RedStripe 14 Posted March 25, 2014 Posted March 25, 2014 (edited) TV guide disappeared.Restarted server.Clicked "Refresh Guide Data" on Live TV page.++++++Server Log2014-03-25 18:33:58.4028 Info - App: Refresh Guide Completed after 0 minute(s) and 0 seconds ++++++Clicked "Guide" on LIVE TV page. Received message "SEQUENCE CONTAINS NO ELEMENTS"++++++Server Log2014-03-25 18:36:25.6702 Debug - HttpServer: HTTP GET http://69.1.21.61:8096/mediabrowser/LiveTv/GuideInfo?2014-03-25 18:36:25.6852 Error - DtoUtils: ServiceBase<TRequest>::Service Exception Sequence contains no elements System.InvalidOperationException at System.Linq.Enumerable.Min[TSource](IEnumerable`1 source) at MediaBrowser.Server.Implementations.LiveTv.LiveTvManager.GetGuideInfo() at lambda_method(Closure , Object , Object ) at ServiceStack.Host.ServiceRunner`1.Execute(IRequest request, Object instance, TRequest requestDto) 2014-03-25 18:36:25.6852 Error - HttpServer: Error processing request for /mediabrowser/LiveTv/GuideInfo? Sequence contains no elements ServiceStack.HttpError No Stack Trace Available 2014-03-25 18:36:25.6972 Debug - HttpServer: HTTP Response 422 to 69.1.21.61:4927. Response time: 27.0015 ms Url: http://69.1.21.61:8096/mediabrowser/LiveTv/GuideInfo?++++++ server-63531369135.log There are no ServerWMC errors in either log. P.S. The capability to select a TV channel directly would be nice. Edited March 25, 2014 by RedStripe
krustyreturns 191 Posted March 26, 2014 Posted March 26, 2014 Are you sure swmc is returning guide entries? Look for the GetEntries command in the server log. There will be one for each channel called during a guide refresh. If there are no entries to return, it prints out a warning on each of these commands..
Solution RedStripe 14 Posted March 26, 2014 Author Solution Posted March 26, 2014 (edited) Not sure which server log you are referring to but there is no GetEntries command in the serverXXXX.log or either serverWMC log. Resolved. Somewhere I was told to check hide DRM channels. I unchecked this and the guide populated. Sorry for the bother. Edited March 26, 2014 by RedStripe 1
