE
solabc16
    Advanced Member
  • ForumMod
  • 1967 posts
Posted 21 November 2018 - 07:40 PM
Hello @RobsterUK
No problem at all, it shouldn't be too difficult to keep the compatibility layer we put in working reasonably sensibly.
There'll just be a bit of work to do around Package Center behaviours.
I've till got a DSM 5 system here, so I'll be able to give it a reasonable run out.
Best
- James
#6 WiteWulf OFFLINE
WiteWulf
    Member
  • Members
  • 15 posts
  • Local time: 02:42 AM
Posted 14 January 2019 - 04:04 PM
Hi there, just testing out Emby at the moment as a replacement for Plex and liking what I see (mostly) so far!
I'm running DSM 6.2-23739U2 on an HP Gen8 Microserver, baremetal, with 4GB of RAM and the stock G1610T CPU (2.3GHz Celeron) and Jun's 1.03b loader for DS3615xs.
I was so pleased to see the specific support for XPEnology users and hope it's maintained into the new Emby Server 4.0 release.
#7 solabc16 OFFLINE
solabc16
    Advanced Member
  • ForumMod
  • 1967 posts
Posted 14 January 2019 - 04:36 PM
Hi @WiteWulf
Thanks for getting in touch and the feedback, any problems or questions, don't hesitate to ask.
When Emby Server 4.0 is released, both Synology and XPEnology based systems will be supported from day #1.
Best
- James
#8 solabc16 OFFLINE
solabc16
    Advanced Member
  • ForumMod
  • 1967 posts
Posted 14 January 2019 - 04:42 PM
Hi @WiteWulf
...I should also have added, the best custom package for your G1610T at this time, would be the 'sandybridge' package.
We may add an 'ivybridge' optimised package in the future, if there is sufficient demand.
If you haven't seen it already, take a look at : https://github.com/M...s-for-XPEnology
Best
- James
#9 WiteWulf OFFLINE
WiteWulf
    Member
  • Members
  • 15 posts
Posted 15 January 2019 - 05:04 AM
Hi @WiteWulf
Thanks James, I'd been using the Core2 package.
Is there any way to change the package without uninstalling and reinstalling? I'd rather not lose my settings and library database. With other Synology packages it's a simple matter of downloading the package itself and doing a manual install, but there doesn't appear to be a mechanism for downloading those package files for Emby beyond the using the repo within Synology's package manager.
#10 solabc16 OFFLINE
solabc16
    Advanced Member
  • ForumMod
  • 1967 posts
Posted 15 January 2019 - 07:42 AM
Hi @WiteWulf
If you change your package source now, when the next update comes out it will install the package best optimised for your processor.
Simple as that :)
Best
- James
#11 WiteWulf OFFLINE
WiteWulf
    Member
  • Members
  • 15 posts
Posted 15 January 2019 - 07:46 AM
Thought that would be the case, was just wondering if I could force it, non-destructively, before the update. Thanks for the reply, tho
#12 solabc16 OFFLINE
solabc16
    Advanced Member
  • ForumMod
  • 1967 posts
Posted 15 January 2019 - 07:49 AM
Hi @WiteWulf
There are ways to do that, but as the next update is due any moment now, it's probably worth hanging fire this time.
Best
- James
#13 WiteWulf OFFLINE
WiteWulf
    Member
  • Members
  • 15 posts
Posted 16 January 2019 - 06:18 AM
Okaaaay, I updated the repo URL to point to the sandybridge package, updated, and now it won't start.
I seem to recall having this when I first started trying Emby and could only get Core2 to work.
So, back to my previous question: can I download the package and install it manually so I don't blow my database away, please?  :D
Diagnostic output:
* removed - solabc16 *
Edited by solabc16, 16 January 2019 - 06:25 AM.
#14 solabc16 OFFLINE
solabc16
    Advanced Member
  • ForumMod
  • 1967 posts
Posted 16 January 2019 - 06:21 AM
Hello @WiteWulf
Can you run the Send Logs utility, details here : https://github.com/M...us-Support-Logs
I'll PM you and get you up and running again once I've looked at the logs.
Best
- James
#15 WiteWulf OFFLINE
WiteWulf
    Member
  • Members
  • 15 posts
Posted 16 January 2019 - 06:23 AM
Done: "sendlogs_diskstation_synology_bromolow_3615xs_20190116T102225UTC.tgz"
As I say, I could only get it working previously with the Core2 build. Having the documentation, though, I would agree that a Sandybridge build should work this architecture.
Edited by WiteWulf, 16 January 2019 - 06:24 AM.
#16 solabc16 OFFLINE
solabc16
    Advanced Member
  • ForumMod
  • 1967 posts
Posted 16 January 2019 - 06:26 AM
Thanks @WiteWulf, I'm looking now  - and yes, I want to make sure we understand the issue here, so can avoid in future.
Best
- James
#17 WiteWulf OFFLINE
WiteWulf
    Member
  • Members
  • 15 posts
Posted 16 January 2019 - 07:10 AM
All sorted, thanks for the help James.
#18 solabc16 OFFLINE
solabc16
    Advanced Member
  • ForumMod
  • 1967 posts
Posted 16 January 2019 - 07:18 AM
Hello @WiteWulf
No problem, glad we got that sorted quickly.
Now the latest stable has been released, I'm going to pick up an item on my whiteboard - which is to add a wiki package listing the optimal package architecture for processors that we've come across whilst working with users in the community.
This should help reduce the 'guesswork' a little further.
Best
- James
#19 MardukNT OFFLINE
MardukNT
    Newbie
  • Members
  • 6 posts
  • Local time: 07:42 PM
  • LocationGreater Seattle Area
Posted 13 March 2019 - 01:13 AM
Hope this helps.
I'm using Jun's Loader 1.03b with DS3617xs image. (See HERE) Running DSM v6.2.1-23824 Update 6 (See HERE).
I've installed the XPEnology Emby Server from (HERE) and after running Version 4.0.2.0 for a week, there are no issues to report. Everything's working like a champ.
This is all running on a bare metal Lenovo ThinkCentre M700 Tiny, sporting a 6th Generation Intel Core i5-6500T (Skylake) Processor (@2.50GHz) (See HERE for full Specs).
It comes with 8GB RAM and I swapped in a 500GB Samsung SSD.  I also own a Synology DS412+ (w/4 3TB WD Reds) providing all the storage remotely via CIFS over a bonded connection (See HERE and HERE).
There were a few hiccups along the way (due to there being a learning curve for XPEnology), but I can honestly say it all works great now.
The question I have is; Am I running the best build of Emby for my hardware?
Thanks for all your dedication to the development of this program.
--Cheers!
MardukNT
Edited by MardukNT, 13 March 2019 - 07:25 AM.
#20 solabc16 OFFLINE
solabc16
    Advanced Member
  • ForumMod
  • 1967 posts
Posted 13 March 2019 - 09:33 AM
Hello @MardukNT
Thanks for taking the time to post the above, appreciated.
The default package for XPEnology systems you will have seen on the main page (https://emby.media/nas-server.html) - so that would indeed be your starting point.
e.g.
https://synology.emby.media/?package_repository=360efc6e-de72-4073-b603-2bfbd7001586
However, there are processor optimised packages available, which are discussed here and here.
At this time, the 'haswell' package would be the best match for your system - as the XPEnology user base grows, we're adding more architectures, so it's likely 'skylake' will make an appearance soon.
Best
- James
Also tagged with one or more of these keywords: XPEnology
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
