Post processing script question
I have a script question that should be simple but I'm being stupid:
I've created/modded a post-processing script for Emby that converts/renames media, cuts commercials, etc. based on several excellent suggestions elsewhere in the forum. It runs fine except when it runs in to certain titles.
Example problem (test.sh script I did for troubleshooting):
#!/bin/csh
set path = ($path /usr/local/bin)
set w1 = `jot -r 1 2 15`
set filename = `printf "%s " $1:t:r:r`
set grab = `printf "%s " $1:h`
set a = `echo "$filename".ts`
set b = `echo "$grab/$filename"_cut.ts`
set c = `echo "$grab/$filename".mp4`
set d = `echo "$grab/$filename".srt`
echo "$filename"
If the external input ($1) is, say, this:
"/media/recording/Family Guy (1999)/Season 8/Family Guy S08E20 The Splendid Source.ts"
It works fine. The script grabs the correct filename/path, then I assign different variables so the rest of my script can work correctly (i.e. _cut.ts is the new name after I run Comskip/comcut, the others after I extract subtitles and convert to .mp4, and so on).
However if I have a show like this:
"/media/recording/House Hunters International (2006)/Season 117/House Hunters International S117E01 House Fishing in St. Croix.ts"
Everything after the . in "St. Croix.ts" is truncated
"/media/recording/House Hunters International (2006)/Season 117/House Hunters International S117E01 House Fishing in St.ts"
However if I echo "$1" I get the correct showname back - so the variable from Emby is being passed in correctly, my script/printf is screwing it up.
In my test script, the above name echos this for $filename
Obviously I'm not escaping correctly but I can't figure it out and my tiny brain is tired.
How can I sanitize $1 correctly? This:
Is so it's easier to rename the files without an extra .ts on the end (i.e. "filename.ts.mp4")
Figured it out while the forums were having problems :)
Didn't know about the basename utility:
set filename = `basename "$1" .ts`
now to figure out how to clean up the files afterwards properly.
  • Like 1
